7kg J845 frontloader keeps leaking water even
7kg J845 frontloader washing machine keeps leaking water even after the filter has been cleaned
  • 636 Answers
Check and see if the float moves freely , could be sticking and causing too much water to enter the dishwasher.
Posted on Sep 13, 2009
I have a samsung 7Kg J845 front load washing mechine, when i turn on, water not fills enough ( only water fills couple of seconds after stops flows. the error shows 4E, Then i clean up all mesh filters...
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 08, 2010 | Samsung WF203ANW Front Load Washer
My LG 7kg frontloader intellowasher WD8013F is leaking from underneath and no water is going into the washing machine. Please help?
i removed the filter off the front of my lg intello washer to clean and now it keeps leaking water from the filter what have i done ?
Jul 12, 2010 | LG Washing Machines
J845 Samsung FrontLoader, no longer spins, makes a whirring sound, but nothing, just stopped; cleaned out everything according to the owner's manual.
if you are sure of whirring noise, then the motor is fine. check the drive belt that connects motor and drum
Mar 19, 2010 | Washing Machines
I need a manual for a Samsung 7kg Front loader washing washine model number J845
I googled the make and model of the washing machine and it bought up a site that had manuals that were in PDF form and I printed it from that.
In fact I got the manual for the washing machine, oven and microwave.
Nov 12, 2009 | Samsung Washing Machines
Please help! My samsung 7kg J845 front loader keeps flashing UE on the error code (spin cycle) and I can't open the door. Sarah
Hi, I have the same washing machine and it flashes UE on the error code during spin cycle when I have one thing in there, or if the clothes are uneven. I usually have to wait until the lock light goes out, re-arrange the clothes and continue spin cycle. If it is just one item in there, I usually have to manually wring it out as it will keep saying error if I keep trying to spin.
Oct 22, 2009 | Samsung WF337AA Front Load Washer
My clothes smell horrible with my Ge frontloader. I have tried he detergent, cleaning the parts, bleach wash, leaving the door open. This is very frustrating considering how much it cost and the...
Make sure there are no leaks from the machine. look behind it and check the water inlet hose and connectors for any damage. Also look under the machine for any water as this may indicate a leak from the internal hose and pipe work and / or water pump. Also check that the outlet hose is completely clear of debris and soap scum build up and check that the filter is clean.
To keep the machine clean of waste build up and to keep any bad odours away
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Sep 30, 2009 | GE WSXH208A Front Load Washer
Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Sep 30, 2009 | Samsung Washing Machines
Our samsung j845 front load washing machine won't
You have a blockage in the drain pump or sump on the machine, it could be anything from a coin, bra wire or an elastic band, best thing to do is switch off the electricity and incoming water, remove as much water from the machine as possible, pull machine out place a suitable container below the drain filter and then open up the filter (if fitted) once cleaned check hoses and drain pump internally for blockages.
Sep 07, 2009 | Samsung WF337AA Front Load Washer
Over loaded the macine
Have you tried unplugging the machine for a minute to reset it?
Dec 09, 2007 | Washing Machines
Washing Machines Logo
428 people viewed this question
Top Washing Machines Experts
