Question about Bose SoundDock Digital Music System for Apple iPod - White
Ipod does not seem to connect with the Bose sound dock base.
When placed on the sound-dock base, my classic ipod leans backwards toward the Bose unit. For a while, I could sneak small items, like the ipod cover, behind it. This would push it into more of a horizontal position, and if I prayed hard, and tip-toed away from the unit, it would usually make a connectuib. But that no longer works.
This is my pride and joy. I have over two thousand songs. The ipod plays on my daughter's cheaper speakers. Is there a new sound dock base insert that I could put in my Bose, or what would you suggest? Send the whole thing in? The Bose system is only 18 months old. The Ipod is 3 years old.
Thank you very much for any advice.
Bose repairs
It may be expensive to have someone replace the connector. One option is to squirt some silicone around the base, being careful to still allow contact to be made to the iPod dock connector. You could get a dock extension cable (see link below). It may fit better and will reduce the strain on the Bose connector. If it's still loose, you could glue the extender cable in.
Alternatively, you could use a 3.5 mm audio cable to connect the iPod headphone jack to the Aux-in jack on the back of the Bose. Just living with it may be prudent.
Amazon com 30 pin Male to Female Dock Extender for iPod and iPhone...
Jul 22, 2014 | Bose SoundDock Digital Music System for...
Tip
How to connect an iPod to my Bose Radio
<p>The manufacturer offers two radios Bose iPod connection kit to connect an iPod to the radio. You can purchase the kit to connect the wave or acoustic wave connect kit. Both kits come with a USB audio connection, an iPod dock for iPod, a battery that plugs into the wall and a remote control to use the iPod while in dock. Download all the upgrades to your iPod through Apple's website before connecting a Bose radio. <br /> <p><br /> <p>1. Connect one end of the audio cable is included with the connection kit for iPod "Aux In" on the back of the Bose radio. <br /> <p><br /> <p>2. Connect the other end of the audio cable to the "Audio Out" on the back of the iPod dock. <br /> <p><br /> <p>3. Connect the adapter to an outlet connection kit. Connect the other end of the battery to the "DC Power" on the back of the iPod dock. <br /> <p><br /> <p>4. Set the iPod dock on the right side of the face of Bose radio out. Align the IR sensor on the front of the iPod dock with the IR sensor on the front of the Bose radio. <br /> <p><br /> <p>5. Place the iPod firmly in iPod dock. Point the remote at the IR sensor, iPod dock. Press the "iPod" for the iPod <br />
on Aug 09, 2011 | Apple iPod touch
Ipod classic 80GB makes a horrible popping noise with sounddock II
Sounds like there might be a loose connection between your iPod and the dock. Firstly make sure there is no dust or grit inside the female 30 pin of the iPod. Also make sure that there is no grit or dust around the male end on the dock. If there is grit or dust (or even if there isn't, some compressed air (you can buy this in a can) will help to clean out the connection. Also make sure that when you dock the iPod, it is seated on the dock properly. You should be able to see if it isn't seating properly. If this doesn't fix it and you are near an apple store, I would recommend taking the problem to them where they will be able to make sure that the iPod isn't causing the problem.
Nov 30, 2013 | Bose SoundDock Digital Music System for...
Is it possible to connect an ipod to a Bose V20 via a minijack?
You can only Connect a iPod via a iPod dock
Apple iPod Univeral Dock
and use either
Apple Composite AV Cable or Apple Component AV Cable
based on what Output you iPod Allows.
the list of which iPod that is supported is listed on each page of the AV Cables above.
You can use a IR Blaster Cable with the iPod Dock to control the iPod also.
May 28, 2011 | Bose Lifestyle V20 System - black Theater...
Bose sounddock portable problem
You can now order a new PCB for the Bose Sounddock PORTABLE at http://www.chargeconverter.com/store/sounddock/portable_repair
Jul 11, 2010 | Bose SoundDock Portable Digital Music...
Bose SoundDock burned out two of my iPods - a Nano and a classic.
um ur sounddock might require that u place the white docking piece that came with ur ipod to be place b4 the ipod is docked if not u may ruin the dock and the ipod usb port this is done because different generation ipods(nana and touch and ...) have different shapes so the entrance for docks may require to be eleveated or reduce in gradient basically if the dock isnt made for the specific ipod or u dont know just put the white piece in
Oct 04, 2009 | Bose SoundDock digital music system...
Bose Portable sound dock remote not working with iPod Classic
I have the same problem with mine. Called Bose Belgium and waiting for answer but it seems there's nothing to do.
Wait and see
Sep 21, 2009 | Bose SoundDock Digital Music System for...
Ipod classic 80gb won't charge
If it's over 5 years old, it won't work. Sorry budd
Dec 07, 2017 | Bose SoundDock digital music system...
How do I connect my iPod to Bose Lifestyle V20 System
and use either
Jan 04, 2009 | Bose Lifestyle V20 System - black Theater...
Old Dock New iPod (won't always charge)
http://www.griffintechnology.com/products/firewire-to-usb-converter
Just bought it, haven't tried it - seems to be a very cheap and easy solution!!!!
Jul 12, 2008 | Bose SoundDock digital music system...
Bose SoundDock Digital Music System for Apple iPod - White Logo
119 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
