Question about GE GDS18LBR Bottom Freezer Refrigerator
I have a problem with botom freezer ge refrigerator its not defrosting
  • Fred Masson
    Fred Masson May 11, 2010
    Wen u try to defrost ur frezzer do u tun of the entire unit? Like friged and frezzer. and how long do u wait
  • GE Master
  • 4,654 Answers
The first thing to check on your model is the defrost timer found inside the fresh food section and behind the control panel where you adjust the temperatures. Look for a small opening about the size of a pencil. Most times the hole is covered by a plastic plug and all you need to do is pull the plug out and with a flathead screwdriver turn the timer clockwise slowly until you hear the compressor stop. It should remain off up to 25 minutes and come back on itself. If not turn again slowly clockwise until the compressor restarts. During the time the compressor is off you should be able to open the freezer door and hear sizzling and crackling. That would be defrost taking place. I have some photos and locations I will place here next to help guide you on this, Sea Breeze
Posted on Sep 13, 2009
Ice sheet forming on bottom of freezer. GE Monogram with top refrigerator and bottom freezer
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 21, 2010 | GE Monogram ZICS360NRRH C... Bottom...
Ge profile refrigerator/freezer, freezer on the bottom. Refrigerator stopped cooling.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Nov 06, 2010 | GE Refrigerators
1/2"ice on the botom - why?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 07, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have an amana br22 the botom freezer gets an ice block on the radiator coils then air flow slows down to top section i have to hot air gun the freezer to get the air to start moving
The ice block is due to a defrost circuit failure. Typical problems are due to the defrost heater, defrost timer if used on this model and defrost thermostat. Since you are using a heat gun to melt the ice, check the the defrost heater with a meter to determine whether it needs to be replaced.
Aug 23, 2010 | Amana Easy Reach AFD2535DE Bottom Freezer...
AMANA FRIDGE ARB190RCW FREEZER AT THE BOTOM. FRIDGE IS RUNNING BUT NOT COOLING. FREEZER BACK WALL FULL OF FROST
Switch off unit for 12 hours and do a proper defrost. once all ice is gone, switch back on and take note if evaporator fan is working.
Oct 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Model tfx24f defrost not working.
Replace the defrost heater and defrost thermostat located behind the freezer panel inside the freezer compartment.
Jun 12, 2009 | GE PSC23NHN Side by Side Refrigerator
Refrigerator not cooling
I THINK YOU HAV A DEFROST PROPLEM .. CHECK AND SEE IF YOU HAVE A LOT OF FROST ON BACK WALL OF FREEZER ./. IF SO YOU HAVE YOU DEFROST HEATER ,. DEFROST BY-METAL OR // TIMER OR MOTHER BOARD ..
Feb 04, 2009 | GE GDS18LBP Bottom Freezer Refrigerator
Freezer will not defrost on its own GSL25JFPE
Most likely, the defrost system has failed. There are three components: a defrost timer, a defrost heater, and a defrost bi-metal.
I would have suggest replace your defrost heater.
Jul 25, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer
If the freezer is in defrost then the freezer fan should be off. Only on the electronic will the freezer fan come on in defrost but the freezer door has to be held open for 3 min before the fan comes on
Jun 17, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GDS18LBR Bottom Freezer Refrigerator Logo
294 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
