Question about Electrical Supplies
How do you remove the altitude adjustment knob at the bottom of the carburetor bowl from an Onan BGE spec M generator (without breaking it). This link shows the carburetor: http://www.partsfortechs.com/asapcart/bmz_cache/8/8879f5cff051af2f6fe95806a3a1b96d.image.499x550.jpg
    President:
  • 1,714 Answers
It probably has a small Allen screw in the side of the knob. Use a Allen wrench to loosen it and pull it off.
Posted on Sep 16, 2009
I have a 6500 lp onan marquis generator in my rv that wont start. any suggestions?
Check the fuel. If old, drain & refill it.
Check for spark.
If the fuel is there and good, trace it to the carburetor. Check the carburetor bowl for fuel.
Check the spark plug, the magneto, any switch that breaks the circuit or kills the circuit for spark.
If you're getting good fuel to the carburetor and you're getting good spark, try to start it with ether spray.
You might also want to check compression while you're checking everything else.
Jul 26, 2014 | Onan Marquis Gold 6500 Lp
How is the carbeurator bowl on an ONAN Marquis 7000 genset removed? I think it sat too long without Stabil and became clogged. It appears to be, maybe< pressed on as there are no visible holdong
They are generally sealed, as it affects the mixture. You can take the carb off, put on the bench and remove the shut off solenoid at the bottom of the bowl, remove black cap on main jet, remove screw, and unscrew the bowl. To set back up you will need to ideally check on a load bank, for ability to pick up full step load,
Jul 06, 2014 | Onan Marquis RV Generator 7000 Watts Gas
Onan Generator
id say its your idle jet is blocked. remove and clean carburetor thoroughly is solution or for quick fix try removing air filter and spraying carburetor cleaner into throat of carby whilst revving engine, repeat several times and perhaps that will flush it without need of removing carby.
Jul 04, 2012 | RTO Cummins Onan HomeSite Power 5500
I have an Onan 2500 LP generator. What is the red knob for?
That knob should be to bring pressure up and down with 0 being off or the lowest range of the regulator. This regulator is adjustable for different applications apparently.
Jan 21, 2010 | Watts Onan Portable Generator - 4000 ,...
Onan Marquis Gold 5.5 HGJAB 1038C. Won't start.
Test the solinoid with an ohms meter and if the circuit is open replace the solinoid.
Oct 22, 2009 | Watts Onan Portable Generator - 5000 ,...
Coleman 6250 generator runs rough
Fresh fuel? Does carburetor have adjustable jets? Turn the high speed jet (at bottom of float bowl) about 1/4 to1/2 CCW (looking at bottom of bowl). If no improvement, carburetor should be torn apart and cleaned. This also applies if there are no adjustable jets. Is there a fuel filter anywhere?
Jul 14, 2009 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
431 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
