I had a similar problem. My PS3 was not starting the game discs when I inserted those to PS3. Also those game discs were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3. 2. Hold the power button down; the system will turn on and turn off once again. 3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps 4. When you hear the 2 beeps take finger off power button. 5. You will be prompted to plug in your controller via USB and then hit the PS button 6. The Recovery menu will pop up.
The current Recovery Menu supports: • Restart System: Restarts the PLAYSTATION 3 System. • Restore Default Settings: Reset all system settings back to default. • Restore File System: Checks for corrupt/missing system files. • Rebuild Database: Rebuilds the OS for the PLAYSTATION 3. • Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch. • System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
I had a similar problem. My PS3 did not start the disk based games.
Those disk based games were not visible in the game menu. I did not
working fine.
After
PS3 has executed the DB rebuilding operation, the disc games will be
to PS3.
I did not
working fine. Also downloaded games were working ok.
After
to PS3.
