Question about Betty Crocker Coffee Makers & Espresso Machines
Need a temp shut down device for a coffee maker Don't know what the part is called. It is marked 240V-10A-214 C. It stops the element from getting to hot (214 Cel.) radio shack used to have them but can't find them. This part is common in all brands of kitchen counter drip coffee makers. It might be a type of diode (?) When they burn out the coffee maker wont heat up. Whenever a coffee maker doesn't heat up It's most likely this part. Does anybody know what it's called and where I can get one?
    Scholar:
  • 35 Answers
I believe you're looking for a thermal fuse or thermal cutoff.
In the EU or UK, try: maplin.co.uk
In the US, try: www.digikey.com or www.action-electronics.com/fustherm.htm
You might also try contacting a manufacturer directly:
http://www.thermtrol.com
Posted on Sep 13, 2009
Testimonial: "Right on!!! Thanks to Polymath5000, & FIXYA. Once I had the correct name (Thermal fuse) I was able to locate the item on e-bay and order it. "
The urn stops perking after about three minutes - coffee is not brewed
2 points of failure
A) Heater Element - Open Circuit or Wire Broken (Corrosion at crimp(s),
B) OVER Temp Thermostat OVERLOAD.
IF the element does not get hot enough (The amount of power (measured in Watts) consumed is not close to the Nameplate rating, then the element is weakening inside.
IF it stays cold, then it is gone completely, however you indicate that after 3 minutes (the usual time??) the brewing stops.
MOST designs have a water heater fused to a "Hotplate" type warming pad.
There are two temperature sensitive valves built into the flow of water. A Low Temp that closes when the water is about 30c. A HIGH temp valve that opens at 70C. Between the two valves, the water gets heated to 90C then pumps over the drip basket.
Along the way, is an OVER TEMP that trips at 105C, and stops the heater function (After the coffee is brewed, and the reservoir is empty.)
Jun 08, 2015 | Coffee Makers & Espresso Machines
How can I fix my Keurig Coffee maker? It pumps water from the time it is turned on 'till it indicates add water. Any suggestions?
either the heating element has failed or a thermal overheat trip device or thermal fuse has failed
you need to use a meter and see if the heating element is getting AC power
perhaps the pump actuator usualy a relay or a triac device has failed and gone short or fused contacts ....
hard one to diag from words only
Dec 04, 2014 | Keurig Coffee Makers & Espresso Machines
Cuisinart DCC-1200 brewing temperature
Hello ditommm,
Not to worry, I think I can help. On the face of your DCC-1200, there are two black switches. The right one adjusts the carafe temperature. With the white line to the left you get a lower carafe temperature. With it all the way to the right you get the highest (hottest) temp. Of course, in the middle, you get a medium temp. I use mine with the lowest temp so that I don't end of scalding my lips and tongue when I drink my coffee. Use this bit of info to adjust your carafe temps. If you are looking to cause the actual brewing temp I don't know of a way to do that. Coffee needs to be brewed at the set temp in order to break down the elements of the ground coffee. I hope this is what you were looking for in an answer and that it is helpful. If it is, please consider leaving positve feedback for me. I will certainly appreciate it. Good luck! Regards, NormanZ
Jul 07, 2009 | Cuisinart DCC-1200 Coffee Maker
Heating Element Shuts Off Very Early
Reset the timer for shutting off the hot plate, instructions are in the user manual.
Jan 31, 2009 | Cuisinart DGB-300 Coffee Maker
WEAK COFFEE & NOT HOT ENOUGH
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Dec 22, 2008 | Bunn NHB Coffee Maker
Coffee maker parts
need a heating element replacement for model cm 500 coffee maker. How much does it cost? Mark
email to mmtazzy @yahoo.com
Sep 01, 2008 | Coffee Makers & Espresso Machines
Temp.
Occasionally with a Bunn you have to add some extra water. Remember when you first got it and you had to add water so that the tank is always full? It may be also that you need to turn down the temp. I need your model number to look for your manual, unless you have your manual? That is where we are going to find the answer. The model number could be on the back but it may also be on the bottom. Let me know.
Aug 25, 2008 | Bunn NHB Coffee Maker
Leaking from the water Chamber
The Krups heats the water through a horseshoe shaped aluminum tube which the heating element is wrapped around the tube in the same fashion, the tube is corroded or cracked most likely, if you poured cold water into the machine when it was hot, this will crack the tube, they are made by Cesod ? which is stamped on the element with a number on it,  and I have seen between 700 and 1100 watt elements. I have the same problem with my 7 year old krups coffee maker, Im trying to repair the tube with aluminum welding or find a new element.  It could also be the high temp tubing may be cracked.  You need tamper proof Torx bits to remove the bottom cover on some models.
Jan 21, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Coffee pot warmer is not working
I called Cuisinarts repair center and they had me set my auto off button. It had been set to 0 so it shut off as soon as it started brewing. If you turn the switch to auto off, then when the numbers are blinking hit the hour button until you get the desired hours you want the heating element to stay on. Then when you stop hitting it it will remain at that time after you brew your coffee. If that doesn't work you can call the help line at 800-726-0190, just give them your model number and serial number, the device carries a 3 year warentee
Nov 14, 2007 | Cuisinart DCC-1200 Coffee Maker
VRP
Thermal switch in the burner is defective. You can take it apart and replace it. You have two possibilities here. If you take it apart, you will either need to replace the temperature control switch completely. You will see a part number and mfg name on the switch. See you can find an electrical store near by that has them. Or, there may be a seperate "high temp thermal switch" on the burner element. Don't know that particular design but either way it sounds like the thermal swich is not letting the burner shut down ans cyclt as it should.
Jul 14, 2007 | Bunn VPR Coffee Maker
Coffee Makers & Espresso Machines Logo
107 people viewed this question
Top Betty Crocker Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Betty Crocker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
