Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
My machine is leaking from the bottom of the machine. Hoses in the back are ok. but i'm afraid to run it
    Problem Solver:
  • 15 Answers
You will have to open the top of the washer.
take a flat head screwdriver and place it at the seam area around the washing machines rim, the front should lift up from some clips that hold it down, look down inside for any corroded hoses or signs of water leaking from pressed hose fittings.
if there is no leak signs at top of washer then you may have to take the back cover off and look at the bottom for signs of water stains or corrosion.
replace hose if tightning it doesn't work. run the washer with panel off so you can spot leaks.
Posted on Sep 13, 2009
WHEN I TURN ON WASHER WATER LEAKS FROM BOTTOM OF WASHER
Hello there and thank you for choosing fixya
This can be a fairly easy repair normaly the problem is that the hoses at the bottom of the machine will wear out or loosen up over time and will need to be re tightened or replaced so what you will need to do is to pull the machine out about 4 to 5 ft from the wall and lean the machine back so you can inspect the hoses annd the drain pump you will be able to see where the water has been leaking from cause there will be residue on the parts that are leaking and on the floor where it has been leaking
Then all you have to do is to repair the leak meaning tighten up the hose clamp or remove and replace the hose if needed ok now if the pump iself is leaking then you may have to remove the pump and see if any thing on the pump is broken and replace that part as needed ok?
Hope this helps
Best regards Mike
May 16, 2011 | Washing Machines
I have a LG front load washer seem to leaking front area. Hoses OK Need o see what causes it to leak
you will need to narrow down where the water is leaking from. under the door...? behind the bottom drain door..? underneath machine..? behind machine..? leaks can be found in many areas.
May 16, 2011 | LG WM-2277HW Front Load Washer
When we switch our Beko DE 2541 on its running straight away with the stop/start button being pressed. On the last successful cycle completed it just carried on making a noise like it was running and has...
sounds like you have a water leak. The machine is fitted with a leak detection device that runs the drain pump constantly as a safety mechanism. If you want to look your self you will need to pull the machine out and tilt it back and if possible remove the bottom panel, should be 4 screws, this gives you access to the components. Then see if you can see where the leak is coming from. Hope this helps.
Feb 23, 2011 | Beko Dishwashers
Water leaking from bottom of machine however I cannot find a leak when inspecting from the bottom with the machine tilted back. Fisher & Paykel model GWL11. I have not been able to determine when (...
Hi just read your posting.Now have you checked for the leak where the drain hose comes out of the case of the machine? It is located at the back top left of the machine.Have you checked the inlet hoses at the tap end and the machine end?Rub the inlet hoses with your hand from the tap to the machine on both hoses to feel if there is any water on them.Check the nozzle under the lid where the water comes into the machine to see if it is not loose or broken.Please reply and let me know how you got on and If you need further help.Looking forward to your reply.
Sep 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Creda W220VW front loading washing machine leaking from bottom of casing. Hoses seem OK, coluld filter need cleaning? If so, how do I access?
Check water flow rate into soap drawer , if very fast water can overflow and run down back of fascia panel and out underneith
Nov 01, 2009 | Creda W120VW Front Load Washer
Amana washer leaking water from the bottom, has not been used in 2 days? It is not constant water leak, I can soak the water up with a couple of towels and then about 8-12 hours later the water is back...
is this with the machine off the entire time or running the machine? if it is with it off check your water hoses for tightness see if the gaskets are leaking or the hoses are leaking, if its after you run it and then it loses water check the water pump and water pump hose and hose clamps. without some more information I can't help you beyound that.
Jul 23, 2009 | Washing Machines
Speed queen washer leaking & won't pump out water .....
water level sensor could be faulty, but it shouldnt leak from bottom, may be loose hoses or cracked drum if plastic. try this though, a hose/ sensor line running from tub to the top lid may have popped off , which would explain the two problems. after removing as much water as you can , til the washer on its side and check all hoe connections. if all is good, pop off top lid and check connections there. sometimes the strong motions of a washer pop out hoses or break the plastic nipples right off.
Jul 09, 2009 | Washing Machines
Water leak
Hoover HW160M Service Manual Page 4
This shows all the hoses, You also can see the part numbers related to the hoses on the back pages.
Aug 05, 2017 | Hoover HW6 160M Front Load Washer / Dryer
Leaking water coming from underneath washer, after water fills. draining, and spinning fine, just leaking water all over the place.
ok there are 2 screws that hold the front panel on. they are at the bottom. take them off then take the panel you can see inside. ckeck hoses.be carefull if you run the machine there is a gearcase that spins if you hit it while its running you can break your arm.
Nov 03, 2008 | Frigidaire Washing Machines
Leak
remove bottom panel 2 screw ckd pump and connecting hoses ckd drain hose in particular then have been known to crack
Jun 03, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
139 people viewed this question
Dan Webster
Dan Webster
Sal De
