While using a headset, the volume will increase randomly until it is maxxed out. I have tried different ports and two new headsets of different brands. Why is my computer increasing the volume? It functions as normal while using the desktop speakers..
the volume control for the headset is typically the same one you use for the phone. plug the headset in again & use the volume control to increase/decrease volume as you require, remove the headset and use the same volume control to increase/decrease the volume on the device..
try uninstalling and re-installing the headset. Plug the USB connector into an available external USB port on your computer or laptop. On most computers, drivers install automatically and your headset will be ready to use. Note: On windows, if you are prompted with the Add New Hardware Wizard, follow the steps to download and install the driver.
For any audio issues: Plug the USB connector into an available USB port. • Check your computer's volume level. • Check if your computer's volume is muted. • Check your operating system's audio input and output settings. • Check the headset's volume and mute settings. • Restart computer.
you may want to try this: #3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though. for the headset volume, if your headset is the type that has volume controls or, check the side panel of your phone, try pressing arrow up to increase volume, arrow down to decrease, or go to the settings of your phone, look for headphones then volume
Try resetting your headset by pressing power key and volume up key, until the LED flickers in different seqence. after a while try connecting with your device. it should work.
There is no option provided with sony ericsson headsets to increase the volume as only one button is there in it which is meant to use for attending and disconnecting calls only. But you can increase/ decrease volume and go to next/previous tracks,if you are using a compatible blue tooth headset with your mobile.
Volume adjustment is made by depressing the two + and - together until beep is heard
once beep is heard press the + button several times until louder bleep is heard this will increase transmission from headset and cure the problem
Hi Ihenski If your USB cable is sure to be working try increasing your phone's volume or betterstill increase the volume of your earphones if it has one, if problem persists get new earphones.
