Question about Canon Rebel XT / EOS 350D Digital Camera
Cannon EOS file curruption
I have experienced the same problem with my 20D, and it IS NOT the CF card. Removing the CF card from the camera and downloading the images through a card reader eliminates the problem. I suspect that the problem is caused by a bad connection between the mini-USB connector of the camera and the mini-USB plug.
    Brigadier General:
  • 4,090 Answers
Check that all the pins in the USB cable are straight and not bent. You will need a torch and possibly a magnifying glass to see this, also check the camera side to see there is no occlusion of the connectors. Check the PC end of the plug for the same. You dont have to have a a CANON Usb cable just buy one that fits, most Tandy stores or similar can help you there just take your camera with you for the fit
Please rate our help to keep the FREE service online++++Thank you for using FIXYA
Posted on Sep 13, 2009
Canon eos 20d error 99
1.Remove the battery, lens and CF card. Allow the camera to sit without power for 20 minutes and then reinsert a fully charged battery.
2.Turn the camera on and push the shutter button as if you were taking a picture.
3. If you don't get the error message reattach the lens and insert the CF card.
4. Check the below canon eos 20d service manual link:
http://goo.gl/YtVLQR
it will help you to save a lot of money
Hope it helps, Thanks
Aug 07, 2011 | Canon EOS-20D Digital Camera
Canon 20D. Says "Err
Error 99 is a result of an electronic communication problem normally between the lens and the camera body.
Use a red pencil eraser to "polish" the contacts even if they look clean do it again.
Take care to keep dirt out of the camera and lens bodies.
Another thing is often times the camera firmware needs to be updated to move on from this.
Another thing is the CF cards? The 20D was in an era where pretty well the larges CF card was a 2gig,I use several 1gig however if you have updated your cards to say an 8gig the firmware just can't handle the card.
Okay moving on clean the lens and body, update firmware, make sure the CF card isn't beyond the camera capabilities and last if all that stuff didn't work the it's possible the actual sensor is really dirty and needs cleaning.
The worst case scenario is that the shutter has failed. The Canon 20D is only good for 60,000 actuation's.
Hope this give you a few options
Apr 29, 2011 | Canon EOS-20D Body only Digital Camera
I have a canon eos 20D and the camera don`t accept 2, 4, 8 GB CF i download the last actualization and the problam is the same can you help me with this problam thanks
I have a Canon 20D in my fleet and have used 1 gig card in it almost exclusively however I did use a 2gig and a 4gig when shooting RAW + jpg. I would think that you haven't formatted the card for the camera even if it's a new card and has never been used you need to format the card to the camera you are going to use it in.
Jul 09, 2009 | Canon EOS-20D Body only Digital Camera
Canon eos 20d giving false error message
CF means that it can't read the compact flash socket on the side. I had a similar problem on one of my bodies. I would try either a different (new or one that hasn't been in the body) with a freshly charged battery. If this doesn't help, you can only send it in for diagnostics and repair
Jan 05, 2009 | Canon EOS-20D Digital Camera
Camera won't turn on
Does the camera do this with any CF card? If you've tried another CF card with the same problem, check in the slot that the CF card fits into with a strong light to make sure no pins are bent and touching each other.
Also, was the card formatted with a Windows 2000 or Windows XP system? If you format with Windows, make sure you specify FAT32 as the file system (rather than NTFS).
Err 99 is a 'catch-all' error message that is non-specific. It indicates that the camera detects an error within its operating system, but cannot determine the specific reason.
In summary, try another card. If you get the same error, and no pins are bent, you probably need to have the camera serviced.
Aug 31, 2008 | Canon EOS-20D Digital Camera
CF FULL
I just had exactly the same problem with my 20D. I removed and reinserted the battery and it fixed the problem.
Dave
Dec 08, 2007 | Canon Digital Rebel / EOS-300D Digital...
CF card problem
Perform the following procedures if your camera does not detect a CF card. 1. Restart your camera. - Set the camera's power switch to and remove the batteries. - Open the CF card slot cover to make sure the CF card is securely set in the card slot. - Insert the batteries and turn the power switch . 2. Format a CF card. Format the CF card with your camera. Refer to the Camera User Guide supplied with your camera for instructions on formatting your card. 3. Check if your camera detects other CF cards (If you own multiple CF cards.) If your camera does not detect a CF card after performing the procedures 1 and 2 above, the card that wasn't detected may have a defect.
Aug 29, 2005 | Canon EOS-20D Digital Camera with 17-85mm...
Canon Rebel XT / EOS 350D Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
