Question about Kenmore 22422 Top Load Washer
Water leaks at bottom of washing machine
Water leaks at bottom of washer machine
  • 76 Answers
Get the drun check out. It could be louse or it is totally of it's hinges.
Posted on Sep 13, 2009
My washer is leaking water
Frigidaire washing machine leaking water from bottom
www.washingpoll.xyz/frigidaire-washing-machine-leaking-water-from-b...
I on the middle hard non porous ( keep girl does washing machine front you ...Detergent liquid reviews drain new combo amana washes click. ... Drum sensor cleanedfilter years of rash bad skin pull disconnected washer dry rings magic left.
Dec 30, 2015 | Washing Machines
HL04932940 27" FRONT LOAD WHIRLPOOL HE WASHING MACHINE LEAKING WATER FROM BOTTOM
First check is the standpipe drain. The hose that comes from washer should not be inserted more than 4". More than that can cause a syphoning situation that can cause leaks from beneath. If that seems okay you will have to see where water is coming from by observing the machine in action with back or bottom service panel removed (if it has one.)
Jan 06, 2013 | Whirlpool LHW0050PQ Front Load Washer
Admiral washer leaking water from bottom
What is the model number of the unit?
Nov 24, 2012 | Admiral Washing Machines
Water coming out of the bottom of the machine
Sometimes, what may seem like a washing machine leaking from bottom locations is actually one that leaks slowly from other spots. Slow leaks can accumulate beneath your washing machine making it seem like you have a bottom leak. For more help identifying the exact point of the leak, see Washing machine leaking.
Bottom leaks may be better identified using a newspaper. Just dry the floor and lay the newspaper beneath the washing machine before you test for leaks. Darkened sections map out your water leak. This method is not always foolproof, however. The best diagnosis will come from a qualified service professional inspecting your machine.
If your washing machine is leaking from bottom in the rear, you may need a replacement pump and professional installation. The leak could also be caused by a faulty air dome seal or a hole in the tub. For more troubleshooting steps to tackle that leak, see Washing machine leaking from bottom. I hope that helps!
Sep 27, 2012 | KitchenAid KHWS01PMT Front Load Washer
Water leaking from the bottom of washer
I had this problem the other week we turned the machine around and took off the water hose got to the water pump and found 5cents, hair pins, badges ect in there once cleaned out and put back together worked great again and no more leaks!
Apr 26, 2010 | KitchenAid KAWS850L Top Load Washer
Maytag top load washing machine leaking water from bottom
The machine is leaking water from the bottom, I think the leak is in the area near where the motor is mounted. Before we noticed the water comes from underneath the washer, we smelled like burning rubber.
Al Bana
Jun 26, 2009 | Maytag PAV2300 Top Load Washer
Washer leaks water from bottom
Water pump or hose came off or broke but i bet its the water pump
Feb 06, 2009 | Kenmore 23822 Top Load Washer
Heavy water leak during when washing clothes
disconnect the hose on the bottom and see if the seal is good.If it is good, then remove the back panel, start the washer and watch and see what seal is broke and you can visually see the exact spot the water is leaking from.
Feb 04, 2009 | Maytag Atlantis MAV6000 Top Load Washer
GE Top load washer.
Hello rschneeweis
Welcome,
Sounds like a seal or drain hose is leaking or the clamp on a hose has vibrated loose.
Water leaking out the bottom of the machine when washing machine begins agitation cycle. If the machine is turned off the water stops leaking even with the tub full of water.
Let me know if you found it and how you do.
Huuum
Please remember to leave a rating
Oct 04, 2008 | GE WBSR3140D Top Load Washer
Kenmore 22422 Top Load Washer Logo
89 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
