Question about Canon Pixma MP480 All-In-One InkJet Printer
Printer will not print, please help
I have a lexmarkz12 printer.having problems printing.it shows installed, but it will not print?
  • 25 Answers
Have you tried printing from within the Printing software for the printer in control panel? Click on "Print test page" and see if it will print. If not, go to the color management tab and check that it shows enough ink in each color. If there is one that is too low or has a yellow yield sign on it, it won't print and you will need to reinstall that ink after you verify that it has enough of that color. Make you you installed the CD first before you connect the printer or it won't install correctly. If you did that you will need to uninstall and reinstall again after restarting each time.
Posted on Sep 13, 2009
Dell 5100cn Error cod 010-397 Restart Printer
ahmad, does the printer show as default? if not make it. Try test print and make sure all printer compartment are securely closed.
Jan 11, 2014 | Dell 5100cn Laser Printer
Printer does not print test page
Go to devices and printers, select the printer with check mark with right click of mouse. First check if the printer shows as default printer. If not, make it. Try test print.
Dec 22, 2013 | HP DeskJet Office Equipment & Supplies
HP 5600 printer won't print
Is your HP printer having printing problems due to incorrect printer configuration and driver installation? For the quick tech assistance, you can also go to the Printer USA Support, which is an online directory, offering the certified HP toll-free number that is helpful to directly get in touch with the technicians and get your printer problems repaired in no time. HP Printer Tech Support Phone Number HP Printer Help
Apr 26, 2017 | HP Officejet 5610 All-In-One InkJet...
I connect the konica minolta bizhub 210 to my win xp system then i try to print but i can't the system show the message "failed to print" what is this .please help me
SOLUTION:- Follow these steps. 1-First of all take a usb cable. 2-Connect its one end to Bizhub 210 and the other end to your computer. 3-you will see your computer will show a notification " Found new hardware". 4-Now insert the printer Driver disc of Bizhub 210 in CD-ROM. 5-autoplay will show at the desktop 6-Now click on "Install Printer" 7-Follow the instructions and install the drivers. 8-when the drivers are correctly installed you will see printer icon of bizhub 210 in "Printer and Faxes" at control panel of your computer. 9-Now right click on this icon and click on "Properties" 10-now click on "PRINTING PREFERENCES" tab. 11-select Paper size, i.e if you are using A4 size in bizhub 210 then select paper size=A4 from the list. 12-now give a print command.ctrl+p. of any document. 13-printer will start printing.
if still having problem, then please do check the usb cable, it may be broken. if there is any other printers are installed on your computer which are not in use then remove them/ delete them. use konica minolta bizhub 210 as a default printer.
Jun 28, 2010 | Konica Minolta bizhub 180 All-In-One...
I have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error...
By deepak_compu on Oct 06, 2009
i have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error show,but print not come. and when i print a test page from printer button it gives print. but on paper write like this toner exhoasted so what i do for this problem please give me soltuion of this problem
Oct 06, 2009 | Samsung ML-1640 Monochrome Laser Printer
Unable to print on printer Dell 926 -test page prints ok
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
May 23, 2009 | Dell 926 All-In-One InkJet Printer
Hp 3325 printer printing test page and not printing other pages
PREM
Apr 06, 2009 | HP DeskJet 3325 InkJet Printer
Canon PIXMA MP160 Printer
This probbly some problem with the connectivity check your cables and try reinstalling the printer driver, check whether your printer is detected by your computer.
Good luck
Feb 18, 2008 | Office Equipment & Supplies
Nothing will print
5 times The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 / 1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on. This might help
Mar 10, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon Pixma MP480 All-In-One InkJet Printer Logo
60 people viewed this question
old marine
old marine
