Question about Mr Steam Mr. Steam Commercial Steambath System - CU-2500C3
Steam Shower shuts down immediately now.
For awhile now after turning on the steam, you could hear it fill with water and begin to heat, but then shut off. After doing this about 3-4 times it would stay on and produce steam. However, now it shuts off immeditely; it doesn't sould like its even begining to heat the water; it will not produce steam no matter how many times you press the on button. Still you can hear it start, but then it shuts down immediately.
  • 143 Answers
Probably scale build up from tap water unfiltered. Scale caused by mineral deposits will affect safety systems and auto cut offs in the unit
Posted on Sep 13, 2009
Commercial espresso machine
Sounds like the safety thermostats on the machine is tripping because the machine is overheating or the circuit breaker is tripping because machine needs more amperage.
Nov 14, 2012 | La Marzocco Coffee Makers & Espresso...
I have the Mr Steam MS Super 1 T steam unit with the Tempo Plus accessories and auto flush. The unit has worked great for about 2 years but for some reason yesterday the unit light comes on at the...
You would need a multi-meter or voltmeter to trace the power path. Turn on the generator and wait until you hear the water feed solenoid stop. This means the water has reached the satisfied level and the pc board should have sent 24v to engage the contactor. On the actual pc board there is a section label "cont" which is what sends the 24v to the contactor the engage the heating element. Verify that you have 24v on the spade terminals going out to the contactor, if not then you may have a pc board issue. Second possibility is the contactor, if it is recieving 24v and it is not engaging then it's simply a bad contactor. Check the load side of the contactors with the blue wires. Lastly if these two steps check ok, then perform an ohm reading with a multimeter on the actual heating element(with the power off, put your two test leads on the two flathead screws that hold down the blue leads the go to the heating element). If you get an open reading then this may indicate a failed heating element. Pulling the heating element out on the left side panel will confirm any element failure.
Nov 08, 2012 | Mr Steam Ms Super 1e Steam Shower...
Maax steam shower
To get replacement parts for Maax steam shower, you can prefer showerenclosures.
Nov 13, 2011 | Home
Clean iron?
Hello tcant....
  • 1 Fill the iron's steam receptacle with white vinegar or CLR, a product used to clean coffee pots. CLR is available in department stores.
  • 2 Plug in and set the iron to its steam setting.
  • 3 Operate as usual. When the vinegar or CLR begins to steam, operate the iron as you would normally. Press it over an old, clean towel as the vinegar or CLR loosens sediment and dirt from the appliance.
  • 4 Continue ironing until all of the cleaning solution has steamed out. Repeat the cleaning process if necessary until the iron no longer oozes discolored liquid and the ironing surface is clean.
  • 5 Fill the iron steamer receptacle with distilled water and set the appliance to steam.
  • 6 Continue steaming until the smell of vinegar or CLR is gone.
  • 7 Prevent future mineral buildup by using distilled water for steam in your iron, rather than tap water. Joe. Thanks for choosing Fixya!
  • Jan 12, 2011 | Black & Decker ICR250 Iron with Auto...
    My SM11 model Steamist was installed above our shower/steam room. It is 2 years old. While in use recently, it made a loud sound like a low-pitch popping sound or low boom. Imagine somebody inside a...
    The heating elements had burned up in the unit therefor creating a dead short on that circuit. Main breakers on homes and buildings are VERY sensitive and will sometimes trip before the smaller branch cicuit breakers will . So the popping you heard was the heating elements breaking down inside the unit it can be some what noisy.
    Nov 03, 2010 | Steamist 1100 Sm11 Large Capacity Steam...
    Saeco Magic Comfort Plus still producing steam in "off" position.
    This may be something you can fix. It depends on your comfort level with mechanical repairs. You probably need to replace some o-rings in the steam valve. Don't keep trying to brew or steam because leaking water or steam inside may cause an electrical short. Decide if you want to delve into the repair, or locate a repair center near you. I could put you in touch with some.
    Mar 18, 2009 | Saeco Magic Comfort Plus Espresso Machine
    Steam won't shut off
    I have portable steam sharrk, had same problem. I filled it with water and now works fine, water level might be to low
    Jan 07, 2009 | Kenmore Euro-Pro Ultra Steam Shark II Hard...
    Descaling
    (Button 26 is the right-most one (2 intersecting
    ovals.)
    From the Manual:
    Press the button (26) for at least 5 seconds to
    select the descaling operating mode; the LED
    emits a fixed light.
    • Direct the steam nozzle (14) toward the drip
    tray.
    • Position a vessel of adequate capacity under
    the steam nozzle and turn the hot water knob
    anticlockwise (16). The appliance starts an
    automatic descaling cycle with pauses preset
    by the manufacturer and managed
    automatically by the appliance.
    • At the end of the cycle, the flow of the
    descaling solution is shut off and the 5 buttons
    start flashing simultaneously.
    • Turn the knob of the hot water nozzle (16)
    clockwise to OFF. In this case, also the warning
    light (27) flashes.
    • Rinse the water tank and fill it with fresh
    drinking water.
    the steam nozzle and empty 2/3 of the
    contents of the water tank by turning the steam
    knob (16) anticlockwise; to shut off the flow,
    turn the knob (16) clockwise.
    • Let the appliance heat up and empty the
    remaining contents of the water tank by turning
    the steam knob (16) anticlockwise; to stop the
    flow, turn it clockwise.
    HTH
    dave
    Aug 14, 2008 | Gaggia Syncrony Compact Coffee...
    Steamer
    Both tubes must be in the water. If you haven't used the machine for awhile, fill the water canister, turn the espresso maker on and also turn on the delivery switch (the top switch on the EC140). You'll hear the pump and in a second or two water will begin to exit the boiler nozzle. Immediately turn the delivery switch off. Wait for the "OK" light to come on. Press the "Steam" switch (the middle switch on the EC140, place an empty cup under the frother and turn the steam control knob on top in the counterclockwise direction. Steam will come from the frother. Be very careful to avoid contact with this steam.
    Apr 23, 2008 | DeLonghi EC140 Espresso Machine
    Gaggia espresso machine won't percolate
    Does the steam outlet give water when coffee swith is engaged. If so when you get a flow going, shut the steam valve and water should eventually pout in the cup. If no water pours thru the steam pipe, it's pump failure or blocked wand. If no water at shower depending on last result same problems. Search web for solution i.e. google "jammed espresso machine"
    Aug 30, 2007 | Gaggia Classic Brushed Stainless Steel...
    Mr Steam Mr. Steam Commercial Steambath System - CU-2500C3 Logo
    562 people viewed this question
    Top Mr Steam Electrical Supplies Experts
    BJ Russell
    Hippy_dd
    Are you a Mr Steam Electrical Supply Expert? Answer questions, earn points and help others
