Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Oil fill cup is busted
Oil is going out of the oil fill cup,i guess its lost thread. where can i find a replacement.
    President:
  • 1,167 Answers
Hi buddy does the plug screw in on the threads nicely or is it tight also if it is leaking oil you may have put too much oil inside get back to me bud
Posted on Sep 13, 2009
What is the location of oil sendind unit on a 2002 Suzuki XL7. Engine is a 2.7 liter V6 so I guess that makes it a H-25?
If the diaphragm was busted and with that amount of oil lost I would be seeing oil tracks along the vehicle and under the floor pan. Also there would be a red light on for the oil pressure as the diaphragm has a spring behind it which closes the electrical points and allows the oil light to go off when pressure is above the low oil pressure setting. It may be but I would be looking else where for the problem. I would be looking at valve stem seals broken. These allow the oil to be drawn down into the cylinders when idling at lights and will come out as a puff ofsmoke when taking off and only lasts a few seconds
Dec 31, 2014 | 2002 Suzuki XL-7
Oil leak mcculloch electramac em250 ?
You have a cracked tank, or busted chain oiler. Will have to take apart to view the chain oiler , and check if oil is puddling just under the oil tank. There is some epoxy sealers, or gas tank stop leak material that can possibly repair the busted or leaking oil tank.
Jul 19, 2014 | McCulloch Garden
Froze block on 02dodge diesel replaced 1freeze plug @oil cooler cover plate water still in oil . Was cooler busted?
sounds as if something else gave out when got frozen ,have to do a strip down an check for cracks etc
Mar 30, 2014 | 2002 Dodge Ram Pickup 3500
What type oil and how much should be placed in each cup when oiling?
It is anybody's guess as to what type instrument you might be talking about... I MIGHT guess a Hammond organ but that is only a wild guess. Should this be the case go over to the:
Organforum.com where there are a lot of Hammond owners. You should ONLY use the Hammond oil. Also read this site: http://www.theatreorgans.com/hammond/faq/hammond-faq.html
Sep 15, 2011 | Music
I seem to have lost my manual. Can you tell the rice to water ratio. How much rice and how much water? I have been guessing and it just doesn't come out well. littlebus27@hotmail.com
Hi, you lost the instructions to your rice cooker and now you want to know how much rice and water you need in there? He is what I have found out with using my cooker to prepare rice.
There is a cup that comes with your rice cooker that equals about 2/3 of a regular measuring cup...one of these or 2/3 cup for every cooked cup of rice that you want to end up with... Add as many 2/3 cup fulls of rice as the number of full cups or servings that you want to end up with. See my notes about washing the rice further down in this tip.
The water...
There are lines on most of the cookers with numbers that represent the number of cups you are cooking...fill with water to that line.... If you are not sure, just fill with water a bit over the top of the rice...the amount is not that critical as the cooker senses when the water is cooked off and then shuts down...so a bit more will only make the cooking time a bit longer... no biggee...
Also it is best to rinse your rice before you actually leave the water in the pot that you are going to cook with...
Remeber also, if you have a brown or wild rice setting that the cooking times are MUCH longer...like up to 90 minutes, so get it started in plenty of time or you will be eating rice for a snack before bed...
The best feature is that you just have to place the rice and water in the unit, press the button for the type of rice you are using and forget about it itll it goes through the cycle and shuts down, going into the hold warm mode....it is so easy!!
These things are really goof proof, and make great rice very easily...a little bit of experimentation and you will enjoy very much using your rice cooker.
Mar 11, 2011 | Panasonic SR-106N 5-Cup Rice Cooker
Oil tank threads for drain plug stripped. Unknown why, I was using correct torque specs. May have been overtightened by deaker when I had oil changed. Any solutions to repair threads?
If you live in the USA, you can go to an automotive shop and look for an item called "Thread Saver", it is a coiled soft steel spring that you use to fill the gaps between threads. Mind you this only works on minor thread strips. Any major thread damage will require either a replacement or a welding of a new bolt to the block.
Dec 23, 2010 | 2006 Yamaha Roadliner S
How to replace the dust cup on a craftsman weedwacker
The dust cup has female threads and is threaded onto the end of the drive shaft. Care must be taken if the flexible drive shaft isn't pulled out of the tube and removed. Turn the dust cup until you can line up the hole in the side of the cup with the hole in the shaft. If you can, insert a thin, strong metal object like a Phillips screwdriver in the holes to lock up the shaft. Unscrew the dust cup with a large crescent wrench. Spray the assembly with penetrating oil beforehand to make it easier. Please post back if needed.
Nov 12, 2010 | Craftsman Garden
Where is opening on for oil on the gearbox. lost lot of oil and now needs more
hi the oil filler is on the side remove the plug fill gear box till the oil runs just runs out of the hole put plug in
Apr 24, 2009 | Volkswagen New Beetle Cars & Trucks
Presto fry baby
I just got one of these w/Instructions, Says fill oil to fill level line inside. Cooking oil or shortening. Never use more than (2) - 8 ounces cups of cooking oil or (1) pound of shortening. Hope this helps!
Dec 12, 2008 | Presto 05430 FryBaby Deep Fryer
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
76 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
