Question about Plumbing
Hot water problem in bathtube
I get hot water out of my sinks but not my bathtube
  • 31 Answers
Make sure your hot and cold water lines arent crossed up. depending on how its plumbed in it could take longer to get to the tub then it does to the sink,
Posted on Sep 13, 2009
Hot water doesn't work
Does any water come out of the faucet when turned to hot? If not, you may have disconnected the fautet line from the valve and attached the dishwasher line. You can check this by looking under the sink and making sure all lines are connected to valves.
If everything is connected, you may have dislodged some mineral buildup and it is blocking your hot water line to the faucet. You'll have to remove the line and clean it out.
Mar 02, 2014 | Home
Rinnai R75LS error 12. I recently went to fill my bathtub and got nothing but cold water. After checking the hot water heater it was flashing 12. After looking at the book saw it meant flame failure. My...
You may have instant hots for the sinks, a small heater for each location which won't be on the tub. If there is a flame fail the hot water heater is not working. Check the flame sensor and ignitor.
Jan 07, 2014 | Water Heaters
Richmond water heater
The water inlet to the heater must be plugged.
May 16, 2017 | Water Heaters
We have a bosch tankless water heater in a 1600 sq ft home...it works great except in one faucet (the spare bathroom sink)...sometimes the hot water comes out, sometimes it doesnt, sometimes it takes...
Since you have hot water at all the other fixtures, the problem lies in the sink, not the water heater. It could be that the sink is farther away from the water heater than the other fixtures. It would take longer to get hot water.
Aug 29, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
No hot water coming out of shower, only cold, there is hot water in both faucets over sinks..Water pressure ok.
Handle for hot water is probably stripped out inside. Does the water flow from hot side when turned on?
Mar 01, 2011 | Home
I TURNED ON THE HOT WATER IN MY BATH ROOM SINK AND NOW IT WONT TURN OFF HELP
There may be a service valve under the sink. If not, there may be a valve over your water heater that you can shut off until the faucet is repaired.
Gary
Feb 24, 2011 | Home
The show is saying low flow but it isn't... there is no hot water at all whatever temperature setting you use
dawnbond I would check to see if your water heater is working first,see if sink has hot water? Then we can go from there
Jan 27, 2011 | Home
Hot water faucet on an older kohler two handle bathtub faucet only goes on slightly. Will not completely go on and can't force it any farther.
Turn off the water supply to the sink. Now remove the handle on the hot. next remove the seat. When you remove that, you should have a rubber gasket on the bottom. You can take that to any home improvement store. Your seat has gone bad. They make kits for it.
Dec 18, 2010 | Home
I have hot water in my bathroom sink,but not to my shower/bathtub all of a sudden.I went and checked the line and felt it,still plenty hot.I turned the valve off and back on,came back inside and had hot...
You don't indicate what kind of valve(s) you have in your shower/bathtub.
It is sometimes the case, when you have separate hot and cold valves that use the traditional flat washer, the rubber/viton washer wears over time and actually becomes cut, such that a part of the washer protrudes from the valve face.
Hot water will cause the distorted washer to expand. Consequently, as more and hotter water flows through the valve, the washer expands to the point where it constricts the flow of hot water.
Replace the washer, at least on the hot water valve.
Aug 11, 2010 | Heating & Cooling
I have installed a 4 gallon inline water heater close to the bathroom. The main hot water heater is at the other end of the house. Now the hot water in the bathroom runs luke warm when the washing machine;...
you don't have a circulating line in it,, there for it is pulling the hot only,, when you have the 2 systems you have to have it circulationg or take 1 out, it being it is hot water they will vapor lock,, meening no hot water , you could get a circulating pump that actually hooks to the cold and hot side under the sink far away from the water heater and it has a timer on it that will circulate the water at certain times of the day,,, this would solve your problem
Jul 02, 2009 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Plumbing Logo
103 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
