Hi i have a samsumg b14455 but won't drain
Hi i have a samsumg b14455 smart wash but will not drain off any water, it tries to drain but just makes a racket
  • 76 Answers
Check ur drains. not the washer's the houses;s.
Posted on Sep 13, 2009
Smart drive 085
It won't spin until all the water is drained out. The drain pump may be blocked or faulty. Fix the drain pump fault first then deal with the filling issue. They will not be related.
Jun 21, 2017 | Fisher and Paykel (IWL12)
Hi I have a fisher and pykel fresh smart drive 9 and its filled up with water but wont drain,ive tried advancing the cycle but all I get is a humming noise.please help
The humming noise is due to the drain pump being jammed due to clogging of dirt. All you need is to remove the drain pump and do a full clean up. You can also try to tap on the drain pump while it is humming as it will release the dirt and wash off.
Sep 07, 2013 | Fisher and Paykel GWL11 Top Load Washer
Pop off valve on gas water heater making racket. Can just the pop off valve be replaced?
Yes it can be replaced. This is a temperature/pressure relief valve and is the second most important safety device on your heater. They rarely make racket. Is it leaking? if so yes replace it. Water heaters should have a portion of water drained annually along with operating the relief valve. IF you raise the handle a few times, and it continues to leak, then it should be replaced. If you replace it be sure to replace it with EXACTLY the same temperature and pressure rating that is on it now. Allow the water heater to cool, and drain pressure before removing. If it is rumbling inside, you might have calcium deposits bouncing around in the bottom. Drain some water and see how it looks. (Often if you operate drain, and haven't in a long time it won't reseal)
Aug 11, 2010 | American Standard 40 G Natural Gas Water...
My washer is making a grinding, metalic noise when the agitator is supposed to be moving. Water enters and drains fine. The agitator moves very little and makes a great racket. Help!
Could be the belt or the bearing or both...
You need to remove the belt and test if agitator moves easy by hand, then it means bearing is OK
Apr 16, 2010 | Whirlpool Washing Machines
I have a GE Model WJRE5500g0WW washing machine. It is two years old, purchased new. After the clothes had spun dry, water was observed on floor. Drain tube checked and okay, not plugged up. Before I open...
Normally water on the floor can be from a few places. Mostly a faulty drain pump: possibly a tear in one of the pipes: rust in the drum: possibly water in the centre which comes from the bearings.(if the machine makes a racket when spinning, then i would look at the spin bearing collum). even concider drain pipe at outlet not running out onto floor. Either tilt washer back about 45 deg. to look underneath or possibly remove panel to allow a visual of the motor and components. See if you can pick up any indecationof water having run down from a particular spot. If so rectify. Hope it helped. .Ge washers not farmiliar to me but most problems are similar.
Sep 17, 2009 | GE WJSR2070B Top Load Washer
Machine does not spin, it only makes a horrible racketing noise
Sound like you have a busted coupler .It is located between the motor and trany.Cheak inbetween .hope i helped.:)
May 18, 2009 | Kenmore 22422 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
