Question about Toshiba TheaterWide 46HM94 46" Rear Projection HDTV
TOSHIBA 46HM94P NO PICTURE
I have the 46HM94P since 3 years ago and this is the third lamp I go thru, but this last one was oem but didnt turned on, so I opened the lamp cover loosen the screws and pulled it out a couple of mm and it worked, when it failed I just wiggled it a little and it worked again, but this last time it didnt go on at all, lamp dosnt look blowen, I checked the power harness to the lamp and I get reading of 275 DC volts, I get no continuity on the bulb, usually on normal light bulbs you get continuity thats why I checked it, my other doubt is, if I get voltage to the lamp, does that mean the ballast is ok? and might have a deffective lamp? Thanks.
Why does my Panasonic 52 inch rear projection TV make a clicking noise with no picture after turning on the power? I replaced the lamp a year ago with no issues.
You might want to look at the lamp again to see it is intact and not shattered----2,000 hours or 2 years is normal life for a OEM lamp but a generic or cheaper version lasts about a year and picture is usually not as bright as with the original ones.
Jun 12, 2012 | Panasonic PT-52LCX66 Projection Television
Have an 52HM95. Man.- 01-2006. Rent-a-center had the lamp (I believe) replaced when this happend the first time 3yrs ago. . It cost them around $200. Now 3 years later, its paid off, so, NEED HELP! (No...
The "LAMP" LED light indication on the front of the tv screen panel flashes or light up?The projection lamp was replaced 3 year ago u belive right?The average projection lamp life about 1 1/2 or 2 years.Withthin function in the tv and in used like 4 or 5 hours a day of tv viewing.Ur tv require a new projection lamp.
Sep 18, 2010 | Toshiba TheaterWide 62HM84 62" Rear...
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
I have purchased 3 new lamps. one lasted 900 hrs.
Your lamp is rated for 3000 hours. Is the fan working to cool the lamp? When you turn off the projector do you allow the fan to continue to run? If not the lamp is not cooling evenly and the lamp will fail. Th filters should be cleaned regularly and the vents be unobstructed.
May 14, 2010 | Toshiba TLPLMT70 Projector Lamp
I have a Toshiba 46hm94P. Just replaced the lamp. Now I get the TV trying to start. It will reboot 8 times, with the green light blinking 8 or 9 times while the red light is on. The TV will then turn off...
make sure the lamp cover is on because sometimes they have switches on them that turns the on when the cover is on but if its off tv might not come on. If thats not the problem then you might have a bad ballast. Call a local tv repair shop.
Jan 20, 2010 | Televison & Video
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
No picture on my 62" DLP Mitsubishi
I am not sure what the problem is, but usually if a lamp is bad, the other 2 lamps will still function. Since you are getting no picture at all, I am thinking it is a circuit board problem. TV electronics are expected to last 3-5 years. After that, many components will start to go out one by one. If you have your tv repaired, I would replace the whole circuit boards instead of just the bad component. The power board is the #1 board I would replace 1st. This is the most stressed board and will cause most of your tv problems.
Dec 06, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Toshiba dlp red light green light on and off no image
It was the lamp cover original response was right on point
Nov 29, 2008 | Televison & Video
Toshiba Ballast part number
Use the following part number: 23122468. The cost is $48.38 from TRITRONICSINC.COM
Dan
Mar 18, 2008 | Televison & Video
Toshiba 46HM94P
booboo43,
How's the lamp?? Sounds like a lamp failure which is the most likely problem with these units. The lamp for that unit is Toshiba p/n# 23311083x but a better source would be http://www.dlplampsource.com/ and they have it for $199.00 dollars with free shipping...
Nov 05, 2007 | Toshiba 46HM95 46" HDTV
Toshiba TheaterWide 46HM94 46" Rear Projection HDTV Logo
564 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
