HP Compaq Presario SR1720NX  PC Desktop
Problem for HP Compaq Presario SR1720NX (EL435AA) PC Desktop
Noisy computer fan
By ersh2000 on Sep 13, 2009
noisy computer fan
Solution #1
posted on Sep 13, 2009
Not Rated)
bob_computer
Rank: Guru  HP Computers & Networking  Expert
Rating: 87%, 1493 votes
This would indicate that the computer is overheating.
I would look at the cooler first.
It does sound like an overheating computer they are designed nowadays to shut themselves down if there is a problem
What you should do is check the fan assembly If you see a build up of gunk and debris then get yourself a can of compressed air used for cleaning computers and take the unit outside.
Whilst wearing glasses use the nozzle on the can to blow out any debris from the CPU and power supply.
If everything went to plan you should now be back in business.
Another consideration is that many cases have places in them for extra fans and usually extra connections on the motherboard too.
They are quick and easy to fit.
Quite often I will fit TWO in what is called a push/pull configuration. One pulls cool air in while the other pushes hot air out.
These will not only help keep the computer cooler but also cleaner
Was this helpful?
Yes
No
Solution #2
Not Rated)
jennifer720
Rating: 90%, 256 votes
Open the case and see if dust is around the fan. If it is, then get a can of air and gently blow the dust off. You can also replace the fan. These go out quite often due to them being on all the time. If you have an old computer, you may be able to use the fan from it, if it will fit. Or you can buy one cheap off eBay. Be sure you are grounded when opening the computer case so you will not get static electricity in the computer and make sure it is unplugged.
Was this helpful?
Yes
No
Solution #3
Not Rated)
dbucyk
Rank: Wiz  Computers & Networking  Expert
Rating: 84%, 85 votes
There are two different types of fans in a computer.
Open the computer and look at the CPU fan. Is it turning. Also, if you hear a grinding sound, it is the power supply fan and you might as well just get another power supply.
Also, if the system is pretty dusty, used compressed air to clean out the system.
As more dust gets into a system it actually dries out the bearings.
Was this helpful?
Yes
No
Popular Solutions for HP Compaq Presario SR1720NX
Questions and Unsolved Problems for HP Compaq Presario SR1720NX
Do you recommend HP Compaq Presario SR1720NX (EL435AA) PC Desktop?
Answer
Answer
how to switch on nlue tooth in acer 4730z model laptop.its now showing no blue tooth device
Answer
My HP m9180f with Vista will not power up. It seems to be in permanent ''sleep mode''. Have tried... (More)
Answer
Dvd/CD RW+- not recognizing Dvd disk. CD is fine. Gateway GM5407E only DH16W1P161C on player. Vista... (More)
Answer
D2D recovery hi all i have acer extensa 5230 laptob which came with no OS so i got for it a genuine... (More)
Answer
How can I print off one frame in a video file?
Describe your PC Desktops problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Desktop Experts
Top Computer & Laptop Repairmen
in Baltimore, MD
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
