Question about Lexmark E250d Laser Printer
How to change firmware of lexmark ?or how to get firmware from the correct printer and copy it to faulty one by USB? Is there any way that is suitable for all lexmark's printer?
Lexmark s605 will not print in colour
Try updating the firmware of your printer. Just go to http://bit.ly/ghfW8H. Also, perform a maintenance on the cartridges, to do that, on the control panel of your printer, press on the Ink Levels > More Options > Deep Clean Printhead.
Make sure that you're using genuine Lexmark cartridges.
Apr 28, 2012 | Lexmark Interact S605 Wireless All-in-One...
Lexmark S405 not reconising magenta cartridge
Make sure that your printer firmware code is updated. Please visit the Lexmark website to download and install the Lexmark S400 Series Firmware Update. If more than one download is listed for your model, choose the first download in the list. If it is the wrong firmware level, an error message will tell you which firmware level is correct. The firmware update addresses the problem you mention - printer having trouble recognizing the cartridges and it will help improve your printer's overall performance.
Should the problem continue even after updating your printer, it would be best to contact Lexmark technical support center for additional assistance.
Apr 03, 2012 | Lexmark Interpret S405 Wireless All-in-One...
Cannot center printhead to remove
A firmware update for your model addresses the printhead problem you're currently experiencing. Please visit the Lexmark website to download and install the Lexmark S300 Series Firmware Update. If more than one download is listed for your model, choose the first download in the list. If it is the wrong firmware level, an error message will tell you which firmware level is correct.
Should the error continue to display on the printer screen, it could be that the printhead itself is faulty. If that is the case, I highly recommend to contact Lexmark Technical Support Center for additional assistance.
Mar 08, 2012 | Lexmark S305 IMPACT LEXS All-In-One...
Printer says problem with printerhead
Mar 02, 2012 | Lexmark S305 IMPACT LEXS All-In-One...
Lexmark 705 adf jam
If your adf is jamming while it is feeding it might be due to a broken hinge. Check out this video.https://www.youtube.com/watch?v=GaS0oKcreBo
Jan 29, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
Lexmark pro 900 will not print properly or copy or scan
There is a firmware update for the Lexmark Pro900 Series printer that addresses print quality issues. Please visit the Lexmark website to download and install the Lexmark Pro900 Series Firmware Update.
After successfully updating your printer, try to print, scan or make a copy again to verify that the problem is fixed.
Should the problem continue, it might be a printhead problem. Please contact Lexmark Technical Support Center for further assistance.
Dec 29, 2011 | Lexmark Office Equipment & Supplies
Left cartridge incorrect message after installing a genuine lexmark replacement cartridge
There are a small number of #23/#24 cartridges that are not properly recognized by the printer. Lexmark has a firmware upgrade to correct this issue. The upgrade for the X3430 is available from Lexmark at:
To install the firmware upgrade,
  1. Make sure the printer is ON and connected with a USB cable.
  2. Download and run the appropriate firmware upgrade for your computer.
  3. Be sure not to disconnect or power off the printer until the upgrade is complete
When the update finishes the printer will restart and will accept the cartridges. Please contact Lexmark support if this does not fix the problem.
This works for the X3550 and X4550 models. A similar patch is available for the X3430 and Z1420 models. See http://bit.ly/LoXxv
Jun 04, 2009 | Lexmark X4550 InkJet Printer
Printer says cartridge incorrect, but is the right one...what do I need to do?
The upgrade for the X3430 is available from Lexmark at: PC: http://www.downloaddelivery.com/downloads/misc/Firmware_F061909_3430Series.exe Mac: http://www.downloaddelivery.com/downloads/misc/Mac_MCC_J062309_01.Zip
To install the firmware upgrade, 1. Make sure the printer is ON and connected with a USB cable. 2. Download and run the appropriate firmware upgrade for your computer. 3. Be sure not to disconnect or power off the printer until the upgrade is complete
May 10, 2009 | Lexmark MFP-X3470 All-In-One InkJet...
Changed cartridge and printer says cartridge incorrect
The upgrade for the X3470 is available from Lexmark at: http://www.downloaddelivery.com/downloads/misc/Firmware_F061909_3430Series.exe
This works for 3400 Series printers. A similar patch is available for the X3550, X4550, and Z1420 models. See http://bit.ly/LoXxv
Feb 06, 2009 | Lexmark X3470 All-In-One InkJet Printer
Lexmark E250d Laser Printer Logo
302 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
