Question about HP Photosmart C6180 All-In-One InkJet Printer
Setting up wireless connection to network
I do not know how to set up the printer to my router so I can print on both of my computers on the wireless network, please assist
  • cherylmullen Dec 12, 2007
    Cannot setup my HP Photosmart C6180 on my wireless network
  • Anonymous Dec 14, 2007
    Recently set up a wireless network and can not figure out how to send documents from the laptop to the printer
    Sergeant:
  • 239 Answers
You have to set up a network and then make sure workgroup name is all same and make sure when you set it up you allow for printing on the network, Now when you go to print make sure the computer, the printer is hooked to it, and the printer is on, Now go to your control panel, Open your printer and faxes. on the left hand side it will say add printer, Click on that, Now click next, Now you want to select. " A network Printer, Or a printer attached to another computer". select that, and follow the directions windows will find the printer and install drivers so it should work after that, I sure Hopes that this solution fixes your printing problems. U All have a Happy Holidays, And if this don't work write back here and we will try something else. bear001
Posted on Dec 15, 2007
Can i hook up my printer to my wireless router and if i can how do i tell it to print when i need it to print
The iP6310D can't connect to the wireless router directly. It has a USB port and an optional blue-tooth receiver.
If you connect the printer to one computer, you may be able to share it using that computer as a server. Install the printer software on all of the machines. For the software, see http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_ip_series/pixma_ip6310d#DriversAndSoftware . For Windows 7 and 8, if you set up a Homegroup, enable sharing for the printer on the computer that it is directly connected to. Then use Add a Printer command from the Devices and Printers Control Panel option to locate networked printers. For other OS options, you'll need to make sure that the computers are in the same workgroup. (See the Network set-up information.) Then add a network printer.
If your wireless router has a USB port, you may be able to connect the printer to the router. Again install the printer software on each computer. Then use the router's software to add a printer on the computer. (For Linksys routers, that is the Cisco Connect software. Some routers may not offer this software for all OS's or for all printers.)
A similar option is a print server connected to the USB port of the printer. You will need to check the specifications for each one. There are some that only work on select printers.
Once the software (the printer driver and then the network software/shared printer is set up), then any program should be able to print following the File > Print command.
Please add a comment with your OS and/or router model, I'll try to walk you through setting up a shared printer or a USB connection on the router.
(Note: I have a USB printer connected and a wired network printer to a Cisco router. My only issue is that I get a printer error with every print job. The printers print the documents anyway. The error is due to the printers not responding to the software as fast as if it were a direct connection.)
Aug 10, 2013 | Canon PIXMA iP6310D InkJet Photo Printer
Can i hook my printer to this router Linksys wireless-g 2.4ghz
You want to connect a printer to the network.
If you have Ethernet port on the printer then you can connect it to the router with the ethernet cable. IF it is wireless printer then you will need to connect to the wireless network on the printer. In both the cases you will need to set up your printer as a network printer. If you contact the manufacturer of the printer they will tell you how to do it.
If you do not have ethernet port on the printer and it has only USB port and it is not a wireless printer then you will need a print server. You can purchase a wireless print server and you can set it up so that all the computers will be able to print onthe same printer.
If you have only the USB port and you don't want to use print server, then you can connect your printer to one of your computer. Enable File and printer sharing on all the computer. If you go to microsoft.com and search for file and printer sharing, you will get steps to enable file and printer sharing.
If you want to check the wireless settings of the router, you will need to open the set up page of the router .
Click here for more information about router and networks
Mar 21, 2010 | Linksys Wireless-G WRT54G Router
Epson sx510w prints using a cable but can't get it to print wireless
The specs for your model Epson allows you to connect the you network by wireless and by LAN cable.
The specs are as follows :-
Wi-Fi Wireless LAN IEEE 802.11b/g – compatible with 802.11n*
*Transmission rate will be limited to 802.11g and will operate in the 2.4 GHz frequency band
Ethernet Wired LAN IEEE 802.3 (100BASE-TX, 10BASE-T)
Other PictBridge
Wireless security
WEP – 64bit
WEP – 128bit
WPA – PSK (TKIP) – compliant with WPA2
WPA – PSK (AES) – compliant with WPA2
To connect the printer by a LAN cable you need to configure the Epson for an IP address that suits your network configuration and connect the LAN cable to your wireless router/hub.
The reason why you cannot print using wireless is because the wireless configuration in the Epson is not setup with the router's wireless configuration ie. SSID WPA encryption etc.
For instructions of setting up a LAN network printer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
For instructions on setting up a wireless printer, the Epson wireless settings need to be configured with the router's wireless settings. Go into your router's wireless and note the SSID, and encryption settings etc and configure the Epson's wireless settings with the router's wireless settings. This will allow the Epson to connect to the wireless router. Please click on this link for instructions to secure your wireless network, configure the wireless router (if you have not already do so) and configure the wireless card in the computers and wireless printer (the instructions for configuring the wireless card in the printer is the same as for the wireless card in the computers via the printer's menu screen).
http://www.fixya.com/support/r3559128-wireless_router_security
Feb 07, 2010 | Epson Office Equipment & Supplies
I have changed my wirelss router toa Linksys and now need to set up wirelss printing from my HP6110. how do I do this? The new wireless router is a WRT310N.
You will need to check the wireless settings of the
router
is there any computer connected to the router ?
If yes then you can open the router set up page on
that computer.
Router set up page is the page where you can check
all the wireless settings of the router.
IS your printer wireless or it is connected to the computer.
If printer is wireless then you will need to connect to the wireless network.
If it is connected to the computer and you want to share the printer then you will need to enable the file and printer sharing on all the computers.
