Question about LG KG300 Cellular Phone
My set gets swiched off when working on it - LG KG300 Cellular Phone
  • Fred Masson
    Fred Masson May 11, 2010
    Do u mean wen u acces menus?
  • 39 Answers
These are the symptoms of the virus in ur cell phone........format it .......also format the memory card........hope it ll work
Posted on Sep 13, 2009
What causes the break light swich to push, ive took apart the swich and can push it and break lights worked but when i put swich back on with clip it dose not work when i hit the break peddel
nothing, It doesn't work like that, when your brake switch is mounted , correctly , your pedal has a bracket on it that pushes the switch plunger in so brake lights are off. when you push brake pedal in, to stop vehicle, the switch plunger (spring loaded) comes out to turn brake lights ON ! get it ? when you release pedal it pushes plunger in, to turn lights OFF !
Jan 15, 2013 | 1997 GMC Sierra
On/off button not working
k9 on off problam..........plz help me
Jun 06, 2012 | Karbonn K9
95 chevy suburban- brake lights not working (turn signals work and regular lights). checked the bulbs and whatnot- cannot find the problem. someone please help!
There are a couple of types of switches but lets assume you have a more common one. It will be located on the left side of the brake pedal shaft it is black with 4 wires in one connector and a seperate 2 wire connector above the 4 wire connector. The switch is easily removed if it is this style by pulling it down it has 2 clips one at the top and one that slides over the pedal shat the back of the switch has a rased hump tha slides into a recess on the upper pedal support bracket.Grab switch pull down and gently wiggle it if necessary.Remove 4 wire connector and 2 wire connector. Now you are holding the old switch and yor troubles have just started the after market replacement switches really **** get a real gm swich.If you look at the old swich at its bottom you will see a little foot sticking out of the base of the swich once the new swich is installed you must use the little foot to adjust the swich.If you do this wrong you will do dammage to your transmission.The two wires at the top of the swich go to the transmission torque converter clutch.when the brake lights are on the upper swich is off. When brake lights are off the swich will be on.Get new swich installed using this info and get a pro to help you adjust it.It should cost you only 35 bucks to get it set.Dealer shouldnt charge more than 30 bucks for switch.
Good luck and thank you for using Fixya
Mar 15, 2010 | 1995 Chevrolet Suburban
My sigmatel s4 has dead. i have activated hispeed sim on it. how can i get back to normal working condition?
Try to swich it on buy taking simcard out & then goto settings & select RESTORE/ORIGINAL setting give security code & its done
Feb 21, 2010 | Lands Phones
I want the setup software that runs the phone for k 750i
Try doing a master reset or back to factory settings. It would delete all the data so take a back up. If it does not work, it has to be a hardware failure, get the phone serviced.
Jan 27, 2009 | Sony Ericsson K750i Cellular Phone
My 87 camry wont star i think is my swich
Have a local mechanic check the main power relay. This feed power from the ignition switch out to the stated accessories
Dec 16, 2008 | 1987 Toyota Camry
My monitor is set on the default settings and I can't get it off and I don't have the disk anymore
i need some more details about that
that u mean it's swich not work? or it's not shut automaticaly ?
Jul 28, 2008 | Computers & Internet
Flashing lights
the printer when i on the swich the flashing light is on but can't work the printer
Feb 24, 2008 | Epson STYLUS CX3900 All-In-One InkJet...
LG KG300 Cellular Phone Logo
18 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
