Question about Panasonic SC-HT67 System
Locked sa-ht67 I just locked my panasonic sa-ht67 system. all i did was move it from its spot to check connection in the back. I am 95% sure i pushed bottuns on front. Well when i put it back on the shelf it read locked on screen. I can still satch the disk that is trapped inside but that is it.
  • Anonymous Dec 05, 2008
    i have the same problem the  receiver  comes up with the F61 error code and i would like to know how to fix it
I hope you've already unlocked your DVD player by now, but for all those searching after you, I got the solution from Panasonic.
Make sure the device is on the DVD/CD mode. Press the Stop button on the main unit and the >=10/Enter button on the remote control simultaneously. You will see the word "Initilize" on the device, and at that point it is unlocked.
Posted on Sep 20, 2009
Had a similar problem with a Sony DVD recorder which I found was due to standing the unit on its front which caused the 'on/off' switch to be depressed for a long time, this put the unit into 'childlock' mode - I found holding the 'on/off' down for about 20 sec cleared it.
Posted on Jan 07, 2008
Disc tray will not open and only says "ERROR" when I hit open.
The tray moves by the use of a rubber belt. These often come off and therefore it won't move. Replacement is easy if you can get to it. There are other causes too, but this is more than likely the cause.
Jul 28, 2015 | Panasonic SC-HT67 System
When i power on the screen shows F61
Another user wrote that by redoing the speaker wire connections and turning the volumn on low at start up he solved it. Try this and let me know if it worked. jim@firstservicetechnology.com
Jun 15, 2009 | Panasonic SC-HT67 System
I cant eject cd/dvd changer.
there may be a lock/unlock selection in the menu somewhere, something like a parental lock on tv sets, this is just a thought on my part.
Mar 25, 2009 | Panasonic sa-ht930 Home Theater Audio...
Need to connect panasonic sb wa730 to panasonic sa dp1 system
There is a subwoofer outlet at the back of the sa dp1 connect via cable to the inlet on your sub then on your sa dp1 remote press shif and subwoofer at the same time
Feb 28, 2009 | Panasonic SC-HT730 System
Fault code
speaker cord connector problem:-
remove all speaker connectors and insert it one by one each time until you find the bad one and change its connector with a new one.
(you must play something and listen).if all above does not work you will have problem in power supply and need to fix.
Mar 24, 2008 | Panasonic SC-HT67 System
Tv Code!
http://service.us.panasonic.com/OPERMANPDF/SCHT67.PDF
Nov 19, 2007 | Panasonic SC-HT67 System
Panasonic home theater
take it apart via the screws on the side and back and then there is a white lever you can pull to unlock it. make sure you are wearing shoes because you dont wanna short the system
Sep 09, 2007 | Panasonic sa-ht930 Home Theater Audio...
Panasonic SC-HT67 System Logo
738 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
