Question about CyberLink Power DVD 5.0 (cd-powerdvd5) for PC
Powercinema 6 doesn't allow me to set-up, please help
I installed a downloaded powercinema 6 with activation key, but while i tryed to set-up it exit before it start to scan TV chanels
  • Peter Dragonetti May 11, 2010
    have you try to reinstall the software ??
  • 77 Answers
You should use Total uninstaller and it and reinstall it again
if this doesn't change any thing then you may have to reinstall the windows again
For all of these you must sure that there is no problem with the internet
Posted on Sep 14, 2009
Tip
Vista Web Browsing Speed Up
Internet Explorer 7 only allows you to download two files from the same server at a time. This is not a software limit but rather a limit imposed based on the web standard. Since this is simply a software setting, it can be modified and you can increase the limit to something much high such as 10.
1. Click the Start button, type regedit in the Search box, and then press Enter.
2. After Registry Editor loads, navigate through HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings.
3. Right-click in an open space and create a new DWORD key.
4. Type MaxConnectionsPerServer as the name of the new DWORD key.
5. Right-click this key and select Modify.
6. Set the base to Decimal and enter a value greater than 2, a.Like to use 15 as my value here. Press OK when you are done.
7. Create a new DWORD key and type MaxConnectionsPer1_0Server as the name.
8. Right-click this key and select Modify.
Set the base to Decimal and enter the new value. Use the same value as used in step 6. Click OK when you are finished.
9. Exit Registry Editor and reboot your computer
10. After your computer has rebooted, your new Internet Explorer settings are active.
BY GUNJAN SARKAR
on Feb 07, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
HOW DO YOU MOVE THE ARROW KEY ONCE YOU ARE IN THE MENU?
You use the button with the <> arrows to move through the menu selections. Use the menu key to select the function you want to change.
Below is an excerpt from the Acer manual. The manual can be found at http://www.retrevo.com/support/Acer-X203H-Monitors-manual/id/23224bh549/t/2/
Front Panel Controls
1.Power Switch:
To turn ON or OFF the power.
2.Power LED:
Lights up to indicate the power is turned ON.
3.Empowering / Exit:
1) When OSD menu is in active status, this button will act as EXIT-KEY(EXIT
OSD menu).
2) When OSD menu is in off status, press this button to select scenario
mode.
4.Auto Adjust button / Exit:
1)When OSD menu is in active status, this button will act as EXIT-KEY (EXIT
OSD menu).
2)When OSD menu is in off status, press this button for 2 seconds to
activate the AutoAdjustment function.The Auto Adjustment function is
used to set the HPos, VPos, Clock and Focus.
5.< / >
Press < or > to select the desired function.Press < or > to change the
settings of the current function.
6.MENU / ENTER:
Activate OSD menu when OSD is OFF or activate/de-activate adjustment
function when OSD is ON.
Jul 02, 2011 | Acer X203H bd Monitor
How Am I going to Activate My Windows Vista
Hi, If you have original product key.You enter thr product key when prompted.If you don't have original operating system, then follow the below steps. 1)go to www.bittorrent.com 2)download the bit torrent software (<3mb size) and install it. 3)Go to the below link. http://thepiratebay.org/torrent/3631799/Vista.All.x86.OneClick.Activator.4st.March-CLoNY 4)Click "download this torrent " link which will be in green colour. 5)open the downloaded torrent file and it will prompt to download the"clonysoft windows vista one click activator".Give ok 6)extract the downloaded file and run the software.Your windows will be activated. 7)if your download link is slow try searching in google as "clonysoft windows vista one click activator"
Nov 25, 2010 | Computers & Internet
I have starview but doesn work could someone help me here please?
Press menu/factory settings enter 0000 as password OK. select language/installation select network (< or > key)/ automatic scan. This will take about 10 mins wait for saving and exit to blank screen and press menu again. Enter 1570 on remote and scroll down to key EMU and turn on (< & > keys again). Exit out and select Sky Sports1 wait for update. When channel comes on all channels are availabe. You will need to redo favourites. If you need help on that then add comment to this psot.
