Question about Sta Rite STA-RITE CONTROL BOARD KIT - 42001-0096S
R8 Error Turned on heater. LED says 125 then 126 then 125 - back and forth and back and forth. I set the thermostat to 100 degrees (spa was 77 degrees a tthe time). Then r8 appeared. What does this mean? How do I fix this? Heater not turning on at all.
  • misslasko Sep 14, 2009
    Sta Rite 400NA. I do have a remote for it. But I bypassed it & tried turning the heater on manually. LED still flashed 125, 126 etc right from the start then R8. Then back to 126.
    Champion:
  • 246 Answers
Dont know what heater yuo got may be a board or temp sensor also post if automatic control
Posted on Sep 13, 2009
Heats to 72 degrees
try setting heater all the way to 104 the aqualink should control the heat
Jan 03, 2014 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Error AD0 SF0 180 r8
the stack flue sensor is bad make sure you order the identical part since is two model for thre same heater
Oct 09, 2009 | Sta Rite Maxi Therm 400k Btu Propane...
I have a Sundance Spa (Altmar - bought in 2004). I've never had a problem before. I just changed out the water and noticed that its not heating as anywhere near as quickly as before. I do not see the icon...
we spoke earlier in chat about the problem. You might also be looking at a sensor that plug into the circuit board. The repair costs shouldn't be more than $100.
Sep 21, 2009 | Pool & Spa
Sta-Rite Problem; Error codes R8, Won't stay on.
Its the top membrane where the control buttons are. The circuit board plugs in to it.
Aug 21, 2009 | Sta Rite STA-RITE CONTROL BOARD KIT -...
Sta Rite Sr333na Max E Therm Pool & Spa Heater gauge stuck?
Anytime the heater is reading the water temp to be above what it actually is, especially 126, the problem is the Thermistor, or Temp Sensor, for the heater. This is a very easy part to replace. The Thermistor is located on the manifold, on the left side, between the top two bolts.
Sorry this is a late response! Hope that it helps!
Apr 10, 2009 | Sta Rite Sr333na Max E Therm Pool & Spa...
Pentair Heater shuts off prematurely when warming spa
check gas pressure could be running out or overheating
Mar 06, 2009 | Pentair MINIMAX NT TSI IGNITER
Sta-rite pool heater SR333LP
This heater has a thermal regulator and a high limit that could be the problems. If it were a high limit that was bad, the display would show the error when the heater goes off. In the absence of an error, one would look to the regulator. A bad regulator would cause the water flow to bypass the exchanger and cause a slow heat. The part is easily replaced and runs about $90. It sort of looks like a car thermostat and also has a spring. It is accessed by removing the large black plug near the plumbing inlet/outlet.
Dec 16, 2008 | Sta Rite Sta-Rite Max-E-Therm High...
Sta Rite STA-RITE CONTROL BOARD KIT - 42001-0096S Logo
618 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Jim Goldsmith
Jim Goldsmith
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
