Ativa DQ120D shredder
Unit continues to run. How do I get it back to working normal.
  • 1 more comment
  • boborina May 30, 2008
    how do you clear the sensor. no way to get a toothbrush in there to clean it. I even tried a q tip, no way man
  • edcrain Aug 16, 2008
    Ativa XF50D Unit runs constantly. This happened in the first couple of months of service. Opened unit to discover the each bay (shredder, pencil sharpener, letter opener) has its own infra-red sensor duo. Cleaned unit (these really pack away the scraps) including sensors. No help. Shined flashlight on each sensor (unit opened and safely poised). Lighting pencil sharpener sensor stopped operation. Realigned sensors here and got some results. Not perfect though. BRILLIANT concept. Iffy execution.
  • comunitycent Aug 28, 2008
    Hello, My DQ120D would keep running then, it stopped working. I looked under, and the blades are full of paper, compressed paper. I could get some out but I can't move the blades and can't seem to remove them. HELP HELP ME PLEASE mjpagosa
I had the same problem with my Shredded. In the centre of the paper feed slot is a little sensor that detects when you put paper in, it breaks some sort of light beam that is connected to the motor circuit.
Over time paper dust gathers on this sensor, covering it completely and fooling the machine to think that there is ALWAYS a piece of paper being fed into the shredder, the result being that the motor just runs continuously.
Clear the dust from this sensor and you'll fix this particular problem - a toothbrush worked great for me - don't use it to clean your teeth afterwards :-)
FIXYA!!!
Posted on Jan 16, 2008
I have an Ativa AT-MC1010S shredder that started running constantly. At first I just used rubbing alcohol and a Qtip to clean the optical sensors in the paper feed. But then that didn't stop it, so I took one of those cans of compressed air and sprayed around the sensors in the paper feed and that took care of the problem. Probably a build up paper dust after 2 years that needed to be blown out.
Posted on Nov 07, 2010
Ativa shredder X1800 - shredder does not respond. green light present. Reverse works fine. I killed it with too much shredded paper.
Unplug it. Lift the shredder unit off the catch-bucket. Remove any paper caught in the blades. You may need needle-nose pliers to pull jammed paper out from between the cutters.
Aug 22, 2016 | Office Depot Ativa X1800 Shredder
What is the red light next to the green power light? It appears to look like a temperature light. My unit won't run.
In most cases it means the shredder is full or something is jammed. Empty the shredding container. If the machine has a "reverse" position on its switch, try running it backwards to get whatever is jamming the teeth to come back out.
Nov 03, 2014 | Ativa MD1250 12-Sheet Cross-Cut Shredder -...
My Ativa HD Pro 1800 will not power on
First check the power point is still working - plug in another appliance, like a table lamp. If OK check the fuse in the shredder cable plug.
The commonest reason for a shredder stopping is a paper jam, or running the shredder for too long. By 'too long', many shredders will cut-out after 5 minutes continuous working, and the sensor may take 15 minutes to cool down! Read the manual.
It maybe that the shredder cutters are jammed. Unplug from mains, and lift off top and place upside down. Use a small screwdriver and/or long nosed pliers to poke at any compressed paper wrapped around the blades - can take a while.
It may be that the sensors are dirty - use a cotton bud dipped in rubbing alcohol to clean the sensor light(s) and heads
Give a quick spray to cutters with WD40 Replace - turn on - and run in reverse.
May 21, 2014 | Ativa HDM PRO 8000 8-Sheet Micro-Cut...
Dead no noise
First check the powe point is still working - plug in another appliance,
Mar 15, 2014 | Office Depot Ativa DQ60M Shredder
Just purchased ativa MD 460C and it will not work. misaligned is highlighted. can u help solve problem?
The misalignment message is about the catch bin and the shredder! NOT THE TEETH!
Check to make sure the shredder is properly placed on the catch bin. There is a built in safetymechanism in the Ativa MD460. When the shredder is replaced "backwards" the safety pin is not tripped.
Look for a curve in the lip on the back of the shredder and align it with the bin. Worse case, just pick up the heavy shredder top, turn the unit around 180 degrees and put back down. My light came onimmediately.
Jun 16, 2011 | Office Equipment & Supplies
I have an Ativa MD 460 shredder, it is misaligned with paper. Can you help?
ativa md460 misaligned Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your ativa md460 misaligned question. Get free help, tips ... I have an Ativa MD 460c paper shredder that reads misalignment. What do I do?
www.fixya.com/support/t9496803-just_purchased_ativa_md_460c
Jun 16, 2011 - Look for a curve in the lip on the back of the shredder and align it with the ... I have an Ativa MD 460c paper shredder that reads misalignment.
Ativa MD460 paper shredder: misalignment light is on - Fixya
www.fixya.com/.../t7580117-ativa_md460_paper_shredder_misalignme...
Jan 1, 2011 - I have a Ativa MD 1000 that I just bought. It ran for a few minutes the first time I used it an then stopped. I turned it off and unplugged it in case it had ...
Office Depot Ativa DQ60M Shredder Misaligned - Questions ...
www.fixya.com > ... > Office Depot Ativa DQ60M Shredder
just purchased ativa MD 460C and it will not work. misaligned is highlighted. can u help... I have an Ativa MD 460c paper shredder that reads misalignment.
Jun 07, 2011 | Office Depot Office Equipment & Supplies
DQ83M ATIVA SHREDDER ...LIGHT IS ON BUT DOES NOT SHREDD
The RUN green light is on but no motor is operating for any function of the Ativa DQ 83Mn Shredder. What can be inop?
Sep 17, 2010 | Office Depot Ativa DQ60M Shredder
Something is jammed
I was able to unjam an ATIVA DX 180 D shredder now the shredding blades won't turn but the motor is running.
Jan 08, 2008 | Office Equipment & Supplies
Ativa DQ120D
The mechanism is overloaded. No doubt from debris inside. need to to tak it apart, clean it all up, relube, and reassemble.
Dec 31, 2007 | Universal Office UNV-38961 Shredder
Ativa shredder
Pull out as much of the paper as possible. Then spray some window cleaner or similar on whats left to soften and disolve it.
Dec 29, 2007 | Office Depot Ativa DQ60M Shredder
974 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
