Question about Plumbing
Newly installed white-rodgers zone valve works for a while then eventually moves to manual (or open) on its own. Suggestions on how to keep valve in a closed position? Chris in Alaska
  • 99 Answers
Please check the link for troubleshooting:
2 wire zone valve: http://www.white-rodgers.com/wrdhom/pdfs/06_Cat_pages/Cat_06_pg0299.pdf
3 wire zone valve: http://www.white-rodgers.com/wrdhom/pdfs/06_Cat_pages/Cat_06_pg0298.pdf
If the valve fail the test you must change the motor head.
Also chcek the wiring of your thermostat to the zone valve.
I hope this information help. :)
Posted on Oct 10, 2009
  • 54 Answers
This problem has to be in the way the valve was wired. Wrong zone valve-Normally open instead of normally closed-power interuption causing valve to open. Faulty T-stat/ Most likely wired incorrectly.
Posted on Sep 13, 2009
Schematic white rodgers 13a03112 zone
Try a plumbing supply store(not home depot) or try contacting whites rodgers and ask them for schem
Nov 08, 2013 | Plumbing
White rodgers 1361 troubleshoot
Next valve you sweat in, make sure you remove the valve stem, or use heat dissipation paste to not get the valve too hot.
Oct 25, 2013 | WHITE-RODGERS DIV White Rodgers 1361-102...
Connecting 2 wire thermostats to white-rogers type 1311 3 wire zone valves
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. Make sure to connect a thermostat that will power open and powered closed the zone valve. I pretty sure that the two wire thermostat that your going to connect will not be compatible. To better assist you with this further contact us directly at 18002842925.
Oct 15, 2012 | Heating & Cooling
White rodgers zone valve will not shut off by thermostat. you can shut off heat manually.
if this is a 13a zone valve it will have the wires in the front with a bunch of little holes for the wires. try to push each wire into there holes because sometimes they come loose and stop the valve from opening and closing. let me know how this works for you.
Dec 20, 2010 | Heating & Cooling
Model 1f90w-51 the up down buttons stopped working this is a white-rodgers
Electronic Digital Multi-Stage Thermostat 1F83-261
  • 1F83-51 - White Rodgers Installation and Operating Instructions Thermostat 1F83-51
  • 1F86-344 - White Rodgers owners manual Thermostat 1F86-344
  • 1F86-444 - White Rodgers Installation and Operating Instructions Thermostat 1F86-444
  • 1F87-251 - White Rodgers Thermostat 1F87-251 OPERATION INSTRUCTIONS
  • 1F87-51 - White Rodgers Installation and Operating Instructions Thermostat 1F87-51
  • 1F89-11 - White Rodgers Installation and Operating Instructions Thermostat 1F89-11
  • 1F90-51 - White Rodgers OPERATION GUIDE Thermostat 1F90-51
  • Hi, This is a good stat and I have used it alot in the past as it is a older model. If you have 24 volt control voltage at the stat, and the battires are good, then you have a malfuntion in the ciruitry and will need to replace it. I have sent you a ton of manuals on there products I thiught they may be helpful. Please dont forget to rate this post as I know you will be kind. I hope I have been of help to you.
  • Sincerely,
  • Shastalaker7
  • A/C, Heating Contractor
Sep 22, 2010 | Heating & Cooling
Burner lites but goes out after 2 or 3 min.
the white rodgers gas control needs to be replaced;
the way it works is: the thermocouple opens the pilot gas circuit and, holds it open
when it heats up by creating a magnetic field in the gas control then: when you turn
the knob on the gas control to "on" a valve inside the gas valve opens the main gas circuit and, electricity supplied by your RV keeps it open.
the main gas coil inside the gas valve is defective and, can not hold the main gas circuit to the burner open anymore.
Jul 24, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Replacing WHITE-RODGERS manual thermostat with 3 wires ( red, white, blue and installing Honeywell electronic thermostat RTH110B, how do I connect it? The heating is not central, baseboard heating.
I have only seen one Honeywell thermostat that would work with a 3-wire heating system.
I would replace it with a White-Rodgers 1F80-0471. They are about $100, but they are a good thermostat, and they work well with the 3-wire zone valves.
Most other thermostats have the "Y" terminal that you need, but do not control the zone valve correctly.
Helping Hands Services
- Fairbanks, Alaska -
Jan 30, 2010 | Honeywell Electronic Programmable...
White Rodgers main gas valve operation.
pleas follow the troubleshooting page 9, 10 and 11
Dec 10, 2009 | Heating & Cooling
3 wire white rogers zone valve operated by 2 wire thermostat any one have a wiring diagram?
It is technically possible use a 2-wire thermostat with a 3-wire zone valve, but you need a single pole, double throw relay like a fan control relay with one normally open switch and one normally closed switch. 2-wire thermostats only have one switch that is normally open. 3-wire thermostats have two switches......one switch that is normally open, and one switch that is normally closed. The fan relay lets the 2-wire thermostat simulate a 3-wire thermostat. It's possible, but usually it's easier to just get a 3-wire thermosts.
Sep 06, 2009 | Heating & Cooling
Plumbing Logo
242 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
