Question about Tools & Hardware - Others
Buffer was running and just stopped - Tools & Hardware - Others
  •  Jerry
    Jerry May 11, 2010
    Difficult to resolve without more information. Assuming it is electric, have you tried the device in another outlet? Is there a reset button on the device, and have you tried resetting it? If the problem is more serious, some possibilities are: - defective switch - defective power cord - bad connection (for example, between power cord and switch) - motor may need new brushes - motor could be broken (for example, a bad winding) Please
    Brigadier General:
  • 4,090 Answers
Insufficient information to even start a solve for you....
Could be a million things here and may not even be related to the machine.. check the plug on the unit plug it in somewhere else Check the outlet plug check the fuse box. We are all out of guessing gas in the crystal ball on questions as brief as this.
Please be more specific! Brand of polisher, age, condition, did it go bqng, was there a flash etc etc!
Posted on Sep 13, 2009
Error code recording stopped. Problem with record buffer
I've done some searching this seems very proprietary, I would first try contacting the manufacturer directly to see if t hey can shed some light on this issue.
Jan 23, 2015 | Tascam X-48 48-track Hybrid Hard Disk...
Tip
How to get youtube videos to play nicely on ipad,and ipod.
WATCHING VIDEOS FROM YOUTUBE IS FRUSTRATING SOMETIMES.IT STOPS,FREEZES AND JUST GETS ANNOYING.THE SIMPLE REMEDY FOR THAT IS TO STOP ALL PROGAMS THAT ARE RUNNING IN BACKGROUND WITHOUT OUR KNOWLEDGE.TO STOP PROGRAMS PUSH HOME BUTTON TWICE AND SCREEN WILL SLIDE UP REVEALING ALL PROGRAMS RUNNING.TO STOP THEM TOUCH ANY ICON AND HOLD FOR A FEW SECONDS UNTIL MINUS SIGN APPEARS AND ICONS JIGGLE.TAP MINUS TO STOP ALL OR JUST ONES YOU WANT.THIS DOES NOT REMOVE APP ONLY STOPS FROM RUNNING SO YOU CAN STOP ALL FROM RUNNING AND RESTART APP WHEN NEEDED.I LET MINE BUFFER A LITTLE AT BEGINNING OF VIDEO THEN TAP PLAY BUTTON.BETTER VIDEO PLAY.
on May 16, 2011 | Audio Players & Recorders
While my pc is on and i am watching movie, about 15mnts of the movie, the pc stop and restarts, why?
While the processor is running, memory buffers take care of the other precesses the computer is also running while you are watching the movie. If the memory buffer is big enough, you could get to finish your movie and the computer will not stop. If the buffer is limited, when it is at 100%, the processor will no longer run and will do a restart. When you are about 10 into your movie try to see how the processor/memory are doing. It will let you know if they are saturated. Control+Alt+Delete will get you to the option where you can Start the Task Manager. This will allow you to see the processes running and the memory usage. I see in your post your memory is only 256 MB. Computers nowdays might have 4GB of Memory to run heavy graphics. That is about 16 times what you have. You might want to increase your memory.
Dec 20, 2012 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
The printer is not printing receipts and the error indicator is blinking on and off, what is the solution to this?
Flashing (approx. once every second): Out of paper
Flashing (approx. twice every second): Mechanical error (Buzzer sounds once.)
Most likely your paper feed is giving you the error. Remove the current feed, ensure there are no paper jam & insert fresh paper.
If
Mechanical Error :: Quick blinking Buzzer Sounds continuously for a pprox. 1 second :: Reset the Power
switch
Paper End Blinks.:: Buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Paper Near End Blinks.(Once a second) :: buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Mechanical Error : If the printer mechanism has a greater load due to a paper jam, etc., the buzzer will sound and the SEL/ERROR lamp will blink to stop the printer mechanism.
Paper End : If the printer has run out of paper, the paper sensor in the paper path near the print head will detect the end of the paper roll, turn on the buzzer, and blink the SEL/ERROR lamp to stop the printer mechanism. If the paper is inserted into the paper path, the paper will be loaded.
Paper Near End : If the paper is running out, the paper near end sensor will be activated to turn on
the buzzer and make the SEL/ERROR lamp blink. Even after the paper near end is detected, a command can be used to print by the specified number of lines. (See a description on the command for setting the number of print lines after paper near end detection)
Finally
Backup Data Clear : When the power is turned on, depending on the SEL switch operation, the
backup data in the input buffer will be cleared according to the flowchart on the next page.
To clear the input buffer, turn on the power while pressing the SEL switch.
The following messages will be printed.
"Clear Data in Buffer"
"Cleared Data in Buffer"
To print the data in the input buffer, simply turn the power on.
The following message is printed and the data in the input buffer is printed.
"Power Down(Data in Buffer)
Dec 13, 2010 | Citizen iDP-3550 Matrix Printer
CANT STOP OKI 591 PRINTER TO STOP PRINTING REPORT
Check that the LINE FEED button is not jamming or on.
The LINE FEED + POWER ON will print the "Printer Character Report" or "Test Page".
May 24, 2010 | Okidata 591 Printer
LG Tv 50PQ30 the lower half of the screen intermittely stops working
looking into the back of the tv with the cover removed, there is 2 boards on the far left the run down the back of the screen. These are the Ysus buffer boards.They both plug into a larger board (Ysus). Make sure that the bottom buffer board is pushed into the Ysus properly and that the wired lead connecting the upper buffer board to the lower buffer board is pushed in firmly.If this doesnt solve the problem then you will most probably have a faulty lower buffer board.
Feb 20, 2010 | SNK Magnavox 42MF231D 42 in. Plasma TV
Where do I find the buffer settings?
Make sure your desktop is fairly empty of Icons except the bare minimum system icons. Also, make sure there aren't alot of Icons next to the time display at the bottom right of your screen. If there are, close them and then try streaming video.
May 29, 2009 | Compaq Computers & Internet
I have the porter cable 7424 buffer/polisher. My problem is when you apply any pressure, even the weight of only the buffer on the car it stops spinning. You have to hold it up slightly lifting the we
The armiture has a winding problem, common in a lot of power tools. Replacing the armiture is not cost affective unless your time put into it is worth it, sorry. I recomend the Dewalt veriable speed, nice professional buffer!
May 07, 2009 | Porter Cable 7336 6 Inch Variable Speed...
Buffer overrun detected message comes up when trying to use make movie mode
you want to stop all programs that are running
start/run type in msconfig enter
when screen loaded go to startup stop all running except for antivirus reboot and try to make movie again
sometimes a virus will give buffer over runs as well try the above first
Jul 21, 2008 | Pinnacle Studio 500-PCI version 10 - video...
Real player
Your problem isnt the player. Its not downloading the video fast enough at the play speed. Try pausing the video for a while to let the buffer get ahead then play it again. You can also go into the settings and change the length of the buffer from what I remember. It should be pretty clearly marked. Hope it helps!
Sep 10, 2007 | Video Game Consoles & Games
Tools & Hardware - Others Logo
488 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
