Question about SanDisk Sansa e200 MP3 Player
E200 microSD card not reading
When i connect the mp3 player with my 4GB microSD card in it, a separate drive appears, but when i click on it, there is an error message saying that i need to insert a disk into the drive. and if i try putting music on the microSD card itself and then putting it in the mp3 player, it doesnt recognize the music on the microSD card.
  • 007magicman Dec 12, 2007
    when i right click on the separate drive, i don't have the choice to explore, i can only expand. and then it tells me that i need to insert a disk into the drive.
Mp3 player always have max limit of extra storage to support. sansa e200 series supports only upto 2 GB extra.
Posted on May 03, 2008
  • 3 Answers
Try to right click the icon of the separate drive and click on explore
Posted on Dec 12, 2007
Sansa e200 wont recognize 8GB microSD
The Sansa e200 series machines work with microSD cards. Your 8GB card is actually a microSDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use microSD cards, which are 2GB and smaller.
Later model Sansa such as the Fuze will work with microSDHC cards, but not the e200. Sorry if this wasn't the answer you wanted to see, but that's the way it is.
Aug 20, 2011 | SanDisk Sansa e250 MP3 Player
I have sansa e200 4gb and not read my micro SD 4GB in the player and not through usb on my computer.Help me please
The Sansa e200-series uses microSD cards. Your 4GB card is actually a microSDHC card (the HC stands for High Capacity). While it fits into the slot, it is electronically incompatible and won't work. You need to go with microSD cards, 2GB and smaller.
Dec 16, 2010 | SanDisk Sansa e200 MP3 Player
I added a 8GB micro SD card to my e200 MP3 player but the player won't recognize the card. What do I do?
You need to use microSD cards, 2GB and smaller. Your 8GB card is actually a microSDHC card (the HC stands for High Capacity). While a microSDHC card will fit into the slot, they are incompatible with the Sansa e200 series.
Sep 23, 2010 | SanDisk Sansa e200 MP3 Player
My sansa e250 having video option, but it not supot any video file to play on the player.
When your operating system on the computer is Windows:
Run the Sansa Firmware Updater to get the Sansa Media Converter: http://kb.sandisk.com/app/answers/detail/a_id/101/related/1
When your operating system on your computer is Mac, or when you want to update manually:
go to the Sansa forum: http://forums.sandisk.com/sansa/board?board.id=e200
note
Only when you have the e200 series version 2 player, videos can be viewed from the microSD card.
Accessing the microSD card:
http://kb.sandisk.com/app/answers/detail/a_id/167
Highest capacity of the microSD card:
Verify the version of the player. To check, go to Settings > Info.
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
Differences between e200 version 1, 2 and Rhapsody player:
http://kb.sandisk.com/app/answers/detail/a_id/193
For supported files, see:
http://kb.sandisk.com/app/answers/detail/a_id/21
and
http://kb.sandisk.com/app/answers/detail/a_id/32
Aug 13, 2010 | SanDisk Sansa e250 MP3 Player
Memory card in my sandisk mp3 player
The e200 series does not support SDHC cards with stock software. You're stuck using regular 2 gig microSD cards, OR upgrading to Rockbox software, which DOES support the SDHC cards. It's a software limitation, in other words, not a hardware limitation.
Jun 10, 2009 | SanDisk Sansa e200 MP3 Player
'will e 260s work with sdhc microsd cards'
Have you found one bigger than 4GB?  (SDHC MicroSD, that is?) 2GB works, and if they update the firmware again it will work with 4GB...
You should check out the free software project 'jukebox' which lets you do all kinds of thing (really, anything at all) with Sansa.  The forum there can answer whether 4GB cards have been made to work with that....
Jun 16, 2008 | SanDisk Sansa e260 MP3 Player
Microsd memory
You dont. Max is 2Gb.
May 14, 2008 | SanDisk Sansa e200 MP3 Player
Cant find mp3 player
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
Sansa Recovery Tool
PDF how to use recovery tool
Answer The power may be depleted fully or the Connect might be hung during boot. Charge the Connect for at least 20 minutes using the AC charger. If the Connect will not turn on after 20 minutes charging with the AC charger, you can then try using the Connect Recovery Tool.
The recovery tool will reformat and reload the latest firmware to the Connect. The tool and instructions are located here.
Note: Ensure the Connect is turned off by holding the power button 8-10 seconds before initiating the recovery sequence.
Answer ID: 450 Created: 05/14/2007 Updated: 11/08/2007
For Products: MP3 -> All Sansa Connect
Category(s): Audio Player
Explanation:
The e200 can operated under two different modes, MTP (Media Transfer Protocol) mode and MSC (Mass Storage Class) mode.
To see the MicroSD card as a Removable Disk, the e200 must be in MSC mode. The following screen shots show how the "My Computer" screen will look when the device is plugged in under each mode.
MTP Mode
MSC Mode
Solution:
To change the mode from MTP to MSC go to the Main Menu of the e200.
If you're e200 is plugged into your computer, please unplug it first.
1) Scroll to the "Settings" > "USB Mode" > "MSC Mode" and push the select button.
2) Connect the e200 to the computer using the USB cable provided.
3) Go to "My Computer" and there will now be two Removable Disk drives similar to the MSC Mode image on top.
Answer ID: 356 Created: 03/23/2006 Updated: 03/24/2006
For Products: MP3 -> All Sansa e200 Series , Mobile Memory Cards -> All microSD and microSDHC
Category(s): Audio Player , Computer Only-> Windows XP
Apr 01, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e200 (E260 4GB)
this player can only RELIABLY read SD cards of 256MB or less - anything bigger may work sometimes, or not at all
Jan 20, 2008 | SanDisk Sansa e200 MP3 Player
My computer will read my e250 but not my microsd card
Switch your player into MSC mode via Main Menu > Settings > USB mode. When the player is connected it will show as two drives, the player, and the microSD card just like a card reader. You can transfer files directly to the expansion card.
Apr 19, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
326 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
