Question about Motorola Mobility MOTO W755 Cellular Phone
When I store a number to retrieve my voice-mail from a landline, I need to insert a pause between the number and the pssword. How do I do that? Thanks.
I have a tracphone. How do I clear my voicemail box? No messages can be left on my voicemail. Thank you.
Delete voice mail by going through the keypad on your cell phone. The actual procedure depends on the kind of cell phone that you own. For example, on the Nokia 1100, hold down the "1" key while you are on standby. Tracfone connects you to your voicemail, where you can follow spoken menu instructions to listen to your voicemail. After you hear the voice message, you're asked if you want to delete your recordings.
This is not recommended, because connecting in this way uses up your minutes even if you just want to listen to them.
Use your landline phone to delete messages if you want to avoid using your Tracfone minutes. Turn off your cell phone so it doesn't ring and then call your cell phone number from a landline.
Press the "*" (star) key as soon as you hear your voice mail greeting. Then enter your password number and press the "#" (pound) key.
Listen to the instructions for accessing your voice mail, which can vary slightly depending on the phone you have. You are told the number of new and old messages you have, how to listen to them and how to store or delete them. Press the number for listening to the message to hear it, and then the number for deleting.
Sep 08, 2017 | Lands Phones
How do I increase the number of rings before it goes to voice mail
What type of phone is this? Most home phones have a setting in them to adjust the number of rings. Retrieving voice mails requires the voice mail be set up first. To assist you further, please provide more details.
May 22, 2017 | Lands Phones
No manual, don't now how to answer the answering machine?
Search Results
    Recovering deleted messages from a digital answering machine ...
    www.technibble.com > Forums > Other Discussions > General Chat
    Dec 9, 2013 - Recovering deleted messages from a digital answering machine ..... AT&T cordless phones - I don't know how similar that would be to Uniden.
    How to retrieve deleted messages from digital answering machines ...
    forums.verizon.com > ... > Home Phone (Landline or Digital Voice)
    Mar 16, 2015 - I have to say, though, I doubt you'll be able to recover the messages. Digital answering machines typically don't have an un-delete. Good Luck.
    How Do I Access Voice Mail? ' magicJack Check
    mjcheck.low.li/2013/12/how-do-i-access-voice-mail/
    Dec 14, 2013 - Delay needs to be at least 30 seconds because voicemail takes just over 30 ... If you don't know your four-digit pin, it's possible you haven't ...
Jan 05, 2016 | HQRP Phone Battery for VTech CS6529-2...
How do I retrieve voice mail messages from my uniden dect 6.0?
If you subscribe to a voice mail service, you can use your phone to access your voice mailbox. The new message
LED on the handset flashes and appears in the handset display whenever you have messages waiting in your
voice mailbox. When you subscribe to the service, your voice mail provider provides you with the access number
and the required voice mail signaling tone. You can use your phonebook to store the access number
Feb 13, 2013 | Uniden DECT 6.0 Cordless Telephone...
How do get my voice mail
call ur voicemail from cell phone by pressing 1 when prompted enter ur passcode and if u r tryin 2 call it from landline you call ur number and wait until u hear ur voice and press * on ur landline it should then ask u for your passcode u then would enter 0657
Jan 31, 2013 | AT&T Cell Phones
How do I access my voicemail from another phone?
To call your Voice Mail from a landline phone:
1. Call your TracFone from a landline phone.
2. When your voicemail begins, press the star key on your landline phone immediately.
3. Enter the PIN you use to check your Voice Mail from your TracFone. When you have finished entering your PIN, press the pound key.
4. Listen to the instructions. They will tell you how many voicemail messages you have and give you options for checking them, deleting them, saving them or storing them as new messages. Phones may vary, so listen carefully to the options.
if you havent created a pass code try 9999, if that doesnt work give tracfone a call.
1-800-867-7183
Sep 19, 2012 | tracfone.com
How do i retrieve my messages from a landline when my time is out
You'll receive a text message stating "You have a reply to your Text to Land line message from XXX-XXX-XX-XX. Press TALK to listen to the reply." There is no charge for this notification.
This text message will contain the appropriate toll-free phone number which you can use to retrieve the voice-mail. To pick up the message, you must make the call from the mobile phone that received the notification. Standard airtime rates apply.
Jul 29, 2009 | Cell Phones
I cannot retrive my voice mail messages from my sciphone i68+
If you have voice mail on a land line as opposed to your cellular phone, you shouldn't have an icon on your cellular phone to retrieve any but the voice mail on your cellular account. If there is a special phone number that you call to retrieve your land line voice mail, then dial it, and enter whatever codes are required to retrieve your land line voice mail.
Apr 25, 2009 | Dual Electronics CECT P168 Cellular Phone
When i try to call my voicemail it goes to a woman's comes up telling me to enter my 10 digit phone number for my voice mail box but when i enter it it just says that that there is no mail box with that...
This indicates the retrieval number stored in your phone is incorrect. You can call your service provider to get the correct number and instructions on how to store it. As a work around, call your own number, when you hear your voice or the voicemail greeting, press * and enter your password. This will work as long as the provider has the correct deposit number stored on their end.
Apr 21, 2009 | LG Vu CU920 Cellular Phone
Motorola Mobility MOTO W755 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
