Question about Refrigerators
Doesn't seem to be freezing enough to make ice
    Problem Solver:
  • 10 Answers
Increase or adjust the thermostat. u can see it inside the refrigerator.
Posted on Sep 13, 2009
Freezer side not cold enough, similar temperature as Refrigerator side
It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
Nov 12, 2013 | Refrigerators
I have cleaned out the refrigerator and it still doesn't cool enough to freeze the ice and the bottom isn't cooling enough either even after putting the temperature up.What can I do next?
Have you cleaned off the fins at the bottom of fridg? look on back at bottom and bottom front. Take off covers and see if fins are dusty if so vacume off be careful not to damage fins.
Jul 07, 2012 | Refrigerators
My ice maker doesn't make enough ice cubes
Is the ice maker itself filling normally, meaning where the cubes are made gets enough water to cover the complete area or just a few slots? If not then check the fill tube where the water comes into the ice maker to make sure no ice has formed blocking the water from coming in.
Now if ice production in general has slowed, going from every 45 minutes or so to like every 6 hours, then your machine more than likely isn't getting cold enough. The ice maker requires the temperature be at least 10 degrees F or below for it to function properly.
Jun 16, 2012 | Kenmore Side by Side Refrigerator
I have a sub zero model 650 refridgerator. It is making some ice then it seems as though the water keeps dripping and it freezes up the shelves. Its like the water doesn't shut off when its suppose to...
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 23, 2011 | Refrigerators
For some reason the coils seem to have iced up. I doesn't seem to drain anynore into the reserve tank. What do I need to do?
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
May 30, 2011 | Crosley Dehumidifiers
Our freezer is cold but not cold enough at the top to make ice. It will freeze a cup of water at the bottom but doesn;t seem to be cooling enough. The compressor does come on and the fan is blowing. Is...
Get a thermometer, and place it inside the freezer. The temperature should get at least 17 degrees. If it is like 28 degrees or highe it will freeze water but not other things like some popsicles which freeze at lower temperature.
Mar 05, 2010 | Refrigerators
Ice not strong enough to push open ice maker door
twtw7771
You said,
The ice maker door seems to have a tight spring or something because when the ice goes in the chute and then backs up.
The door needs to be replaced because it is bent or out of alignment!
How old is the fridge??
Now a days you have a 1 year warranty!
Or the seal is not tight and air gets inside past the door and then the moisture freezes on the spring.
Sep 20, 2008 | Refrigerators
Water freezes before getting to ice tray
sounds as if your water inlet valve is not closing fast enough allowing a small amoutn of water to accummulate in fill tube freezing and eventually freezing solid, would try replacing water inlet valve, or even the water filter if this model is so equipped
Feb 18, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
