Question about Samsung S8300 Ultra Touch platinium-red Cell Phone
How do I remove widgets off main screen back to the Widget bar? I've tried sliding them back, but they won't move
I want to remove widget (clock) from the home screen so the picture is not obscured.
just touch the widget for few seconds...then on upper right or left side u will see the remove written on the screen.....now move that widget to that place and u will see no more widget over there.
Aug 19, 2015 | Cell Phones
Got widgets on face of main screen can't get them off
Press and hold the widget, then a garbage can will appear at the top of bottm of the screen. Drag the widget there. It doesn't delete the widget, just moves it off that pagd.
May 09, 2014 | Samsung SGH T139 Hard Plastic Case Flower...
I accidentally removed the clock/weather widget from my home screen trying to pull down my notifications bar, and now I can't find it! How do I get it back?
It's actually a pretty simple way to add widgets back to your home screen.
Long press a blank area of your home screen. A dialog box to Add to Home will appear. Select Widget, and then select Clock [HTC]. You will be able to select from 12 different HTC Clock widgets. Select the one you like, and then press the Select button. It will appear on your home screen as long as there is enough room for it. You can move the widget around by long pressing on the widget and sliding your finger to the desired location on the screen.
Good luck.
Feb 01, 2011 | HTC Hero Smartphone
How do i change from livesquare to widget idle screen?
You just slide youre finger right and it should go back to youre main screen aka widget idle screen
Aug 08, 2010 | LG GW525 Cell Phone
How to remove no event off screen
if its the widget you are talking about it should drag back over to the main widget bar( black box with white arrow) just put finger on icon and hold while you drag it back over
Mar 30, 2010 | Samsung Eternity Cell Phone
How do I remove and manage widgets from my home screen? Also, how do I delete the photos and music that is already on my phone?
To remove widgets from your screen, long hold the widget, and drag to the Remove button at the bottom of the screen.
To move a widget around, long hold and drag the widget to a different part of the screen. If you want to drag it to a different screen, use your track ball while long holding the widget.
To add a widget, press on the (+) button and the select HTC Widget or Android Widget.
To remove music and wallpapers (which are stored on your SD card), you first need to connect your phone to the computer via a USB cord. On your phone, go to your notifications screen (swipe down from the top of your screen). Select "Mount" and your computer will now recognize your phone as an external storage device.
The music files are in the Music directory, and the graphics are located in the Wallpapers directory.
Remember to Turn off USB Storage by going through the notification screen again.
Hope this helps and good luck.
Jan 13, 2010 | HTC Hero Smartphone
Orange world icon in middle of wallpaper screen is it possible to remove it?
on the main screen open the widget bar on the left then simply drag and drop orange world on the widget bar
Aug 18, 2009 | Samsung S5600 Unlocked Cellphone with...
The media player stuck on main screen
Open up the Widget bar and drag the media player back into it, then close the widget scroll bar.
Jul 17, 2009 | Samsung S8300 Ultra Touch platinium-red...
Can't get a Widget back!
This should help you...
Open your widget bar by touching the "W". Once it's open, add all of your widgets to the home screen. Stack them from top of the screen down. that should allow you to scroll down to the one you can't get to otherwise. Now simply move that one up higher, then begin to put back the ones you don't want into your widget bar in order from bottom to top. Once you have them docked back where you want them, click the "X" to close the widget bar.
Problem should be solved.
Jun 26, 2009 | LG KC910 Renoir Cell Phone
I have a samsung tocco ultra, on the main screen a music player box and a grey box that says no event does not want to remvoe from the screen. How do i get rid of these boxes on my screen. Please help.
Just slide it back into the widget bar. I had a problem with this too, although I had tried to slide it back a few times it eventually worked.
May 05, 2009 | Samsung Cell Phones
Samsung S8300 Ultra Touch platinium-red Cell Phone Logo
914 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
