Question about Bernina Sewing Machines
Keeps on running as soon as it is pluged in foot pedal dosent seem to do anything
  • 980 Answers
The suppressor has blown usually in the foot control, if you can undo the foot control and take out what looks like a fuse the machine will run perfectly, if the suppressor is on the motor then you will need to take it in to a repair shop because in that case it would have to be replaced, the foot cointrol suppressor does not have to be replaced.
Posted on Sep 13, 2009
Could a missing bobbin case keep a Bernina 1000 from running? It turns on, and the hand dial works, but foot pedal doesn't run the machine
no a bobbin case won't keep it from running, there may be a problem with the foot control, or the plug that you plug the foot pedal into may have a problem, may need to have the machine check along with the foot pedal
Mar 18, 2016 | Bernina Sewing Machines
The foot pedal gets hot after a few minutes
It sounds as though the foot pedal is the problem. Maybe a shorted out wire in the actuator (rheostat). When your foot is off the pedal there should be no power running through it. If it has a short then it "thinks" the pedal is partially depressed to the slow position so runs at that speed. If the pedal can be removed/unplugged from the machine, do this and see if the machine stops running.
Sep 07, 2015 | Sewing Machines
My janome feedomatic compact sewing machine gone's wild. As soon as i plugged it on,itautomatically runs at full blast! Can anyone tell me what's wrong? I cant see any auto buttons on
unplug the foot controller to eliminate it as the problem ,however if the machine does not run like mad as soon as you switch it on
without the foot pedal then you have isolated the problem to the foot pedal,it could be stuck on full speed .
Len..
Oct 14, 2014 | Janome Sewing Machines
Why does my Pfaff 7550 keep sewing when foot pedal is released?
there is something wrong inside..probably an intermittent short circuit on normally open switch.need to open it and clean it..
Jun 17, 2014 | Sewing Machines
Motor runs unaided, have to turn off power to stop it
Is the foot pedal not returning to the off position? Try disconnecting the foot pedal. If the machine stops running, then your problem is in the foot pedal. If it keeps running, then your control board is bad.
Mar 19, 2014 | Husqvarna Rose
Designer 1 foot pedal won't work
Have you tried using another Designer 1 foot control? It is more likely that the problem is a loose connection at the machine. Do not cut anything apart on the foot control unless you are certain that is where the problem lies.Take the machine in to an authorized dealer and have them test it for you. Find out EXACTLY what is not working. No need to buy a foot control and find out that the connectors on the machine are not properly attached.
Dec 29, 2011 | Husqvarna Sewing Machines
A 1968 BROTHER SEWING MACHINE. PROBLEM IS THE FOOT
The carbons in the ceramic tube normally break away, you should not have any problem if you have a new foot control,
Feb 15, 2010 | Sewing Machines
As soon as i turn it on, the needle starts moving up and down even though i don;t have my foot on the pedal at all.
as you turn on the motor starts running. but when you press pedal there is a clutch that engages. probably the clutch keeps engaged. clutch needs to be set to engage on pressing pedal only.
Nov 06, 2009 | Singer Sewing Machines
Model 6010 Won't Stop Sewing
I would say that is the computer in hte machine
Jul 18, 2008 | Husqvarna Viking 1
Sewing Machines Logo
171 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
