Question about Pinnacle Studio Version 12 for PC
I have studio 12.1 and it is asking me to activate Dolby 2ch encoding decoding. What does this mean?
  • Pinnacle Master
  • 4,924 Answers
It means that you ask it to do a job ...I mean a task ...and it needs this codec to read files or save files in the format you desire...so ...if its an automatic download-install you may proceed ...but be careful if it ask for fees and you dont really need this feature...just cancel and abord...and use it for what you already done ...
Posted on Sep 16, 2009
Auto format decode means?
HI,
There are so many audo formats like Dolby Digital Decoding, Dolby Digital EX Decoding, Dolby Pro Logic Decoding, Dolby Pro Logic II, Dolby Pro Logic IIX Decoding, dts 96/24 Decoding, dts Decoding, dts NEO:6 Decoding and dts ES Decoding Stereo etc. What ever the AVR get a digital input It will decode the format and convert the same While it in the Auto format mode. If auto format is not selected it will convert the same in to stereo.
Ajin
Feb 09, 2012 | Audio Players & Recorders
Cannot get unlock code for dolby 2 ch encoding,decoding for pinnacle studio 14
You can get encoding unlock code for Dolby 2 ch from thisweb-link: http://www.serialportal.com/serial.php?im=57153. You candownload pinnacle studio 14 decoder from "http://www.giveawayoftheday.com/pinnacle+studio+14+decoder/".,if you face any problem then you canvisit http://www.pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Home+Video/Studio+Family/Studio+Plus+12+Ultimate+Support/Download+Area/Drivers+-+Updates/Studio12_1_3.htm?mode=documents&Display=1. Good Luck.Hope this will help you.
Jul 01, 2011 | Pinnacle Studio Ultimate 14 for PC
How do I get the C5 Subwoofer to activate?
Hello
If subwoofer is inactive now, the sound preference settings you set now is wrong.
Before using the remote control for the following
operation
* Set the remote control mode selector to AUDIO
** There are exceptions in the operation mentioned
above. In such a case, follow each instruction
Dolby Pro Logic II*1
# Dolby Pro Logic II has a newly developed multichannel playback
format to decode all 2 channel sources - stereo source and Dolby
Surround encoded source - into a 5.1 channel.
Dolby Pro Logic II has two modes - Movie mode and Music
mode
# Pro Logic II Movie (MOVIE)
Suitable for reproduction of Dolby Surround encoded sources
# Pro Logic II Music (MUSIC)
Suitable for reproduction of any 2 channel stereo music sources
# Dolby Digital*1
Used to reproduce multichannel soundtracks of the software
encoded with Dolby Digital
# DTS Digital Surround*2
encoded with DTS Digital Surround. DTS Digital Surround (DTS) is another discrete multichannel
digital audio format available on CD and DVD software
Jun 19, 2011 | JVC TH-C5 System
When playing a tape on the right side the drive will stop as if at the end of the tape. This is during playback, seems to be random and may happen several times. Also, What is the difference between...
First - your drive problem. Nearly all tape decks use belts to drive the various parts from a single motor. When belts get old, dirty, or worn, they slip. At some point, if the tape gets a bit "heavy" the belt doesn't have the torque to keep things moving. You can try cleaning the belt if you can get to it. Use some isopropyl alcohol and a lint free paper towel. This may only provide a temporary fix and a new belt may be needed. If you have one of the high-end direct drive units (rare in side by side decks) then the drive motor has an issue.
Ah Dolby. Where to start. To answer your question as asked, B and C refer to different "curves" used by the Dolby to reduce tape noise.B came first obviously. The real issue with ANY Dolby is that it is a 2 part system. A tape must be encoded with a Dolby unit for proper playback with Dolby. So, you would have to know that the tape was recorded with Dolby B and you would select Dolby B for playback. The Dolby will "appear" to reduce noise on any tape because it will roll off the high frequencies but the frequency response will be all messed up. To further complicate this mess, any Dolby circuit really needs to be properly calibrated to work 100% as intended. In consumer gear, this is nearly impossible so they settled for a close approximation. In pro studios, Dolby encoded tapes included set up tones at the front of the tape so the engineer doing the playback could align his system to the recording system. All that complexity is why DBX came along with their system but Dolby had good marketing and it was "close enough" that people liked the hiss reduction even when applied to a non-encoded tape. Of course, people tolerate MP3s for the convenience too.
Anyway, hope that helps. Look for the Dolby symbol on the recorded tape. If it is there, it will tell you if it is B or C curve - select accordingly. If not- it probably was not encoded and you'd have better frequency response using the "off" setting.
Oct 23, 2010 | Audio Players & Recorders
I cannot get sound from a sony BDS350 (Blue ray
This must be configuration problem on the BD player. In this case receiver just outputs the signal it receives digitally. If it displayes PCM 2ch, that means it receives only 2 channel audio from BD player.
You can try to configure the BD player not to decode audio and to output the RAW stream over coax cable to the receiver. Then the receiver should get raw Dolby Digital encoded data and be able to decode it into 5.1 channels. It should also display Dolby D instead of PCM in such case.
Feb 11, 2010 | Sony Audio Players & Recorders
Why is the lap top telling me i need a decoder to watch a movie
DVDs are one of the most popular types of media sold today. They hold feature length motion pictures, videos, audio and countless other types of media such as software and data. DVD's not only can be played in stand alone DVD players, but also most computers have a DVD drive. If a DVD includes media such as a feature length motion picture, this media has been encoded and sometimes compressed. In order for this type of DVD to be played on a computer's DVD drive, the data on the DVD must first be decoded; this is done with computer software which are know as Decoder. It should be noted that there are many types of DVD formats, hence several types of encoder programs to make a DVD accessible to computer users.
DVD's encode data in a variety of ways. For instance Dolby Digital data requires a Dolby Digital decoder. The same is true with DTS (Digital Theater System). These are both audio data that require decoding, but many video images stored on a DVD also require decoding including
MPEG (this is the most popular video format for DVD's). It should be noted that in order to play a standard DVD, the DVD player is not enough, you also need the software to decode the images making the data fully functional.
Hope this Explanation will help you,,,,,,
Cheers!!!!!
Vivek
Dec 15, 2009 | Compaq Armada M700 Notebook
Will not save to dvd after appearing to render after several hrs
u shoul use dvd+r on pinnacle it works the best, un install the program, run a registry repair program to remove any old pinnacle stuff still installed then reinstall, make sure you have all the newest drivers for you hardware, and windows updates, dont install any codecs until you tried the program, exp, dont instal dvix or any other program that u use to whatch pirate movies with, it should work
Oct 08, 2009 | Pinnacle Systems Targa 2000 RTX - Video...
How to play dts/dolby digital on HK AVR5
I believe he avr-5 has 6 channel inputs, what you will need is a dolby digital 5.1 and DTS outboard surround sound processor, say an item as the Technics SH-AC500 decoder, a Harman Kardon Signature 2.1 DTS version outboard processor/preamp, and many others on the market by different manufactors, Run the discrete audio outputs from the Processor into the AVR 5`s 6 channel inputs, select 6 channel input or DVD inputs on the receivers selector and your good to go. Be sure you are playing Dolby Digital 5.1 or DTS encoded material.
Feb 08, 2009 | Harman Kardon AVR 100
Pinnacle Studio Version 12 for PC  Logo
1,817 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
