Question about Amana ABB1927DE Bottom Freezer Refrigerator
Refrigerator stopped working, only fan works - Amana ABB1927DE Bottom Freezer Refrigerator
  • shir114 Sep 17, 2009
    It turned out that an electricity surge caused an electric part to burn out. It was a minor repair and I now installed a surge protector.
  • Amana Master
  • 3,287 Answers
Three scenarios come to mind.. 1) The compressor may be "done" or 2) the refrigerant has leaked out. Either way, not good news. But, it may also be 3) a "stuck" defrost timer. These are simple little clock motors that that run whenever the freezer coil is below a certain temperature. After 8 - 12 hours at a low temperature, the power is switched away from the thermostat and directed to a defrost coil located in the freezer coil compartment (usually protected behind a panel in the back of the freezer). When powered, it allows the heater to melt frost off of the coil and collect in the drip pan under the fridge. If the defrost circuit didn't run, the coil would quickly clog with ice and no cooling would occur - but the compressor would run until the defrost timer kicked in again. The timer is not heavy duty - and could be stuck in the defrost setting - preventing the compressor from running. You could press your hand against the back of the freezer and feel for heat - if found, that is likely your problem. It is also possible that the heating element has failed too, in which case no heat would be felt. Replacing the defective parts isn't brain surgery - but maybe more than a DIY project due to hazardous voltage levels (120VAC) and possible exposure to freon if the coil were to become damaged.
Posted on Sep 16, 2009
  • Steve Sep 21, 2009
    Glad to hear it. I thought some more about it to - it could also have been the defrost terminator. It's a little button-like clip that attaches to the refrigerant line in the freezer compartment - sensing the temperature of the line. I wonder, was that it?
2 Suggested Answers
woodchuck789
  • 4066 Answers
SOURCE: kenmore refrigerator stop cooling but fan working
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Posted on Apr 06, 2010
Fridges stops working randomly but the freezer works. Then the fridge starts working after a couple of days
When the fridge stops working, can you hear the fan operating inside the unit? It sounds like you have a failing evaporator fan motor. This fan motor circulated cold air from the freezer to the refrigerator.
Apr 19, 2015 | Refrigerators
My fan as stopped working on my whirlpool fridge 6th sense .
Make sure something isn't blocking the blade. New refrigerators have ac/dc fan motors and they can just stop. It may just need a new fan motor.
Oct 05, 2014 | Whirlpool Refrigerators
Fan turns off in refrigerator section.
Its issue with defrost timer causing the fan to turn OFF.
Get the timer checked.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
2005 Maytag Refrigerator Fan Stopped WOrking
What is the model number and is the compressor kicking on?
Oct 28, 2012 | Maytag Refrigerators
Honeywell compact refrigerator model # 88031not cooling.
Honeywell compact refrigerator model # 88031 making a clicking noise, not cooling, interior light blinks, and the fans in back are not working properly....seems as if it's not getting full power. worked fine for about a year and justed stopped.
Mar 18, 2010 | Refrigerators
MODEL BG2OTW, FREEZER IS WORKING BUT THE UPPER SECTION IS NOT COOLING
This is a common question here.... The most common solutions are that either the fan has stopped working or the defrost is not working and the ice build up stops the fan.
First unplug the refrigerator for 12 hours or so to see if there is ice build up that is stopping the fan. If the fan works when you plug it back in then find out why the ice is building up. Ususally it is because the defrost timer has gone bad.
If the fan still does not work then most likely the fan has gone bad. You will need to replace the fan.
The fan blows a portion of the cold air from the freezer side. If the air is not forced oover to the refrigerator side. the freezer is great but the refrigerator is warm.
Hope this helps you understand what is happening and ultimately solves your problem for you!!
Heatman101
Nov 21, 2009 | Refrigerators
My Mabe fridge stopped working. The fan in the
Your fix will likely involve replacing the fan motor. Until this is done, the freezer side will probably be okay; but very little cold air will be transferred over to the refrigerator side. The temperature in the refrigerator will likely get much too high.
Hopefully, there is an access panel where you can get to the fan. If so, it is not difficult to replace. The motor should be readily available at the appliance parts stores that do internet sales.
Oct 11, 2009 | Frigidaire FRS23KF7AB Side by Side...
Refrigerator stop cooling
THIS DOESN"T SAY WHICH FAN IS WORKING IF THE FREEZER FAN STOPS WORKING THE FRIGE WILL NOT GET COLD.
DOES FREEZER STILL FREEZE?. IF SO ITS YOUR FAN
Aug 28, 2009 | Admiral 26 cu. ft. Side-By-Side...
Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works Refrigerator will not cool down
The compressor should be OK this time because you caught it in time. But if the condenser fan stops you need to consider replacing the fan. I have had refrigerators do fine until the fan motor warms up and you are away, it stops. Don't think you should use the refrigerator until the fan is fixed. Sea Breeze
Apr 22, 2009 | Kenmore Refrigerators
Amana ABB1927DE Bottom Freezer Refrigerator Logo
152 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
