Linksys Router
Problem for Linksys (WRT54GC) Router
Won't stay connected
By djpierret on Sep 13, 2009
When I set up WEP encryption on my router, I can only maintain an internet connection for a few minutes on my networked computers. If I use WPA or disable, there is no problem. (Unfortunately my adapter for the XBOX can only use WEP.) Any ideas why I can't get a stable connection?
Solution #1
posted on Sep 13, 2009
Not Rated)
dbucyk
Rank: Wiz
Rating: 84%, 78 votes
Check in the XBOX settings to see if the TCP/IP settings are 1500 or 1514. (1514 is the default for TCP/IP)
Did you go through the encryption settings for WEP? There should be a setting on the router that allows gaming to pass through it.
Also, if the XBOX is encrypted in WEP, what length of key are you using. WEP is naturally unsecure (about 10 minutes on the internet because it is a static key), but that's all it can do.
Also, if there is a firewall setting through the router, check to see that it doesn't scan encrypted connections. (This can be even in the internet security).
Outside of this, there is not much else that can be the problem.
It's either the router settings or the Internet security package that you installed.
Was this helpful?
Yes
No
Popular Solutions for Linksys Router
Questions and Unsolved Problems for Linksys Router
Do you recommend Linksys (WRT54GC) Router?
Answer
Answer
3G-6200n cannot connect to my broadband
Answer
Does the WRT54GC allow SSL connections? I'm trying to setup a mail client on the iPod Touch that... (More)
Answer
Broadcom 802.11b/g WLAN, WIRELESS, ON MY LAPTOP SHOWING DISABLE, I AM TRYING TO MAKE ENABLE BUT ITS... (More)
Answer
Hola me podrian alludar a ponerle un passaworld a mi sistema?
Answer
Hi, I have a HP pavillion dv600 laptop and a dell inspiron 6000. HP being a new laptop and the main... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Linksys Router:
Top Router Experts
Rank: Guru Guru
Solutions: 3671
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