Click here for step by step instructions
Jan 23, 2010 | HP Computers & Internet
Can I connect my 2wire to my printer to print wireless, if so how?
router
that computer.
on your printer there will be settings of network connection.
you just need to connect to the wireless network on the printer
Click here to know more about routers
Jan 10, 2010 | 2wire HomePortal 100W (1000-400026-000)...
Need my laptop to communicate wireless to printer
If the printer does not have a built-in network card/print server then there is a couple of ways to do this.
If you have a desktop computer connected to the wireless router with a LAN cable, then connect the printer to the desktop computer and make this printer a shared printer on your network. This means that the desktop computer and printer needs to be on when you want to print from the laptop.
The other way is to purchase a print server, connect the printer to the print server and connect the print server with a LAN cable to the Wireless router.
If you don't have sufficient network ports on the wireless router then you need to purchase a hub. Then connect the hub and wireless router with a LAN cable and then the print server to the hub and other computers to the hub.
Setting up the wireless printing will depend upon which method you want to adopt and I can advise you when further when you are ready.
Aug 02, 2009 | HP Photosmart 3310 Printer
DO NOT REMEMBER SSID NAME GIVEN TO ROUTER WRT54GS---LOST PRINTED COPY OF SET-UP. HOW CAN I REPRINT OR JUST FIND OUT INFO
You can see the SSID name from one of your wireless computer that is already connected to the wireless network. Just point your name over the wireless little computer icon down at bottom right hand by the time. It will say there "Wireless Network Connection, Connected to "name of the network". That "name of the network" is the wireless signal name like "Linksys" or whatever name you gave to your network when you setup the router. That's the SSID name as well. Wireless Network Name = SSID.
Aug 27, 2008 | Linksys Wireless-G WRT54G Router
NetGear PS121 Print Server Problem
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
For the print server setup, please follow the steps below:
Note: Before setting up the print server, make sure that you can print when printer is connected directly to the computer.
1. Wire the print server to router. Check the lights on it. It should have the ACT light on and the Error light off.
2. One way to test if the printer would work with the print server is to reset the print server for 3 to 5 seconds while it is powered on and after you release the button, the printer should automatically print the IP address of the print server.
Note: If the printer did not print, there is a possibility that they are not compatible. However, you may still continue to try to set up the print server.
3. Install the PS121 software.
a. Power on your computer, let the operating system boot up completely, and log in as needed.
b. Insert the Resource CD for the PS121 into your CD-ROM drive. The CD main page shown at the right will load.
c. Click Install Software.
d. Click Next and follow the software installation utility prompts to complete the software installation.
e. When prompted, restart your computer to complete the installation.
f. When your computer restarts, click Finish to run the Print Server Setup Wizard.
4. Run the Print Server Setup Wizard to Set Up a Fixed IP Address for the PS121.
a. The Print Server Setup Wizard screen should be displayed.
b. Click Next to proceed. The Print Server Wizard will now search your network for the PS121. If the Print Server Setup Wizard cannot find your PS121, check the network connections and status lights on the PS121.
c. The “Server Name” and the “IP Address” your network assigned to the PS121 are displayed. Click Next to proceed to the device name screen.
d. You can enter a descriptive Device Name and Domain Name or accept the defaults. Click Next to proceed to the IP Address configuration screen. The Print Server Wizard displays a recommended static IP address setting for the PS121. This is usually fine.
e. Click Next to proceed.
f. Click Finish to exit the Print Server Setup Wizard. This completes the configuration of the PS121 for operation on your network.
g. Click Yes to run the Add Printer Port Wizard. Follow the instructions in the next section for using the this wizard to set up each computer to use the PS121.
To set up each computer to use the PS121, please follow the instructions below:
1. Use the NETGEAR Add Printer Wizard to set up each PC to use the PS121.
a. When the Print Server Setup Wizard finishes, you are prompted to run the Add Printer Port Wizard. Click Yes to proceed. Alternatively, from the Windows Start menu NETGEAR Print Server program group, you can run the NETGEAR Add Printer Wizard.
b. After a short delay while the software searches the network for your PS121, the Printer Select window opens and displays the PS121 you have set up.
c. Click Next to proceed to the Port/Printer name screen. Take note of the printer model number listed.
2. Set up the correct printer driver for the printer port.
a. Click Next to proceed to the Port/Printer name screen. Take note of the printer model number listed.
b. Click Next to proceed to the Select Printer screen. If you see the exact printer model number listed as the printer model number from in the previous screen, click it to select it from the list.
c. If prompted, print a test page to verify operation of the printer and the PS121. Then, close any remaining Add Printer Port Wizard or Windows Add Printer Wizard windows.
Use the NETGEAR PS121 Mini Print Server Resource CD to run the Add Printer Port Wizard to set up each PC on you network that you want to use with the PS121. Select the port you added
You may also use the links below as your guide to troubleshoot the print server:
http://kbserver.netgear.com/kb_web_files/n101269.asp
http://kbserver.netgear.com/kb_web_files/n100033.asp
However, if this does not resolve the issue we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
1. Model number of router
2. Model of printer
3. Operating system of computer/s
Apr 26, 2008 | NetGear PS121 Print Server
Wireless printing
Hi, Through what method would you connect the printer to the netgear? I have looked at the information on both products and the netgear has no Print Server and the Printer has no Ethernet or wireless. If your printer has no ethernet or wireless and your router has no print server then the answer to your question is NO. HOWEVER: You can install the printer on any one of the pc's and then set it up as a SHARED PRINTER. If you would like further information on doing this please let me know and I will post it here. Thanks
Aug 21, 2007 | NetGear WGT624 Wireless Router
HP Photosmart C6180 All-In-One InkJet Printer Logo
69 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
