Question about Dell Dimension 3000 PC Desktop
I have a Dell Dimension 3000 desktop, around 5-6 years old. It is connected to the internet through a cable modem then through a wireless router, but it is connected with a LAN line. If I try to connect to the internet, it finds no connection, although it recognizes that it is connected to the internet. I have two wireless laptops that can still connect fine, no problems, and I even tried connecting the ethernet cable directly to the desktop, bypassing the router, and another ethernet cable, no luck.
    Novelist:
  • 148 Answers
First, try uninstalling then reinstalling the ethernet device. If that fails,try replacing it. Ethernet cards can be found for around $25.
Posted on Sep 13, 2009
    Guru:
  • 830 Answers
Sounds like the actual ethernet adaptor (hardware) may be out but first I would run a really good spyware and see if it is infected. This one works really great (see link at bottom) although, it is not free but you can download, installl and it will run scan and tell you if you have malware (which is why it will not connect). It only cost 30 bucks to purchase which is reasonable to take off the malware and get back online. Beats a techs fee.
If there is no sign of malware, then the hardware is out and you will need to replace. These can be purchased at Wal-mart for under 60 bucks. Hope this helps!
http://www.enigmasoftware.com/
No internet when adding switch between modem and router
The router controls and assigns IPs. Configuration goes from ISP modem to router to switch.
Mar 20, 2013 | Zyxel Communications Zyxel GS105B Desktop...
My Dell Dimension 4600 won't connect to the internet and has a solid orange internet light, help?
go into internet options and connections and tell it to never dial a connection see if that helps
Jul 12, 2012 | Dell Dimension 4600 PC Desktop
Can't get router to connect to Dell Dimension 2400 desktop
Try turning OFF DHCP from services. This may fix your problem. Look for "DHCP Client", double click on it (or right click and choose properties), STOP the service, then set it's startup type to 'manual'. That'll kill it. See DHCP is what "Gives out/assigns addresses" and on the ONLY PC, it is the First one... 192.168.0.1... Both PC's will be assigning themselves as that, and that will cause a conflict. As the Router now does the DHCP work. Of course ensure you DO have DHCP set on router.
Feb 12, 2010 | Dell Dimension 2400 PC Desktop
Can't access internet without unplugging modem and router
as long as your modem has the internet light your modem should be fine.. for the router you might want to configure it to option IP Address automatically and distribute dhcp automatically..if it doesnt work try to update your router's firmware best thing to do is to get a new router ..
Dec 30, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 4700C Desktop PC, internet issue.
Try and test the computer and modem connection by hooking it up directly by an ethernet cable..
If the internet connection stays solid when cabled up..
Then try either changing or removing the wep or wpa encryption on your wireless network, and seeing if that allows the computer to stay connected.
Also try disabling the firewall on your computer, and also on your modem.
Oct 30, 2009 | Dell Dimension 4700C PC Desktop
Internet no longer working, but internal network is fine.
i agree with all the above.. it's definately clear as mud how the network is designed and or funtioning. The machines connected to the wireless d-link router.. are they via cat5 inthe wired ports or wireless ? is the server the machine thats connecting to the switch and wiress router and modem? i'd say reset all switches modems routers and machines.. shut them all down.. then fire the cable modem, then the wireless router then the desktop switch then the server, the workstations and the one lonely wireless.. run "ipconfig /all" on all machines and if they aren't all sharing common ips and access, provide the results here for further investigation.
May 20, 2009 | Dell Dimension 2400 PC Desktop
Connect Laptop to PC desktop which has cable connection.
YOU WILL NEED TO GET A WIRELESS ROUTER TO BE ABLE TO USE THE LAPTOP WIRELESS, iT IS A VERY EASY SET UP AND CONNECT THE DESKTOP WIRED AND THE LAPTOP WIRELESS TO A WIRELESS ROUTER.
May 06, 2009 | Arris SURFboard SB5120 Modem
Wireless router with dimension 3000
It seems that you have Dell Desktop computer, unless you requested a wireless card to be put into the computer, it would not come with one. Just like stang_1 mentioned, you should check your network adapters to see if your wireless card is listed. Also since it is a desktop, you can check the back of it to see if you have an Antenna sticking out of it. That would indicate that you have a wireless card on the PCI slot. And if that is the case and you do not see it listed in the network connections, check the Device Manager and make sure that the drivers are installed properly.
Apr 14, 2009 | Dell Dimension 3000 PC Desktop
Dell dimension 3000 won't see wireless network
Hi, I've jst been looking on the web at the Mimo routers, you may find this article interesting, it may help even though its a couple of years old?
http://www.behardware.com/articles/614-2/wi-fi-mimo.html
Pay attention to part about 802.11n compatibility?
Perhaps try changing the IEEE standard on the router to 802.11g in the set up pages, as it may be set at 802.11n, which your older wireless card will not see.
As to the acquiring ip address message, try using a static ip address, here's a good guide:-
http://portforward.com/networking/static-xp.htm
Maybe this will help?
Jan 27, 2009 | Dell Dimension 3000 PC Desktop
Have internet connection but browser won't open
try pinging google.com from the problem pc.
  1. Go to START
  2. Go to RUN
  3. Type in CMD [hit enter]
  4. IN the dos window, type : ping google.com
  5. hit enter.
If your pc can reach google, it will ping back 4 successes
I would install and run spybot from spybot.com. That is a spy-ware checker program and is free.
Post back with results.
Dec 17, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Logo
169 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
