Before 1 month when i was watching tv it went off n doesnt started
My tv went off, will not cut back on. only had it 6 months. was hooked up to xbox 360 and watching netflix.
Return TV to retailer as faulty under the warranty conditions for a repair or replacement depending on trade regulations for your area
Dec 19, 2015 | Televison & Video
Keeps taling longer for tv to start
Probable power supply decline to failure.
Dec 28, 2013 | Toshiba 46XV640U 46 in TV
I have digihome tv has sound but no picture and nothing on virgin
is this happened either watching a tv channel or even watching dvd movies?. and then does the display only white screen or a totally black screen?.
Oct 16, 2012 | Digihome LCD TV
OmIm trying to figure out why my tv will not come on. I was watching it one night and it just went out . I did not think nothing else of it so . I left out the room about 30min later I started to smell...
First replace bulb to make sure it's not the bulb. If it's not the bulb it is most likely the light engine. My suggestion would be don't invest in the light engine. Goes for about $500 plus for a re-built one and warranty is only 3-6 months on it. I purchased one and it went again in 4 months.
Please don't invest in any more dlp tv's. I learned the hard way.
Jul 19, 2011 | RCA HDLP50W151 50" Rear Projection HDTV
Sharp 26'' LCD HD screen went white, sound is fine
Go ahead and try unplugging the video (yellow) cable and plugging it back in.
If that doesnt work, do you have any spare video cables try those.
Then unplug your tv for 2 mins and hope for the best.
GOOD LUCK.
CNBY
Jun 03, 2010 | Televison & Video
Vizio screen went white
Im sorry but did you figure this out yet. my tv just did this today too. it broke now.
Jan 28, 2010 | Televison & Video
The picture went out on our sony bravia lcd
If the unit is less than a year old, it should still be under warranty through the rental center. The inverter has failed. This is what supplies the light behind the panel. This is a relatively common failure and is easily fixed by a service center. Call the rental center for instructions on what to do. This is not a failure than can be caused by misuse. You should not be at fault here.
Dan
Jul 28, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
After 2years and 9 months the picture went black,
Most likely, capacitors in the power supply are bulged. It is not an expensive repair.
Jul 01, 2009 | Philips Televison & Video
My Tv Keeps Turning Off like 30 seconds after i turn it on...
This sounds like your flyback went out on the main board (about 70.00 for part!
This should fix ya!
Dec 12, 2008 | Sansui DTV2760 27" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
