Question about Samsung CLP 300 Laser Printer
I purchased replacement toner cartidges for the CLP 300 and the printer will not work at all (says all 4 toners are empty). If I take the after-market chip off the toner cartridge, the printer works, but it says that I have a 1/3 filled toner cartridge (which is what the original toner cartridge has). I have had nothing but trouble with these machines when the toner runs out and have had to junk two of them already (bought 3 for the office and 1 for home). Any help would be appreciated.
Samsung CLP-325w says its out of black toner but the toner is full
I have the same problem. It says "End of life, replace with new black toner cartridge-K407 (CLT-K407S)" But I have just replaced the cartridge with a compatible cartridge few weeks ago and havent used it much so it should be almost full. And it was working after I replaced original cartridge with compatible one...Any help???
Oct 15, 2011 | Samsung CLP 300 Laser Printer
How do I purchase a new Laser Printer wastetank since mine is full? Samsung CLP-300
When you purchase a new toner cartridge it mat come with a new waste toner bottle. You can empty the waste toner in a plastic bag, do it in the open air and avoid inhaling toner powder.
Sep 27, 2009 | Samsung CLP-550N Laser Printer
Waste tonner tank
The waste toner container is inside the front cover at the bottom right. If you work for a business you should purchase a new one. If not you may be able to empty it into a another container and seal it before putting into the bin.
Jun 29, 2009 | Samsung CLP-510 Laser Printer
CLP 300 toner cartridges invalid toner
the drum has chips encoded,need cartridges with chips.
May 29, 2009 | Samsung CLP 300 Laser Printer
CLP won't print - magenta empty
you need to have all the toners for it to work.
May 07, 2009 | Samsung CLP 300 Laser Printer
CLP 300 toner cartridges don't have a chip
New Models of Samsung Laser printers come pre-packed with Cartridges that have no chips but an empty space where the chip should be. These chipless cartridges do not need to have a chip because the printer is pre-programmed to run for one cycle. These pre-packed cartridges can also be refilled in the same way but will need a reset chip.
Buy new chips from:
http://www.clp300.com/index.php?main_page=product_info&products_id=133
Sep 05, 2008 | Samsung CLP 300 Laser Printer
Black toner
I had the problems with white smear type fading on one side of the page , when pritning black, but colour printing seems OK. Did everything suggested in the manual and more. Changed toner. Been working on it a week.  (I got 2000 pages out of that thing).
Now I have the solution. Bin the Samsung and buy a Canon.
Lee
Sep 01, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP 300 won't print
a few seconds after turned on?
after a half hour ?
in the first case it indicates a problem most likely with the fuser.
in the second case it might be on a timer.
Aug 05, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
87 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
