Question about Poulan Garden
Poulan pp3816av gas cap leak - Poulan Garden
  • 31 Answers
Try a cork or rubber O ring in the cap
Posted on Sep 13, 2009
Gas cap tight and now will not close
What your saying is the gas cap is tight and still leaking gas?
Check the underside of the cap to see if the rubber gasket is missing.
it may of fallen off
Jul 11, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Picture sketch
'Bogging down' Incorrect fuel air mix, fuel starvation or air leak.
Jul 31, 2013 | Poulan Pro Chain Saw 38cc, 16in. Bar,...
I have a poulan self propelled push mower and the gas is leaking out of the gas cap while it's running.
if it is running out around where the cap screws on then you need to chack the rubberizes ring around the inside of the gas cap
Sep 15, 2012 | Garden
Poulan Pro PP3816AV does not start
try and run it without the muffler there is a screen inside that plugs up if ok with the muffler off open it up and clean the screen off
Jul 06, 2012 | Poulan Pro PP3816AV 38 Cc 16" Anti - Vib...
I have poulan woodshark 38cc chainsaw. i need to know if it is a gas/oil mixture and if so what is the mixture
I would say yes. Most are and I would get a small bottle of two cycle oil and mix it to one gallon of gas. Most hardware stores sell the oil.
Aug 06, 2011 | Poulan Pro PP3816AV 38 Cc 16" Anti - Vib...
Poulan 21cc weedeater - starts but won't stay running. I've cleaned all fuel lines, cleaned plug and has plenty of gas - but still won't start. runs for 2 or 3 seconds and dies. appears to not be getting...
On these types of motors that could be the problem, another thing to check is the primer bulb. I have had a primer bulb that had a small crack in it which went undetected for a while. These types of motors do not have a fuel pump and they work on a siphon type mechanism, if there is an air leak dealing with the gas tank anywhere, that is your problem.
Aug 11, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Idles fast, won't cut wood, stalls under load
Clean the fuel filter, air cleaner and muffler if clogged. Check all fuel lines for condition--replace any with original rubber lines--not plastic. The carburetor sounds like it could use a thorough cleaning and re-kit. It's somewhat common for saws to leak some bar oil over a long period. Good luck!
Jun 11, 2010 | Poulan Pro PP3816AV 38 Cc 16" Anti - Vib...
No oil on chain
Oleg; Is this your saw? There is no breakdown for the oil pump the entire assembly is <$9, and the worm gear that drives it was <$1.
A link to a Poulan PP3816 Gas Saw Type 2 follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP3816AV-Gas-Saw-Type-2/75.PP3816AV-Gas-Saw-Type-2.1.59.1.html
If the link is not your saw it can be found here.
The IPL (exploded parts list) for your saw is the only detail for the oil system and it is sketchy at best. Oil components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 01, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
My gas poulan chainsaw model# pp3816av wont crank or get fire at the sparkplug and leak oil in case bad from the bar
the firing part try new sparkplug [plug must be grounded] still not firring disconnect one wire from on off switch purviservin@gmail.com
Jul 10, 2009 | Garden
Garden Logo
288 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
