Question about Epson Stylus CX5800F All-In-One InkJet Printer
Changing ink cartridge/s
When I follow steps 1 & 2, (pressing OK, etc), the scanner will not lift completely, cannot change ink cartridge
The scanner cover is on one set of hinges. Below the scanner bed, you can lift the front edge and the scanner bed will lift up on another set of hinges. Do not attempt to manually position the ink cartridge holder to replace individual cartridges, but follow the instructions from the print dialogue box, under Epson Printer Utility and Epson StatusMonitor.
Posted on Jul 19, 2008
Epson printer error codes
The error code E-90 appears when the print head is not able to move back and forth freely.
If the ink cartridge cover is not completely closed, the print head may have trouble moving back and forth. Follow these steps to close the ink cartridge cover:
  1. Turn off the printer
  2. Lift up the scanner.
  3. Press down on the ink cartridge cover to make sure it is completely closed.
  4. Close the scanner and turn the printer back on.
- or, If the packing materials are not removed, the print head will be unable to move and the error code E-90 may appear on the control panel display. Follow these steps to remove the packing materials:
  2. Lift up the scanner to access the printer area.
  3. Remove the tape from the ink cartridge holder.
  4. Close the scanner.
  5. Turn the printer back on
epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-0.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-2.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-5.jpg
Sep 01, 2014 | Epson Stylus DX6050 All-In-One InkJet...
HOW TO CHANGE INK CARTRIDGES ON EPSON 305
For the Epson Stylus NX305, turn on the printer, if it is currently off. Next if the LCD message reads replace ink, press OK and then lift the scanner unit until it locks into place. Open the ink cartridge cover (it pivots towards the user). Then squeeze the tab on the cartridge to be replaced and lift it up. (Press towards the center of the cartridge.) Next take the new cartridge and shake it 5 times while in the package. Open the package and carefully (without touching the green chip) remove the yellow tape from the bottom of the cartridge. Insert the new cartridge into the appropriate slot and press down until it clicks. Repeat this for all cartridges that need to be replaced. Then close the ink cartridge cover and press down until it clicks as well. Lower the scanner unit. Then press OK to charge the ink system. This step will take about 2 minutes. Then press Menu to exit the menu system.
If you are replacing ink cartridges that are not empty. You need to enter the Menu and select Replace Ink Cartridges. (Press Copy/Fax then press Menu > select Maintenance and press OK > Select Ink Cartridge Replacement and press OK.)
I hope this helps.
Jul 02, 2011 | Office Equipment & Supplies
Sx415 I am unable to line up the printer head to
***hi there,il be willing to help you on that. ****
1. Turn on your Epson printer.
2. If a cartridge is expended, you see a message on the printer’s LCD display screen. The icon on the screen indicates which color to replace. Press Start (NX210 Series) or OK (NX410 Series).
***If you’re replacing a cartridge before you see a message on the printer’s LCD display screen, do one of the following:
NX210 Series: Hold down the Scan button as you press the Index Sheet button, then release the buttons. Press or to select Ink Cartridge Replacement, then press Start.
NX410 Series: Press Setup, press or to select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
3. Open the scanner. Do not open the ink cartridge cover while the print head is moving.
4. Open the cartridge cover.
5. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
6. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.)
7. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge.
8. Remove the yellow tape from the bottom of the cartridge.
Caution:
Do not remove any other labels or seals, or ink will leak.
9. Insert the new cartridge into the holder and push it down until it clicks into place.
10. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place.
11. Lower the scanner
12. Press Start (NX210 Series) or OK (NX410 Series) to begin charging the ink. This takes about 2 minutes.
When you see a completion message on the LCD display screen, ink charging is finished.
***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Feb 17, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Cannot regonize ink cartridges
An ink cartridge may be incorrectly installed. Follow these steps to make sure the cartridges are correctly installed:
1) Make sure the Epson Stylus is turned on.
Do one of the following:
  • If your printer indicates that an ink cartridge is expended, press OK.
