Question about Powerware 9120 UPS System
When the machine is power on it show disconnect battery powerware 9120 2kva
    Novelist:
  • 169 Answers
There may be a broken batt lead or a failed cell or bloc inside.
try checking with software or
take out batts and test with meter.
if you dont understand how then get a tech to help. batts are dangerous.
Posted on Sep 15, 2009
Powerware 9120 batt disconnected
Hi Anonymous,
I want to help you with your question, but I need more information from you. Are the batteries new? If you did recently replace the batteries in the cartridge, did you check the connections and make sure contact as being made?
Let me know!
Daniel • daniel@psihq.com • Power & Systems Innovations • 800.260.2259 • www.psihq.com
Aug 22, 2014 | Powerware 9120 UPS System
I have a powerware 9120 (6kva) and about 1 week i replaced all 20 batteries after the UPS failed. but its displaying battery disconnected when i try to power it. i cant seem to figure the problem. i tried...
Did your UPS display "Battery disconnected" or did it display "Battery Failure"? If it was "Battery Failure", for some reason the Powerware 9120 will take almost 18 hours after plugging in to power after battery replacement to correct the Battery Failure indication. Charger has to charge up the batteries, followed by an automatic battery test by the UPS. If the indication was "Battery Disconnected", you will need to check the internal fuses to see if they are blown. If the UPS keeps blowing fuses, it will require a board repair.
Jun 12, 2011 | Powerware 9120 UPS System
Hello, my Powerware 3105 beeps 3 times every 30 seconds or so. I think the battery is not working anymore because when I unplug the power source everything connected turns off. Can you confirm bad battery...
Your problem is showing up under the Powerware 9305 (a very large UPS) but your comments are about the 3105. It sounds like your battery is dead. If your UPS is over 3-5 years old, that's most likely the case. The website address to view the user manual is www.eaton.com/3105 You can contact Eaton directly, too. Eaton bought Powerware about 6 years ago. Here's the contact info. Be sure to have your serial and model numbers ready from the rating label on your UPS.
Toll Free: 1 800 356 5737
E-mail: SinglePhaseTS@eaton.com
Dec 16, 2010 | Powerware Series 9 9305 (PW930525KVA) UPS...
The UPS machine periodical (every 20mins)gives three beeps. The event log in LANSafe shows "UPS Overload".
You may have too many devices connected to the UPS. Try disconnecting some of them. Typically you want your computer and monitor to be connected. You may want to have your internet modem connected also. Printers are a luxury and I would only include them if your UPS can handle it.
Hope this helps, good luck!
Mar 10, 2010 | Powerware 9120 UPS System
Alarm and battery failure ; Powerware 9102
open the screws and disconnect the battery look the voltage written on it and AH (ampere/hour) e.g.12v & 7ah and purchase same value battery and connect look carefully the +ve &-ve polarity of battery and connect in proper way
Feb 24, 2010 | Powerware 9120 UPS System
The UPS dont go to on batteri
Replace the batteries with new one then power the UPS without load for three hours or more so that the batteries can be charged. Then disconnect or switch off power to the UPS and observe if it will till be on using the batteries. If it will be ON then your problem is solved but if it goes off then your UPS is on BYPASS
Apr 09, 2009 | Powerware 9120 UPS System
Powerware 9330
your problem could be related to a dispay board or possible CSB board.
Sep 24, 2008 | Powerware Invensys 9330 Model 40 UPS...
9120 Battery Failure
sounds like inverter is unhappy(causing the input fuse to blow. maybe, just maybe, this Powerware 9120 has given up the ghost? The inverter can short for a variety of reasons. Try to take out the battery completely, and run it as just a power conditioner. If that works, then you have an unhappy inverter in there.
Feb 05, 2008 | Powerware 9120 UPS System
Powerware 9120 UPS System Logo
432 people viewed this question
Top Powerware Computers & Internet Experts
Vassilis Chamaidis
Level 1 Expert
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
