Question about RTO Automatic Transmission And Engine Oil Pressure Tester
Hi, I have a 2000 holden vectra 2.2l s/w, has been
Hi, I have a 2000 holden vectra 2.2l s/w, automatic has been to auto trans shop, and they say oil fill of filings which causing valve to stick, solution being $4000 to fix. Any ideas, why there are filings are in there, and does this mean a new gearbox?
thanks for any advice most appreciated. They have done a service, put in clean oil, is going ok now, but driving it little as possible, i cant afford to fix it at that price.
  • 143 Answers
Filings caused by miss alignment of shaft/ bearings. Probably be ok wiuth oil changew and filter. Go for it. If it fails buy another trans from a wrecker out of a smash for a lot cheaper. Vectra is euro import. Best fix would be trade in while running ok.
Posted on Sep 13, 2009
Testimonial: "Wow thanks so much, really value your advice,much appreciated."
Where in New Zealand can i buy a holden vectra octopus hose
2001 Holden Vectra Reviews - Carsurvey.org
www.carsurvey.org > Holden > Vectra
  1. Cached
  2. Similar
Aug 4, 2016 - 2001 Holden Vectra GL 2.2 from Australia and New Zealand ... 'Octopus' coolant hose blew. This is stupidly designed by some idiotic engineer ...
PartsWorld : Holden Vectra Parts - Right Parts, Right Service, Right Price
https://partsworld.co.nz/parts/holden/vectra
  1. Cached
  2. Similar
Not logged in ( login ' register ). PartsWorld is New Zealand's Largest Auto Parts Recycling Chain ... Holden Vectra Parts - Select a Series. help. Don't know your ... Missing: octopus
Search Results for radiator hose js vectra - Telstra Media Search
search.media.telstra.com.au/?location=&searchIndex=australia...hose...vectra
  1. Cached
  2. Similar
Products 1 - 20 of 103 - TBAP Radiator HOLDEN Vectra JR/JS 2.5L/2.6L 6Cyl Auto . ... /catalogues/hose-application-catalogue-aus-nz-october-2012.pdf.
Holden Vectra Heater Hoses ' Sparesbox
https://www.sparesbox.com.au/vehicles/holden/vectra/heater-hoses-category
  1. Cached
Shop Holden Vectra Heater Hoses online at Sparesbox Australia. FREE Shipping on orders over $50. Missing: zealand ‎octopus
Too expensive to repair - what next? - Servicing - Automotive ...
forums.whirlpool.net.au > Automotive > Servicing
  1. Cached
  2. Similar
Jan 5, 2011 - Rather than scrapping, get the bottom hose fixed (Should be like ... If you do end up buying a new car, always buy japanese or commodore/falcon. ..... Holden vectra, If it is V6 vectra i can tell you right now it wont be the head gasket. .... broadband · Regional · Last century; International: New Zealand ISPs.
Holden ' Car parts & accessories ' Trade Me
www.trademe.co.nz > Trade Me Motors > Car parts & accessories > Holden
  1. Cached
  2. Similar
Holden for sale in New Zealand. Buy and sell ... Holden Commodore VL, Manual steering Rack & Inter shaft .... Holden VT-VZ Front Electric Window Regulator.
New Zealand can buy holden vectra octopus hose Google Search
Nov 11, 2016 | Holden Cars & Trucks
My 1999 holden vectra goes drives in morning 2 hours lata no gears at all what do i check
Do you have a manual or automatic transmission in the vehicle?
I assume it is automatic and in that case all you can do yourself is check the level of the automatic transmission fluid if you have the engine bay auto transmission dip stick and filler tube in that model.
I doubt low transmission fluid is the problem though but check it anyway and do it when the fluid is warm/hot.
As it is, you need to get the car to Holden service or to a competent auto transmission specialist to run some tests on the transmission. If it is a 1999 model you no doubt have a high kms vehicle and the auto transmissions on these cars will often not last the life of the car and need to be replaced at some time after 140000 kms or so.
Dec 08, 2015 | Holden Cars & Trucks
Does my holden Vectra 3.2 v6 have a oil cooler
If it is an automatic transmission it will have an oil cooler in one of the radiator tanks. The fix is a new radiator unless you can find a radiator shop that is prepared to remove the tank and fit a new cooler core.
Jan 01, 2015 | Holden Cars & Trucks
Tensioning timing belt
Timing belts usually have an automatic (spring Loaded) adjuster. Usual replacement is done at 100,000 k or 60,000 miles. If you do not replace it you run the risk of it breaking which could do damage to the engine. refer to your owners manual.
Aug 30, 2014 | 1999 Holden Vectra
Holden jackaroo petrol 2000 model 3.5 auto
Not until you have done all the necessary checks. Check that the oil is bright cherry red and not tan. Have a pressure test done on the transmission to check for internal faults. Have the fault codes read to check for transmission faults (TCM ) check oil level. Remove the pan and clean out the filter./ If there is band and clutch pack linings in the filter then you may have to have the box overhauled.. If not adjust the bands and clutch packs . After all the checks are done then and only then should you consider a replacement transmission and only from accredited transmission shops
Feb 22, 2014 | Cars & Trucks
Hi...tyre pressure for holden vectra 2001 ?
The correct tire pressure should be listed on the driver's door post, in the trunk, glove box, or under the console lid. Until you can find out what the correct pressure is run 30 PSI is all 4 tires.
Apr 20, 2010 | RTO Automatic Transmission And Engine Oil...
Jdm 1996 honda prelude SiR (4ws) BB8, tiptronic, h22a, 2,2l
any codes? the trans computer will store them. also the engine computer this is an obd2 car autozone can scan for free
Sep 19, 2008 | 1996 Honda Prelude
RTO Automatic Transmission And Engine Oil Pressure Tester Logo
596 people viewed this question
Top RTO Measuring Tools & Sensors Experts
jdthefixer
Vuk B
Bill Boyd
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
