Question about Maytag MDE6000 Dryer
No heat my maytag mde6000 style f keeps blowing cold air. what could be the problem?
  • 35 Answers
Probably just the heating element. If that isn't it, you might have a bad moister sensor. It tells the dryer to stop heating once the clothes are dry. My first suggestion is to check the heating element, they go out all the time. Usually there is just a tall narrow cover of them, so you can check them without disassembling the whole back of the dryer. Goodluck
Posted on Sep 13, 2009
Maytag dryer model 6000AYW overheats
Probably due to a bad blower wheel. The wheels on these are made of plastic. Over time the wobble out and don't blow enough air.
Home movie of repair:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 15, 2012 | Maytag MDE6000 Dryer
Why is my dryer blowing out cold air?
It sounds as though you have a defective heating element.
May 31, 2012 | Maytag Atlantis MDG7400AW Gas Dryer
My everstar blows hot air out the back and cold air in front i want all cold air
this style unit needs an exhaust hose attached to the rearand be placed out the window to exhaust the heat that is removed from the air in the room, you will also have to empty the condensate drain bucket when it gets full.
Jul 23, 2011 | Fedders Portable Dual Hose Electronic...
I have a MAYTAG MDE6000AYW Series Dryer. It does not heat up, it makes no noise, tumbles, and the lights work, what can I do to solve the no heating problem with the dryer?
the heating coil needs fixing you can fix it yourself but try a repair man first allot of them come too your home and fix them so choose your repair guy wisely...
Apr 12, 2011 | Maytag MDE6000 Dryer
No Exhaust? Very Damp-not dry clothes
i would check for further blockage. also check the blower fan to make sure it is blowing properly. sometimes the blower fan can wear on the motor shaft and slip, thus reducing the air flow considerably. sometimes i have found the blockage just at the point of the blower fan.
good luck; jay
Jan 04, 2010 | Maytag MDE6000 Dryer
Blows cold air , it still spins, but doesnt heat up.
Is this a condenser dryer or vented?
On the condensers, if the water collector is full it will only blow cold air. Sometimes the water pumps that bring the water to the collector bottles can go and it makes the dryer think that the bottle is full, therefore it will blow cold air.
Hope this helps!
Aug 13, 2009 | Maytag Dryers
Maytag dryer MDE6000AYW keeps blowing the fuse in the panel box, what is wrong? I reset the fuse in the panel box and turn the dryer right back on and it will start right back up. It may or may not blow...
Bad breaker in the panel box.Loose wires at the breaker. Loose connection in the wall outlet. Loose connection at the dryer cord terminal. Bad cord.
One or more of the above.
Jul 05, 2009 | Maytag MDE6000 Dryer
Blows only cold air
Check connection to heating elements. My have bad heating elements
Jan 19, 2009 | Maytag Neptune MDE6800 Electric Dryer
Maytag dryer MDE6000 is only blowing cold air.
Electric dryers run on 220 volt, it is usually a double breaker at your main panel, however, depending on the electrician and how old the wiring is you might have two breakers, so start there first. If not, there are several parts to this dryer. It could be an element, a thermal fuse, high limit thermostat, or as simple as a burnt wire. Most important please turn off power before working on this.
The other thing that most people forget to check is the outlet pipe or vent pipe. If they get blocked, when the heat turns on, and it is blocked, the dryer will detect it and immediately turn off the heat but the drum will still turn. Bed Bath and Beyond has a dryer vent clean out kit that hooks to a shop vac.
Jan 09, 2009 | Maytag MDE6000 Dryer
The dryer only blow out cold air.
When I turn the dryer on, only cold air blows out. There's no heat. I cleaned out the vents? What do you think is my problem> Thank you very much. K
Oct 18, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
112 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
