Question about Samsung HL-R4266W 42" HDTV-Ready Projection Television
White spots !!!!!!!!!!!!!!!!!!!!!!!!
I see alot of people with the same problem and no one has said what the problem is.What gives????
  • 556 Answers
You might want to check out this site http://forums.cnet.com when you get there type in samsung white spot issues and then click on one of the complaints. When you get to where the complaint is take it back to page one and you might find the answer to your problem.
Posted on Sep 15, 2009
Smoking white
If you are in a cold climate it is probably just steam. Oil is blue smoke not white or steam.
Apr 18, 2017 | Suzuki Motorcycles
White spots on scanned images
First thing you should do is to check whether the original image is clean and no dust or anything.
The next one is to clean the scanner glass. Use a clean cloth to wipe the scanner glass to make sure there is no dust or anything that might reflect the light from the scanner that can cause white spots.
Please give us update regarding this issue.
Thank you,
Jack
Feb 17, 2011 | HP PSC 2410 All-In-One InkJet Printer
How do i clean the inside of the lens? there is dust on the inside and it is causing alot a little white spots to appear on the screen.
take a little paper towel make it thin and stick it in their and wiggle it arround and wiggle it around like you just dont care,. ; )
Dec 28, 2010 | Optoma PRO250X Projector
My White-Westinhouse dryer is making alot of sounds
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication
If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps
Nov 19, 2009 | GE Dryers
Is coming alot of bright spot all over the screm like a little point isee the channels whith the spot
These are failing pixels in the matrix. Eventually the screen will not be viewable.
The screen is made of millions of points of l;ight called pixels They turn on and off to create what you see on the screen. When they fail they become minute white spots.
Aug 21, 2009 | Samsung HL-S4666W Television
Olevia TV white spot on screen
U should not get such type of white spots on the screen
call ur experts..
thanks..
Feb 01, 2009 | Olevia LT37HVS 37 in. LCD HDTV
White spots
In addition, flash lighting dust doesn't make a white spot, but a fuzzy whitish circle (out of focus). The image underneath is still visible, but distorted. These are definitely not flash reflecting on dust.
Sep 07, 2005 | Panasonic Lumix DMC-FZ5 Digital Camera
Open Questions:
Samsung HL-R4266W 42" HDTV-Ready Projection Television Logo
76 people viewed this question
Jerry Greenberg
Jerry Greenberg
