Question about Nokia 3110 Cellular Phone
Security Code I tried my security code for more than 5 times and now it is disabled. i get a message called "code error". I cannot unlock my phone with my security code.
  • Jestin Zachariah
    Jestin Zachariah May 11, 2010
    Hi, Call your service provider / carrier and they will unlock the phone IF you met their requirements otherwise you can either buy an unlock code online Or take your phone to a phone tech store and they will unlock the phone for you. Hope this helped!
TampaNative
  • 778 Answers
SOURCE: unlock security code for n76 phone
Try "0000", and if that doesn't work try "1234" to unlock it.
Good luck.
Posted on Feb 15, 2008
SOURCE: Resetting Security Code
forgot password need master code....IMEI no is 354813017033711
Posted on Sep 15, 2008
SOURCE: unlock security code for my nokia 6030
i have a nokia tmobile 6030 b . HELP ME.............. sir my mobile not accepting my security code which i set.......all time it says CODE ERROR... I had try this after a interval of 1-2hr also, will you pls help me to unlocking this......... waiting...........thanks
Posted on Dec 07, 2008
  • 40 Answers
SOURCE: Security code problem to unlock Nokia: 7210 Supernova
Here is a solution that I have found.
http://www.indiastudychannel.com/sites/147861/Forum-1918-Forgot-your-Nokia-phone-security-code-Reset-here.aspx
Hope it helps. Please rate if helpful. Thanks.
Posted on Apr 14, 2009
heavyice
  • 374 Answers
SOURCE: How to unlock my cell phone. I forget my security code.
By default the security code is 12345 u can try that or u can use a mobile unlocking software,for some the software has worked.Try it.
Posted on Jun 01, 2009
Trying to unlock my Nokia 1600 i get not allowed message
try the following
#pw+918432431511027+7#
without SIM inside the phone.
After entering the security code, are you getting any message on your phone as "Cannot Undo Restriction" or "Not Allowed".
Note - You only get 5 attempts to unlock the security code.
The message "Can Not undo Restriction" or "Not Allowed" means that an incorrect code has been entered 5 times or more, before entering the generated correct code generated. This means that even a correct code will not unlock your phone. Unfortunately, your phone can now only be unlocked using a direct cable method, your local market unlocker should be able to help you out.
Jun 06, 2010 | Nokia 1600 Cellular Phone
I need to unlock the security code of my nokia 1208.
You have probably forgotten your security code. Enter 12345 to enter new security code.
Regards
Aug 02, 2009 | Sony Ericsson W200i Cellular Phone
MY NOKIA 3110C SECURITY CODE DOESN'T UNLOCK...MY IMEI IS 354161020225035 AND I HAD ENTER THE MASTERCODE GENERATED BY (www.crazy4mobilez.com/mastercode.asp) AND STILL DOESNT UNLOCK THE PHONE..WHAT SHOULD I...
Select Menu > Settings > Security settings.
  • To set the phone to ask for your Personal Identification Number ( PIN) code every time the phone is switched on, if this function is supported by your Subscriber Identity Module ( SIM) card, select "PIN code request".
  • To restrict incoming calls to and outgoing calls from your phone, select "Call restrictions".
  • To restrict your outgoing calls to selected phone numbers (if this function is supported by your SIM card), select "Fixed dialing".
  • To specify a group of people whom you can call and who can call you, select "Closed user group".
  • To set the security code for your phone, select "Security level". The preset security code is 12345.
  • To change the security code, PIN code, PIN2 code or restriction password, select "Access codes
Jul 12, 2009 | Nokia 3110 Cellular Phone
6600
try this if you never change the security code. press"12345" wait 5 min or more before press ok.
If you have change security code you must go to nokia service center or mobile service shop to get security code reset.
Aug 15, 2008 | Nokia 6600
If you see any of the above messages then you have entered an incorrect code more than 5 times! When entering unlock codes you only get 5 attempts. There is no free solution to unlock your phone if you have entered the incorrect code to many times. The best advice I can offer is to take your phone to a professional unlocker such as a market trader or small independent retailer. They will use a direct unlock method using either a data cable or clip. These solutions are normally quite expensive to buy and unless you plan to unlock many phones it is not cost effective to purchase these yourself.
May 04, 2008 | Nokia 5300 Grey Cellular Phone
Security code
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Which is the one that you want?
The default security code for Nokia is 12345
Apr 23, 2008 | Nokia 3110 Cellular Phone
SIM pin code:
Master Reset Code
Apr 13, 2008 | Nokia 3110 Cellular Phone
Apr 09, 2008 | Nokia 7610
Unlock Nokia N95 8GB
plz give nokia n95 master cod
Apr 05, 2008 | Nokia N95 Cellular Phone
Nokia 6265i
There's a Security Code and Lock Code.
Resetting the Lock Code:
Remove the battery and replace it after 1 hour or more. The default Lock Code should reset to "1234". If that doesn't work try the last four of your phone number.
Resetting the Security Code:
The default Security Code is 12345. If this doesn't work go to your normal interface and type in "#3001*12345*. Go to the Security option, write down the number, then press "Ok". Back out of it all and it should take you back to your normal phone interface. The number your found should be your security code.
Feb 16, 2008 | Cell Phones
Nokia 3110 Cellular Phone Logo
23 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
