Question about Toshiba MD19N1 19 in. TV/DVD Combo
Remote stopped working
Tried new batteries and new remote. No reaction from TV
  • 934 Answers
Replace the IR detector on the main board...
Bill
Posted on Dec 11, 2007
The remote control sensor on the TV has stopped working
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Regards.
Jan 09, 2012 | Televison & Video
Remote stopped working so I cant use the tv what can I do I was trying to set the firect tv remote and could not get it to work. After I tried that the remote to the tv would not work anymore. I tried...
your best bet is going to be contacting rca and having them send you out a new remote alot of the universals have a 50/50 chance of having the needed frequency so I try to say away from them
hope this helped
Robb
Apr 22, 2010 | RCA RCU600M Remote Control
My remote control has stopped working. The remote
hello. You might want to try a universal remote. If that works, then your remote is bad. Hope this helps.. Ron
Sep 08, 2009 | Televison & Video
My polaroid tv remote isnt working
Get a new remote or try it again with new batteries.
Aug 17, 2017 | Polaroid 1720-7 Remote Control
Samsung DVD r135 no reaction using remote control but recorder reacts on remote control from Samsung TV, batteries check. Disconnect the recorder from the power over night no change, still own remote...
Try this. Remove the batteries from the recorder's remote control and hold down the POWER button on it for 30 seconds. Then replace the batteries with fresh ones. It should work fine after that.
If not, the remote control may be defective.
You can purchase a new remote control at www.samsungparts.com
Mar 01, 2009 | Samsung DVD-R135
Remote for tv not working
go to the shop you got it from and ask for a new remote:D
Jan 03, 2009 | Beko 324250WN 28" TV
Remote does not work
Remote stopped working - I bought a universal remote Phillips / Magnavox used a code in the 400 range and everything worked. Hope this helps.
Aug 08, 2008 | Zenith IQB50M90W 50" Rear Projection...
Refuses to work
you are going to have to try a new universal remote because that one is not capable of programming to your tv. not all universals will work. trial and error. your best option sense you need to purchase a new remote is to go to www.replacementremotes.com and search my your TV model number and purchase the original equipment manufactured remote for your tv. Good news you wont have to program it either. and it will work your menu functions.
May 28, 2008 | RCA RCU410MS Remote Control
No response from remote
Remote problem could arise from either tv or remote. First check your universal remote on some other tv and if it is okay your tv's infrared sensor has stopped working. You can get it from the local component shops, take the existing sensor with you. This problem could be from the micro processor in rare cases. Best of luck.
Jan 27, 2008 | Panasonic CT-32SL14 32" TV
Toshiba MD19N1 19 in. TV/DVD Combo Logo
87 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
