Question about APC Back-UPS 400EI (BK400EI) UPS System
Inverter 12V to 230v not working
I have an APC ups 400 EI and I've found the 5A link blown on the battery negative and the all four mosfet transistors with a nearly zero resistance between drain and source - I 've done the measurements with the transformer disconnected from the PCB.
I can't get a schematic to fix this Ups.
Could you please help me.
Thanks,
Adrian.
    Novelist:
  • 169 Answers
Could be the devices, the inverter, the up converter,or the micro.
Throw it away and buy a new one, as this will be cheaper and easier.
UPS devices are very complicated with lots of related circuits logic etc.
These units are not made to last, recover the batteries or recyle the whole thing.
Posted on Sep 21, 2009
How do i connect 4 batteries in series
Here is the way to hook them up in series, or in parallel.
There are 3 batteries in top (series) pic, but a 4th would be added in same wiring manner. Disregard the letters "ve" in diagrams, but the +/- polarity is vitally important in hookup.
Note that four 12v batteries hooked up in series will be 48 volts at the end terminals. (If all four are hooked up in "parallel" then the total would still be 12 volts).
If you want to supply a 12v inverter, you need to hook 12v batteries in PARALLEL.
Nov 01, 2014 | Cobra 2500w Power Inverter
How can output voltage be adjusted when on battery power?
1. check either it is overloaded or the batteries are weak . check battery voltage to
May 10, 2014 | APC 620VA/390W Input 230V/Output 230V...
I have APC RS 600, 360W battery which is not working that means O/P voltage 230V is nill there is no Output supply . I checked the ckt but when switch on the ups it will start alarm and even i check the...
Hi Datta,
It seems that you have the wrong battery in that UPS. The replacement battery for that unit should be an RBC2 -or- a 12v 7.5ah battery ($28 delivered). The UPS will not work without the correct battery in place.
If you could provide me with the exact model number I may be able assist you further.
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
** If this helped - Give it a Thumbs Up :) **
Dec 13, 2013 | APC Back-UPS 600VA UPS System
My ups is overloaded for first time. can it be fixed
yes it can be fix. try to open your UPS and see if power mosfet are blown, replace the power mosfet and check other component around it. or you can bring it to any authorized APC service center
Mar 20, 2012 | APC Back-UPS XS900 (BX900) UPS System
I have a APC BX900R. i HAVE REPLACED THE
Your UPS is having an internal problem, it should be an inverter problem. if you know how to troubleshoot up to component level try to open the UPS and check the power mosfets. if not bring your UPS to the service center.
Aug 12, 2009 | APC BACK-UPS 900VA (BR900) UPS System
Overload light in APC RS 800 UPS
it seems that the inverter circuit of your UPS is dying. the solution here is you have to open up the UPS and check the inverter circuit. to make easier, check the power mosfet if its leaking.
Jun 11, 2009 | APC (br800) UPS System
APC Smart UPS 3000VA - Dead UPS When I plug in the unit nothing happens no lights, no noise - nothing! Is there a replaceable fuse in these units? Cheers
ok how long you brought the ups and how long you had not start the the ups usaully ups is power dead change the battery and try to power up it should work be sure that all connection is connect properly before power up the ups.. if the ups doest work that will be the mainboard problem you hav to call for vedor to repair the unit.. yes these fuse for the ups but it unlikely to be blown so should worry of the fuse it self.. change of battery come with different spefc for the ups.. eg su3000rmi3u, sua3000rmi3u, su3000rmxl3u --- battery replacement is 8 pcs of 12v 7ah. sua3000rmi2u-- 6 pcs of 12v 7ah or 8 pcs 12v 5ah. su3000rminet-- 4 pcs 12v 17ah,
Sep 03, 2008 | APC Smart 3000VA (sua3000r2x145) UPS...
APC Smart-UPS RT 1000VA
Hello Dear Specialists I have a problem with the APC Smart-UPS smart 1000VA: when I insert the
power plug in the wall outlet in one ups , indicate the AVR Boost ups regulating low AC voltage, when I measuring the AC city power voltage that is 207v .whey this ups is not working about the AC low voltage? ,but it should be work from (170v ~ 230v) AC input volte.please solve this problem, which element of AVR from the ups is failed or wrong and give me free circuit diagram low & high AVR and charger and inverter circuits. thanks allot
Aug 20, 2008 | APC Smart-UPS 1000VA UPS System
APC Back-UPS 400EI (BK400EI) UPS System Logo
186 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
