Question about LG DLG5988 Gas Dryer
Drys sometimes my husband took it apart and the second stage to the thermostat does not come on the 1st stage the ignitor does but when it goes to the second stage it shutts the gas off
  • LG Master
  • 8,220 Answers
Posted on Sep 15, 2009
How do I change out the thermostat?
first remove battery cables, second drain radiator, third remove the top hose on radiator it is where the hose that goes to the motor, is where the thermostat is you will need a new on and gasket after all done put back in order that you took apart
Jan 09, 2015 | 2003 Chevrolet Impala
Sorry, yes, the ignitor comes on and then shuts off. When first started, there is a glow at the bottom of the dryer and it goes away within seconds. As far as the noise - I believe that it is the...
Well your fuse is good and your cycling thermostat is calling for heat, your ignitor is fine because it glows and the flame sensor is doing it's job because the ignitor is fine. The only other components involved is the solenoid coils. They sometimes will work a bit then get hot and quit. Very hard to diagnose. themobilian_3061.jpg
Oct 25, 2011 | Dryers
I am trying to install a thermostat and I am not sure where to put all the wires... it is for american standard freedom 90 two stage - furnace and air conditioning
Should be like this:
Y from furnace goes to Y on thermostat (yellow)
C from furnace goes to C on thermostat (usually blue)
G from furnace goes to G on thermostat (green)
W1 (first stage heat) to w1 on thermostat(white)
w2 (second stage heat) to w2 on thermostat (black)
Doesn't sound like you have a heat pump but if you do "o" will also have to be connected which is the reversing valve.
Jun 21, 2011 | Heating & Cooling
My whirlpool duet electric dryer won't heat up. Everything else seems to be fine. My husband replaced the cutoff and thermostat. Any suggestions
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 15, 2010 | Dryers
Drys too slow
heatman101
Aug 28, 2010 | Whirlpool LER7646E Dryer
Instead of the heating element turning on the heat pump runs out side thermostate is not set on eheat
The heatpump is your 1st. stage heat, when you have a call for heat it will bring on the outdoor unit.
When the first stage heat can't heat the house and the indoor temperature drops 2° or 3° then 2nd. stage heat will kick in and maintain the house temperature at about 2° or 3° below the temperature setting.
If you outdoor unit fails or goes into defrost then emergency heat will kick in and keep the house at 2nd stage temperature approximately 2° or 3° below thermostat setting.
If you have an outdoor thermostat or balance point setting on outdoor board, it will shut the outdoor unit off at a certain set outdoor temperature and the 2nd stage heat will be primary heat for the house.
Jan 05, 2010 | Heating & Cooling
Steam button on iron has stopped working yet iron still heats up and light on boiler still goes on.
this just happened to us & the electronics man at my husband's plant took it apart & said the thermostat needs replaced. the wires were all eaten up so to speak
Jun 10, 2009 | Rowenta Steam Generator DG050 Iron
Dryer does not dry clothes. Flame does not stay on
run dryer for 10 minutes then remove vent hose see if start working mean flame on for while, if it is then you need to clean your vent system.
May 01, 2017 | Maytag Atlantis MDG7400AW Gas Dryer
Rheem Furnace sometimes takes a couple of ignition cycles before
Try cleaning the flame sensor. It is located right besides the last burner. Looks like a thick piece of wire. Take steel wool and gently remove the carbon that has built up. Should only take 4 or 5 strokes. Let me know how it goes after that. ken
Dec 23, 2008 | Heating & Cooling
First and second scuba regulator
The scuba regulator has two parts: a 1st stage and a second stage connected by a hose. The 1st stage connects right to the tank; the 2nd stage is the contraption behind your mouthpiece. Both have an important function in regulating air flow throughout your scuba system.
Dec 01, 2008 | ACCO Brands Apollo Bio-Filter Moisture...
LG DLG5988 Gas Dryer Logo
75 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
