Question about Canon PIXMA MP470 All-in-One Printer
I hve a problem that print head is not installed why???
I sent you a question on paper napkin stuck in HP printer. Hve not received your respone beyond what kind of printer it is, HP Officejet 5610 All-in one.
If you are ready to open it, then do the following steps else send it to a ervice center.Ok
>Remove the top cover by taken up the screws
>u can see the print head and a roller.
>remove the roller by taking out its serews(sme having lock)
>your napkin paper is seen unde it
>remove it
>then fix the roller,print head and top cover one by one (dont forget to fix the screws)
If any problems,contact us.
Jul 12, 2011 | Office Equipment & Supplies
Fax problems
ok..let's start with this step
go here, get a fresh set of drivers, and remove old s/w, then install the new set
Jun 18, 2008 | HP 1010 Plain Paper Inkjet Fax
ERROR MESSAGE U051
Print head not installed,
or not properly
installed.
[1401] U051 Print head is not installed. Install
the print head.
Install the print head properly.
It may be that print head is defective or main PCB assy
Jan 12, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Photos hve stripes on them
Try cleaning the print heads. Look at replacing the printer. Right now, they are giving them away.
Rich
Dec 15, 2009 | Canon Office Equipment & Supplies
Five flashes pause then a further 5 flashes
This error mean "non installed or defective print head".First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist you need to replace the print head.It's part number is QY6-0057.
Nov 25, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
I have a HP 4100 printer. Installed new ink.Purple streaks
That's a neat trick. The 4100 is a printer that uses one BLACK toner cartridge. It doesn't print in color. And it doesn't use ink.
Oct 24, 2009 | HP LaserJet 4100 Printer
I hve a installed a new hp print catridge but it deos not print
It asks you to align it. Press ok. The printer will print off an alignment page, then you have to run it through the copy part of your printer. Then press ok, and it will run through and line things up for you.
Apr 15, 2009 | HP Officejet 4215v All-in-One Printer
I am unable to print anything on my printer. It is a Lexmark 1200 series. I hve reconnected it but to no avail. I am in a real pickle
Have you tried printing test page from the computer to check if software has been installed properly.
If not then reinstall the printer software.
Aug 19, 2008 | Lexmark Office Equipment & Supplies
Not printing in black (not a cartridge or head drying)
you first try by cleaning the head then you can clean the cartidge contact point with printer head, if nothing seems to solve the problem then you hve to send the printer for servicing
May 19, 2008 | Canon MultiPASS MP360 All-In-One InkJet...
Canon i9950
Seems impossible to reset the counter, is there a way to manually reset?
Oct 10, 2007 | Canon BubbleJet i9950 InkJet Photo Printer
Canon PIXMA MP470 All-in-One Printer Logo
113 people viewed this question
old marine
old marine
