Question about Sentry Fireproof Safe
I need a battery holder (for 4aa batterys) for my s0500 fire safe. how much and how do i order
    Brigadier General:
  • 4,090 Answers
Most electrical stores carry these at around $2.00
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Posted on Sep 13, 2009
Customercare
A1 Locksmith Burlingame CA 94010 have new Sentry safe locks, keys, battery holders, battery door covers, and door handles. We are parting out some freight damaged sentry fireproof safes. But only a small supply in stock.
Nov 15, 2013 | Sentry Home Security
My canon 580 EX II stops firing even with new batteries
You must disable the 580EX II form using the 4AA.
4AA must be needed when using hv power pack.
Just let the 4AA use & display the LCD panel.
More help, repairs & troubleshooting send me an email.
atdlee@netzero,com
Oct 21, 2012 | Canon Speedlite 580EX II TTL Flash
Repair my sentry safe
A1 Locksmith Burlingame CA 94010 have Sentry safe locks, keys, battery holders, battery door covers, and door handles. But only a small supply in stock.
Jun 08, 2012 | Sentry Fire Safe - Safe - DS0200
I put in my combintaion, the batteries are good, the lock shows unlocked, but the handle will not move
I would say try replacing the battery holder. A1 Locksmith Burlingame CA 94010 have Sentry safe locks, keys, battery holders, battery door covers, and door handles. New parts reclaimed from damaged freight returns. But only a small supply in stock.
Feb 26, 2012 | Sentry Safe Fire-Safe OA5865 Electronic...
I have the didgital S0500 and can't find the instruction booklet. How can I change the entry code and where do I replace the battery Is it possible to get another booklet Thanx
http://www.sentrysafe.com/CustomerCare/Product_Manuals
Go to this link and put in the product information and it will give you a pdf of the user manual.
Mar 14, 2011 | Sentry Safe Fire-Safe Personal Safe
I need rechargeaable battery for wireless sony stereo headphones mdr-rf860r
Since many Sony headsets use the BP-HP550-11 battery pack, I assume your battery pack is the same. If not, I assume whatever battery pack your headset came with, it is some type of plastic holder that holds two batteries together. Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make them work in the Sony headset you MUST use the bottom part of the plastic battery holder piece (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism to enable the cradle charger to charge the batteries.
NOTE: I am not an electronics expert so I do not know if there would be any problem using other rechargeable AAA batteries (with higher mAh ratings). So I decided to be safe than sorry and ordered the 550 mAh batteries through Ebay.
Nov 19, 2010 | Sony MDR-RF960RK Consumer Headset
When I key in the pin it says to proceed but the bolt wont open. do I have to change the batteries? If so, how do I change it? My safe is a fire safe S0607
Locksmith advice on how to install sentry safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Aug 10, 2010 | Sentry Fireproof Safe
Sony batteries BP-HP550
Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make the charging cradle work with the new batteries in the Sony headset you MUST use the bottom part of the plastic battery holder piece (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism to enable the cradle charger to charge the batteries.
Jul 27, 2010 | Sony MDR-RF960RK Consumer Headset
Where can i buy a sony battery bp-hp550 1 1/2 4v
Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make the charging cradle work with the new batteries installed in the Sony headset you MUST use the bottom part of the plastic battery holder piece (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism to enable the cradle charger to charge the batteries.
Jul 11, 2010 | Sony MDR-RF960RK Consumer Headset
Sentry Fireproof Safe Logo
141 people viewed this question
Top Sentry Home Security Experts
Hannah Johnson
Level 1 Expert
ray012965
Michael Galve
Michael Galve
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