  • If your printer does not indicate that any ink cartridge is expended, press Setup. Then press < or > to select Maintenance, and press OK. Then press A or V to select Change Ink Cartridge, and press OK.
2) Open the scanner.
3) Open the cartridge cover.
and wait until the cartridges have moved to the replacement position.
4) Press down all the ink cartridges until they click into place to make sure they are properly seated.
5) Close the cartridge cover and push it down until it clicks into place.
6) Close the scanner.
7) Press OK to begin charging the ink. This takes about 2 minutes.
8) You'll see a message on the LCD screen when ink charging is finished.
In many cases sometimes :
If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
Jan 23, 2010 | Epson Stylus NX400 InkJet Printer
How to change the ink of an epson stylus sx215
press the index sheet button and the scan button at the same time, you then get setup menu. use" >" to select "change ink cartidge". the ink cartidge will move to the opening position. lift the grey plastic clip at the back, and it will open towards you. then they just pull out
Jan 07, 2010 | Epson Stylus Multifunction Inkjet Printer/...
How do u change the ink in the epson 6000?
Things You'll Need:
  • Replacement cartridge (black, cyan, magenta, or yellow)
  1. Step 1 Turn on the printer and press the Color button.
  2. Step 2 Lift up the scanner and wait for the ink cartridge holder to move into position. Remove the ink cartridge holder's cover.
  3. Step 3 Push the tab at the back of the empty ink cartridge to free it from the cartridge holder. Lift the empty cartridge out and dispose of it.
  4. Step 4 Prepare the replacement cartridge by shaking it gently while still in its packaging. Remove the cartridge from its wrapper, taking care to hold it by the sides.
  5. Step 5 Insert the replacement cartridge into the appropriate slot of the ink cartridge holder. Push down on the replacement cartridge until it clicks into place.
  6. Step 6 Close the cartridge cover and lower the scanner until it clicks into place. The printer is now ready for operation
Nov 15, 2009 | Epson Stylus CX6600 All-In-One InkJet...
How do i change the black ink cartridge on a lexmark x2580 printer
With printer on and connected to computer do the following:
Open top cover.
Fix top cover on open position, using the plastic sustain part located on the right side inside the printer.
Wait for ink carriage for taking position in the middle of the printer rail.
Open cartridge top cover.
Pull cartridge toward yourself and snap it out.
Do the same in reverse order to fit new cartridge.
Remember to remove cello tape strip from new cartridge nozzle.
Do alignment procedure after replacement.
Sep 11, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
I HAVE NO INSTRUCTIONS FOR OPENING THE CARTRIDGE COVER ON MY EPSON rx595 PRINTER AND CHANGING THE CARTRIDGES.
Make sure you have a new ink cartridge before you begin. You must install new cartridges immediately after removing the old ones.
Follow the steps below to replace one or more ink cartridges that are expended:
  1. Turn on the printer.
  2. If a cartridge is low or expended, you see a message on the display screen. Note which cartridges need to be replaced and press OK.
  3. Open the scanner, then open the cartridge cover.
  4. Squeeze the tab on the cartridge and lift it up. Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
  5. Remove the cartridge from the package, but be careful not to touch the green chip on the edge.
  6. Remove the yellow tape from the bottom of the ink cartridge.
    Caution: Do not remove any other labels or seals, or ink will leak.
  7. Insert the new ink cartridge into the holder and push it down until it clicks into place.
  8. Once you replace all the cartridges that need replacing, close the cartridge cover and push it down until it clicks into place.
  9. Close the scanner.
  10. Press OK to begin charging the ink. This takes about 2 minutes. When you see a completion message on the display screen, ink charging is finished.
Caution: To conserve ink, never turn off the printer while ink is charging. If you see an ink replacement message on the display screen, press OK and press down all the cartridges securely
Jan 08, 2009 | Epson RX595 Photo All-In-One Printer
Ink cartridge problem
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Mar 18, 2008 | Lexmark X6150 All-In-One InkJet Printer
Epson Stylus CX5800F All-In-One InkJet Printer Logo
119 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
