Question about Samsung L74 Wide Digital Camera
My dad has a L74, before his holiday the battery
My dad has a Samsung L74 bought it just a year and a few weeks ago. Before his holiday the battery was fully loaded and after some (about 60) pictures taken the battery seems to be flat. He tried to load it again but the loader shows green red and orange (just once after each other and then gets off) but it is not starting to load. Has anyone got this experience with this 'error' and knows what to do? Thanks, in name of my Dad, Kees, the Netherlands
So two years ago my dad accidentally spilt some coke on the fax machine. We opened it up and cleaned it and it works EXCEPT the phone part of the fax machine. What is the problem? Or what could it be?
Try removing the phone's battery, then wash it out with water. Then put phone in a bag of white rice for a week. Then replace the battery.
Dec 08, 2012 | Cell Phones
Electrical problems
Are these factory OEM replacements? I once put three cheap aftermarket Kragen batteries in my Corvette in 6 months, bought a Delco and problem solved, that was years ago. Sounds like your problem is that the car sits to much, if it sits more a few weeks either hook up a float battery charger or disconnect the negative cable to the batt.
Feb 02, 2012 | Cars & Trucks
I bought Samsung SGH-L700 few years back.. now the display light never shuts off... and so battery never stands.. can sim affects?? cos if i use my dad's sim it works normally.. :( need a solution...
No, The SIM does not make changes to the phone settings like Display.
Go to Menu-->Settings--> 3. Display and Light Settings--> 2. Light Settings--> 2. Backlight Time.
Set ON to Lower side like 10 Seconds and DIM to Off (or less than ON Timer). This will turn off the display in 10 seconds.
May 11, 2011 | Samsung SGH-L700 Cell Phone
Hi. i bought my acer aspire 5583 3 years ago...now it suddenly can not be turned on... last 2 weeks i still can play it..but one week later when i came back from holiday...i found out sth wrong with my...
This is just a suggestion ... try removing the battery and turning the computer on with only the mains power lead attached.
Sometimes, as the battery dies, it does silly things with the computer.
If it works, order a new battery.
Hope this helps,
CJ
Jul 02, 2010 | Computers & Internet
TOSHIBA SATELLITE M45-S165 won't charge Battery. The power connector on the back of this laptop is losse but still powers the Laptop. I bought a new battery and the Battery light does light up on the front...
it could be possible that changing the dc jack at the back may fix the problem however it could be a faulty new battery as ive had a few copies (not original) which would work for a week or so then die or others which wouldnt work at all, i finaly splashed out on a new original battery and it hasnt let me down and i bought it over a year ago.
Hope this helps
Apr 19, 2010 | Toshiba Satellite M45-S165 Notebook
Battery Problem for Nokia N81 8gb
I bought new nokia n 81 few weeks ago.its battery finishes very quickly.plz help me
Jul 06, 2009 | Nokia N81 Smartphone
Samsung VP-D31 Mini DV Digital Camcorder
No its not with the samsung alone. Both of your cameras suffer from defective CCD. I think if the cameras were manufactured between 2002-04 then they must be having manufacturing defect. Contact your local Samsung and ask about the world wide problem of defective CCD that were replaced by almost all the camera manufacturers FREE of cost.
Oct 27, 2006 | Samsung VP-D31 Mini DV Digital Camcorder
Samsung L74 Wide Digital Camera Logo
57 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