Oct 05, 2009 | StarTech.com StarView SV211K 2-port KVM...
Cannot install java on samsung i640
Im very sorry Dude
  • It is NOT officially possible to install java MIDlets on samsung handsets (excluding smartphones) via bluetooth, IrDa, USB cable or serial cable. MIDlets can only be downloaded by Over-The-Air (OTA) via a download server
  • There is currently no method for installing MIDlets on other platforms other than by OTA/GPRS via a download server.
BUT THERE ARE SOME UNOFFICIAL METHOD PLEASE TRY THIS BUT RISK IS WITH U.
Install JAVA games on your Samsung via a USB cable, BT or even an IR port
The method here is rather straightforward. It has been tested on my two D500 phones without a single problem biggrin.gif
1. Download and install Softick PPP from here. The software is designed for Palm users, so if you receive any error messages such as unable to locate USBPORT.dll, just ignore them.
2. Active your IR connection or hook your USB cable into the phone.
For IR users, you need to active the IR connection on both of your laptop and D500, and approach the laptop with your D500 to let it find the phone prior to any transferring.
For USB connection, the one I tested is from fonefunshop
3. Start Softick PPP, and check if it has your connection in its 'Settings->Bluetooth/Serial'. Active it if done.
4. Run 'Uploader.exe' program and add a jad file.
5. Enable Serial Java download - #*536963#.
6. Enter Serial Java menu #*5737425#, and choose USB from "1 PPP UP'. Please bear in mind, just do it once for each switch on/off!
Select second option - "2.Serial Download"
7. Let upload and softick PPP access the net if you installed a firewall.
-More details--------------------------------------------------------
If you are using a USB cable, please take the following steps:
1. deactive Softick PPP, and exit it.
2. connect the cable,
3. run Samsung's PIM & File Manager to make sure that you get connected. If not, please switch off and on your mobile and try it again.
4. run Softick PPP
5. go to it's 'Settings->Bluetooth/Serial' to check if it has a connection such as COM7 Devicess_mdm0. If so, select it, otherwise exit the Softick PPP and go back to the first step. (you may find the proper COM setting from the windows device manager->modems->Samsung Mobile USB modem)
6. active Softick PPP.
7. run Uploader.exe
8. ......
For IR users,
2. active your IR connection。
3. approach your phone to the laptop, and make sure there displays an icon in your tray area and it gives a message 'there is a device around....'
4. run Samsung's PIM & File Manager to make sure that you get connected via IR. If not, please switch off and on your mobile and try it again.
5. run Softick PPP.
6. enable IRDA interface support in 'Settings->Options'
7. go to it's 'Settings->Bluetooth/Serial' to check if it includes a connection such as 'COM4 Device
Jun 26, 2009 | Samsung SGH-i640 Cellular Phone
Print in light
1. Check TONER SAVE setting. If this setting is programmed "ON", all
printed documents will be light.
a. Press MENU/SET, 1 (General Setup), then 6 (Toner Save).
b. Press the top or bottom navigation key (keys located above and below
the MENU/SET key) until the display reads "Toner Save: OFF".
c. Press MENU/SET.
d. Press STOP/EXIT.
2. Check the PRINT DENSITY setting. This setting allows you to adjust
the print density from light to dark.
a. Press MENU/SET, 2 (Fax), 1 (Setup Receive), then 6 (Print Density).
b. Press the up navigation key (key above MENU/SET) to make print
darkeror the down navigation key (key below MENU/SET) to make print
lighter.
c. Press MENU/SET.
d. Press STOP/EXIT.
Oct 15, 2008 | Brother IntelliFAX 2800 Laser Fax
JVC Everio GZ-MG145 backup on mac - files are .mod
The software iVerio might help you. It transfers and converts automatically all your videos from your HDD camcorder.
Have a look on the site http://www.convertmod.com
Feb 21, 2008 | JVC Everio G Camcorder
CyberLink Power DVD 5.0 (cd-powerdvd5) for PC Logo
283 people viewed this question
Top CyberLink Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
Are you a CyberLink Computer and Internet Expert? Answer questions, earn points and help others
